    MMM-ImagesPhotos - Show images from a directory
    85 Posts 26 Posters 127.3k Views 26 Watching
    • johnnyboyJ
      johnnyboy @cowboysdude
        c.keen
        I really like this module but experienced kind of a delayed loading of the pictures. I have the raspberry pi 3 running, the pictures (all .jpg) are about 2MB which I think is not such a huge size. Any idea how to excelerate the loading?
        R 1 Reply Last reply
          roramirez Core Contributors @c.keen
          @c.keen The first loading or for every image? are you playing with getInterval?
            c.keen
            @roramirez The first loading of a picture when the mirror gets startet is interrupted, only the first few “lines” of a picture are shown, then the next picture is displayed. I have read about ‘getInterval’ command on the github module page but do not understand it completely. Reading the description it seems the same to me as the ‘updateInterval’ command (??) Any suggestions?
              @c.keen Can you take a screenshot of that?
              • L
                LeztherRokk
                Hello, I install your module and it works perfect for me, thanks, I wanna ask you, can I display videos from this module? I want to do one for videos but I just started in this. Thanks :)
                  roramirez Core Contributors @LeztherRokk
                  @LeztherRokk It’s for only images. Do you want reproduce many videos like playlist?
                  L 1 Reply Last reply
                  • L
                    LeztherRokk @roramirez
                    @roramirez Yes, that’s what I want, have a playlist of videos and reproduce them en the mirror
                      @LeztherRokk Ok. This module is only for Images.
                      I think is not difficult add video support. But this is a things I ain’t planning to do in the near future.
                      • L
                        @roramirez Well, thanks, I think I will check if I can make one, thank you!
                        • N
                          nobita @roramirez
                          @roramirez How can I select What photo is 1st 2nd 3rd photo to display,Because your module is random display photo
                          Thanks for your hints
                            roramirez Core Contributors @nobita
                            @nobita Yes, currently work only in random mode.
                            You can create a new function for get data in not random mode and you call here
                            https://github.com/roramirez/MMM-ImagesPhotos/blob/master/MMM-ImagesPhotos.js#L128
                            A good point is add by configuration this function. If you are interested to add this feature with glad I’ll merge it :)
                            • G
                              Galang
                              hey @roramirez. i really like your MMM-imagephoto module. this module show photo with random but i want it oreder, can you help me how to fix this ?
                              C 1 Reply Last reply
                              • V
                                Vauxdvihl
                                Great module
                                Thanks for this
                                One question
                                How can i adjust the size?
                                  markus220
                                  There are no pictures on my mirror. It seems like the module doesn’t load.
                                  • dasbooterD
                                    dasbooter @roramirez
                                    Thanks a bunch for this module. Seems to work great maybe some pics show up more often than others. Curious what formats it accepts?
                                    • cowboysdudeC
                                      I’m going to think it accepts all formats…nothing is specified…
                                      @markus220 did you check the developer console to see if there are errors? Did you use the right dir format?
                                        Peter
                                        Very nice module.
                                        I have about 2000 pictures in the Upload directory, all resized to 100 kb.
                                        But the module only shows about 50 of them.
                                        Why does it not show the other pictures?
                                        Any idea?
                                        Peter
                                        N 1 Reply Last reply
                                        • N
                                          ninjabreadman @Peter
                                          @Peter
                                          What does your config look like? Where are your images? What type(s) are they? I tried making a folder with 100 files (well over 50), but that seemed to work fine.
                                          Do you have the photos in multiple folders/paths? If so, have you tried removing the path of the photos that work to leave the other paths (to determine they work)? Have you tried adding treatAllPathsAsOne: true to your module config?
                                          What is the content of photos.txt if you type curl http://localhost:8080/MMM-ImagesPhotos/photos > photos.txt into a separate console (while MM is running)?
                                          Don’t post it all here, but if there are not several thousand entries, the module is not seeing all of your files (but you knew that).
                                          P 1 Reply Last reply
                                            Peter @ninjabreadman
                                            @ninjabreadman solved.
                                            I did something stupid.
                                            I had 70 pictures (5mb each) and it caused trouble, so I resized them to 100kb.
                                            But I also have 2 sd cards …
                                            I put 2000 pictures (100kb) on one card and left the 70 (5mb) pictures on the other card.
                                            And then I changed cards …
                                            Peter
                                            • 3 / 5
