    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
    • daenickD Offline
      daenick @strawberry 3.141
      @strawberry-3.141 I ran the bash without the sudo. Finish ok
      • daenickD Offline
        @strawberry-3.141 Hello Again,
        Finnaly I got the MMM-voice installed, but how can I set the micro as default? Sometimes the micro can “hear me” but mostly of time no
        There´s some kind of special configuration with the micro?
        Thanks!
          Advokaten
          @strawberry-3-141
          I get this error (or is it?) when starting MagicMirror.
          MMM-voice: Starting pocketsphinx.
          (node:1844) DeprecationWarning: Calling an asynchronous function without callback is deprecated.
          The microphone icon appears and after it it states “ERROR”, within MagicMirror.
          Thanks!
          • strawberry 3.141S Offline
            @daenick can you give more details about the issue? the only thing that is configurable is the mic the module should use like microphone: 0 or microphone: 1 …
            @Advokaten what is inside the error.log, if you only can see numbers in there please enable debug: true in the config and share the debug.log
            A daenickD 2 Replies Last reply Reply Quote 0
              Advokaten @strawberry 3.141
              @strawberry-3.141
              error.log says 11111111
              debug.log in /home/pi/MagicMirror/modules/MMM-voice ? There’s a ton of INFO: lines and at the bottom it says
              Error opening audio device plughw:1 for capture: Connection refused
              FATAL: "continuous.c", line 245: Failed to open audio device
              It works fine with Alexa.
              EDIT: When I added debug: true to the config file. When MagicMirror is up, it says “ERROR undefined” rather than just “ERROR”, like it did before.
                strawberry 3.141 Project Sponsor Module Developer @Advokaten
                @Advokaten did you choose the correct audio device id?
                  @strawberry-3.141 when installing it said my mic was 1 so that’s what I have in my config. I tried doing microphone: 0 but that didn’t work either.
                    @Advokaten can you check out this? http://cmusphinx.sourceforge.net/wiki/faq#qfailed_to_open_audio_device_dev_dspno_such_file_or_directory and troubleshoot section here http://robot.laylamah.com/?p=35
                    • daenickD Offline
                      @strawberry-3.141 The voice recognition works extremely slow. There’s a way to use Spanish as default language for voice commands?
                      Maybe using Google voice API?
                        strawberry 3.141 Project Sponsor Module Developer @daenick
                        @daenick please read this https://github.com/fewieden/MMM-voice#information if you want to use faster detection you have to use a different module as this one will never support online services like google, apple, amazon, etc.
                        there are some custom language models for other languages https://sourceforge.net/projects/cmusphinx/files/Acoustic and Language Models/
                          @strawberry-3.141 I’m lost. Still can’t figure out what’s wrong. :(
                            @Advokaten did you try what the second link suggested?
                              @strawberry-3.141 Yes, sir! The ERROR text is gone. Now it’s displaying “Initialising…” and the mic icon has a slash through it and is blinking infinitely. I bet I’m doing a rookie mistake somewhere.
                                @Advokaten never had this happened before neither did someone report this issue. I would need to see it myself in order to debug it.
                                  @strawberry-3.141 I tried reinstalling it with bash dependencies.sh and it’s back to “ERROR”. Derp.
                                  Looking at error.log in the MMM-voice folder I can find:
                                  Error opening audio device plughw:1,0 for capture: Connection refused
                                  Somebody gave a suggestion on running:
                                  pocketsphinx_continuous -inmic yes -adcdev plughw:1,0
                                  That too gave me:
                                  I haven’t attached anything to my RPi except for an USB microphone.
                                    @Advokaten did. you disable pulseaudio like in the Link?
                                      @strawberry-3.141 Yes.
                                      checking pulse/pulseaudio.h usability... no
                                      checking pulse/pulseaudio.h presence... no
                                      checking for pulse/pulseaudio.h... no
                                      checking alsa/asoundlib.h usability... yes
                                      checking alsa/asoundlib.h presence... yes
                                      checking for alsa/asoundlib.h... yes
                                        pepemujica
                                        Hi @strawberry-3-141 Now when I launch the mirror first it says “ready choose a mode” and after a few secnods “error” any idea why?
                                          Advokaten @pepemujica
                                          @pepemujica if you scroll to the bottom in your error.log, what does it say? I also cannot get it started.
                                            pepemujica @Advokaten
                                            @Advokaten Just a ‘1’
                                            • 10
                                            • 11
                                            • 12
                                            • 16
                                            • 17
                                            • 10 / 17
