    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
    • A
      Advokaten @strawberry 3.141
      @strawberry-3.141
      error.log says 11111111
      debug.log in /home/pi/MagicMirror/modules/MMM-voice ? There’s a ton of INFO: lines and at the bottom it says
      Error opening audio device plughw:1 for capture: Connection refused
      FATAL: "continuous.c", line 245: Failed to open audio device
      It works fine with Alexa.
      EDIT: When I added debug: true to the config file. When MagicMirror is up, it says “ERROR undefined” rather than just “ERROR”, like it did before.
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @Advokaten
        @Advokaten did you choose the correct audio device id?
        A 1 Reply Last reply
        • A
          @strawberry-3.141 when installing it said my mic was 1 so that’s what I have in my config. I tried doing microphone: 0 but that didn’t work either.
          • strawberry 3.141S
            @Advokaten can you check out this? http://cmusphinx.sourceforge.net/wiki/faq#qfailed_to_open_audio_device_dev_dspno_such_file_or_directory and troubleshoot section here http://robot.laylamah.com/?p=35
            • daenickD
              daenick @strawberry 3.141
              @strawberry-3.141 The voice recognition works extremely slow. There’s a way to use Spanish as default language for voice commands?
              Maybe using Google voice API?
              • strawberry 3.141S
                strawberry 3.141 Project Sponsor Module Developer @daenick
                @daenick please read this https://github.com/fewieden/MMM-voice#information if you want to use faster detection you have to use a different module as this one will never support online services like google, apple, amazon, etc.
                there are some custom language models for other languages https://sourceforge.net/projects/cmusphinx/files/Acoustic and Language Models/
                • A
                  @strawberry-3.141 I’m lost. Still can’t figure out what’s wrong. :(
                  • strawberry 3.141S
                    @Advokaten did you try what the second link suggested?
                    • A
                      @strawberry-3.141 Yes, sir! The ERROR text is gone. Now it’s displaying “Initialising…” and the mic icon has a slash through it and is blinking infinitely. I bet I’m doing a rookie mistake somewhere.
                      • strawberry 3.141S
                        @Advokaten never had this happened before neither did someone report this issue. I would need to see it myself in order to debug it.
                        • A
                          @strawberry-3.141 I tried reinstalling it with bash dependencies.sh and it’s back to “ERROR”. Derp.
                          Looking at error.log in the MMM-voice folder I can find:
                          Error opening audio device plughw:1,0 for capture: Connection refused
                          Somebody gave a suggestion on running:
                          pocketsphinx_continuous -inmic yes -adcdev plughw:1,0
                          That too gave me:
                          I haven’t attached anything to my RPi except for an USB microphone.
                          • strawberry 3.141S
                            @Advokaten did. you disable pulseaudio like in the Link?
                            • A
                              @strawberry-3.141 Yes.
                              checking pulse/pulseaudio.h usability... no
                              checking pulse/pulseaudio.h presence... no
                              checking for pulse/pulseaudio.h... no
                              checking alsa/asoundlib.h usability... yes
                              checking alsa/asoundlib.h presence... yes
                              checking for alsa/asoundlib.h... yes
                                pepemujica
                                Hi @strawberry-3-141 Now when I launch the mirror first it says “ready choose a mode” and after a few secnods “error” any idea why?
                                • A
                                  Advokaten @pepemujica
                                  @pepemujica if you scroll to the bottom in your error.log, what does it say? I also cannot get it started.
                                  P 1 Reply Last reply
                                    pepemujica @Advokaten
                                    @Advokaten Just a ‘1’
                                    • A
                                      @pepemujica and the debug.log?
                                        @Advokaten INFO: dict.c(213): Dictionary size 34, allocated 0 KiB for strings, 0 KiB for phones
                                        INFO: dict.c(361): 5 words read
                                        INFO: dict2pid.c(396): Building PID tables for dictionary
                                        INFO: dict2pid.c(406): Allocating 42^3 * 2 bytes (144 KiB) for word-initial triphones
                                        INFO: dict2pid.c(132): Allocated 42672 bytes (41 KiB) for word-final triphones
                                        INFO: dict2pid.c(196): Allocated 42672 bytes (41 KiB) for single-phone word triphones
                                        INFO: ngram_model_trie.c(354): Trying to read LM in trie binary format
                                        INFO: ngram_model_trie.c(365): Header doesn’t match
                                        INFO: ngram_model_trie.c(177): Trying to read LM in arpa format
                                        INFO: ngram_model_trie.c(193): LM of order 3
                                        INFO: ngram_model_trie.c(195): #1-grams: 25
                                        INFO: ngram_model_trie.c(195): #2-grams: 46
                                        INFO: ngram_model_trie.c(195): #3-grams: 23
                                        INFO: lm_trie.c(474): Training quantizer
                                        INFO: lm_trie.c(482): Building LM trie
                                        INFO: ngram_search_fwdtree.c(74): Initializing search tree
                                        INFO: ngram_search_fwdtree.c(101): 28 unique initial diphones
                                        INFO: ngram_search_fwdtree.c(186): Creating search channels
                                        INFO: ngram_search_fwdtree.c(323): Max nonroot chan increased to 157
                                        INFO: ngram_search_fwdtree.c(333): Created 28 root, 29 non-root channels, 5 single-phone words
                                        INFO: ngram_search_fwdflat.c(157): fwdflat: min_ef_width = 4, max_sf_win = 25
                                        INFO: continuous.c(307): pocketsphinx_continuous COMPILED ON: Mar 29 2017, AT: 15:15:03
                                        Error opening audio device plughw:0 for capture: Device or resource busy
                                        FATAL: “continuous.c”, line 245: Failed to open audio device
                                        • A
                                          @pepemujica We have the same error! I feel relieved that I’m not alone! :D
                                          P 2 Replies Last reply
                                            @Advokaten :D
                                            • 10
                                            • 11
                                            • 12
                                            • 16
                                            • 17
                                            • 10 / 17
