    MMM-ImagesPhotos - Show images from a directory
    85 Posts 26 Posters 126.1k Views 26 Watching
      c.keen
      @roramirez The first loading of a picture when the mirror gets startet is interrupted, only the first few “lines” of a picture are shown, then the next picture is displayed. I have read about ‘getInterval’ command on the github module page but do not understand it completely. Reading the description it seems the same to me as the ‘updateInterval’ command (??) Any suggestions?
        roramirez Core Contributors @c.keen
        @c.keen Can you take a screenshot of that?
        • L Offline
          LeztherRokk
          Hello, I install your module and it works perfect for me, thanks, I wanna ask you, can I display videos from this module? I want to do one for videos but I just started in this. Thanks :)
            roramirez Core Contributors @LeztherRokk
            @LeztherRokk It’s for only images. Do you want reproduce many videos like playlist?
            • L Offline
              LeztherRokk @roramirez
              @roramirez Yes, that’s what I want, have a playlist of videos and reproduce them en the mirror
                @LeztherRokk Ok. This module is only for Images.
                I think is not difficult add video support. But this is a things I ain’t planning to do in the near future.
                • L Offline
                  @roramirez Well, thanks, I think I will check if I can make one, thank you!
                  • N Offline
                    nobita @roramirez
                    @roramirez How can I select What photo is 1st 2nd 3rd photo to display,Because your module is random display photo
                    Thanks for your hints
                      roramirez Core Contributors @nobita
                      @nobita Yes, currently work only in random mode.
                      You can create a new function for get data in not random mode and you call here
                      https://github.com/roramirez/MMM-ImagesPhotos/blob/master/MMM-ImagesPhotos.js#L128
                      A good point is add by configuration this function. If you are interested to add this feature with glad I’ll merge it :)
                      • G Offline
                        Galang
                        hey @roramirez. i really like your MMM-imagephoto module. this module show photo with random but i want it oreder, can you help me how to fix this ?
                        • V Offline
                          Vauxdvihl
                          Great module
                          Thanks for this
                          One question
                          How can i adjust the size?
                            markus220
                            There are no pictures on my mirror. It seems like the module doesn’t load.
                            • dasbooterD Offline
                              dasbooter @roramirez
                              Thanks a bunch for this module. Seems to work great maybe some pics show up more often than others. Curious what formats it accepts?
                              • cowboysdudeC Offline
                                I’m going to think it accepts all formats…nothing is specified…
                                @markus220 did you check the developer console to see if there are errors? Did you use the right dir format?
                                  Peter
                                  Very nice module.
                                  I have about 2000 pictures in the Upload directory, all resized to 100 kb.
                                  But the module only shows about 50 of them.
                                  Why does it not show the other pictures?
                                  Any idea?
                                  Peter
                                  • N Offline
                                    ninjabreadman @Peter
                                    @Peter
                                    What does your config look like? Where are your images? What type(s) are they? I tried making a folder with 100 files (well over 50), but that seemed to work fine.
                                    Do you have the photos in multiple folders/paths? If so, have you tried removing the path of the photos that work to leave the other paths (to determine they work)? Have you tried adding treatAllPathsAsOne: true to your module config?
                                    What is the content of photos.txt if you type curl http://localhost:8080/MMM-ImagesPhotos/photos > photos.txt into a separate console (while MM is running)?
                                    Don’t post it all here, but if there are not several thousand entries, the module is not seeing all of your files (but you knew that).
                                      Peter @ninjabreadman
                                      @ninjabreadman solved.
                                      I did something stupid.
                                      I had 70 pictures (5mb each) and it caused trouble, so I resized them to 100kb.
                                      But I also have 2 sd cards …
                                      I put 2000 pictures (100kb) on one card and left the 70 (5mb) pictures on the other card.
                                      And then I changed cards …
                                      Peter
                                      • N Offline
                                        @Peter At least it’s fixed! Cheers.
                                          pepebc
                                          I like this module, but I would like it to start hidden by default in order to add the possibility of making it visible with voice command (use alexyak / voicecontrol). I have tried several options but I have no results.
                                            Mykle1 Project Sponsor Module Developer @pepebc
                                            @pepebc
                                            Take a look at the Hello-Lucy files. You can adapt what you find there to alex yak voice control. :-)
                                            • 3 / 5
