    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
    • daenickD Offline
      daenick @strawberry 3.141
      @strawberry-3.141 can try again without restart everything?
      By the way, you are so friendly. Thanks!
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @daenick
        @daenick remove the node_modules folder in MagicMirror/modules/MMM-voice first and go into /root/pocketsphinx and execute sudo make uninstall same in /root/sphinxbase then rerun the installer
        daenickD 2 Replies Last reply Reply Quote 0
        • daenickD Offline
          @strawberry-3.141 I ran the bash without the sudo. Finish ok
          • daenickD Offline
            @strawberry-3.141 Hello Again,
            Finnaly I got the MMM-voice installed, but how can I set the micro as default? Sometimes the micro can “hear me” but mostly of time no
            There´s some kind of special configuration with the micro?
            Thanks!
              Advokaten
              @strawberry-3-141
              I get this error (or is it?) when starting MagicMirror.
              MMM-voice: Starting pocketsphinx.
              (node:1844) DeprecationWarning: Calling an asynchronous function without callback is deprecated.
              The microphone icon appears and after it it states “ERROR”, within MagicMirror.
              Thanks!
                @daenick can you give more details about the issue? the only thing that is configurable is the mic the module should use like microphone: 0 or microphone: 1 …
                @Advokaten what is inside the error.log, if you only can see numbers in there please enable debug: true in the config and share the debug.log
                A daenickD 2 Replies Last reply Reply Quote 0
                  Advokaten @strawberry 3.141
                  @strawberry-3.141
                  error.log says 11111111
                  debug.log in /home/pi/MagicMirror/modules/MMM-voice ? There’s a ton of INFO: lines and at the bottom it says
                  Error opening audio device plughw:1 for capture: Connection refused
                  FATAL: "continuous.c", line 245: Failed to open audio device
                  It works fine with Alexa.
                  EDIT: When I added debug: true to the config file. When MagicMirror is up, it says “ERROR undefined” rather than just “ERROR”, like it did before.
                    strawberry 3.141 Project Sponsor Module Developer @Advokaten
                    @Advokaten did you choose the correct audio device id?
                      @strawberry-3.141 when installing it said my mic was 1 so that’s what I have in my config. I tried doing microphone: 0 but that didn’t work either.
                        @Advokaten can you check out this? http://cmusphinx.sourceforge.net/wiki/faq#qfailed_to_open_audio_device_dev_dspno_such_file_or_directory and troubleshoot section here http://robot.laylamah.com/?p=35
                        • daenickD Offline
                          @strawberry-3.141 The voice recognition works extremely slow. There’s a way to use Spanish as default language for voice commands?
                          Maybe using Google voice API?
                            @daenick please read this https://github.com/fewieden/MMM-voice#information if you want to use faster detection you have to use a different module as this one will never support online services like google, apple, amazon, etc.
                            there are some custom language models for other languages https://sourceforge.net/projects/cmusphinx/files/Acoustic and Language Models/
                              @strawberry-3.141 I’m lost. Still can’t figure out what’s wrong. :(
                                @Advokaten did you try what the second link suggested?
                                  @strawberry-3.141 Yes, sir! The ERROR text is gone. Now it’s displaying “Initialising…” and the mic icon has a slash through it and is blinking infinitely. I bet I’m doing a rookie mistake somewhere.
                                    @Advokaten never had this happened before neither did someone report this issue. I would need to see it myself in order to debug it.
                                      @strawberry-3.141 I tried reinstalling it with bash dependencies.sh and it’s back to “ERROR”. Derp.
                                      Looking at error.log in the MMM-voice folder I can find:
                                      Error opening audio device plughw:1,0 for capture: Connection refused
                                      Somebody gave a suggestion on running:
                                      pocketsphinx_continuous -inmic yes -adcdev plughw:1,0
                                      That too gave me:
                                      I haven’t attached anything to my RPi except for an USB microphone.
                                        @Advokaten did. you disable pulseaudio like in the Link?
                                          @strawberry-3.141 Yes.
                                          checking pulse/pulseaudio.h usability... no
                                          checking pulse/pulseaudio.h presence... no
                                          checking for pulse/pulseaudio.h... no
                                          checking alsa/asoundlib.h usability... yes
                                          checking alsa/asoundlib.h presence... yes
                                          checking for alsa/asoundlib.h... yes
                                            pepemujica
                                            Hi @strawberry-3-141 Now when I launch the mirror first it says “ready choose a mode” and after a few secnods “error” any idea why?
                                            • 10
                                            • 11
                                            • 12
                                            • 16
                                            • 17
                                            • 10 / 17
