    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @Advokaten
      @Advokaten never had this happened before neither did someone report this issue. I would need to see it myself in order to debug it.
      • A
        Advokaten @strawberry 3.141
        @strawberry-3.141 I tried reinstalling it with bash dependencies.sh and it’s back to “ERROR”. Derp.
        Looking at error.log in the MMM-voice folder I can find:
        Error opening audio device plughw:1,0 for capture: Connection refused
        FATAL: "continuous.c", line 245: Failed to open audio device
        Somebody gave a suggestion on running:
        pocketsphinx_continuous -inmic yes -adcdev plughw:1,0
        That too gave me:
        I haven’t attached anything to my RPi except for an USB microphone.
        • strawberry 3.141S
          @Advokaten did. you disable pulseaudio like in the Link?
          • A
            @strawberry-3.141 Yes.
            checking pulse/pulseaudio.h usability... no
            checking pulse/pulseaudio.h presence... no
            checking for pulse/pulseaudio.h... no
            checking alsa/asoundlib.h usability... yes
            checking alsa/asoundlib.h presence... yes
            checking for alsa/asoundlib.h... yes
              pepemujica
              Hi @strawberry-3-141 Now when I launch the mirror first it says “ready choose a mode” and after a few secnods “error” any idea why?
              • A
                Advokaten @pepemujica
                @pepemujica if you scroll to the bottom in your error.log, what does it say? I also cannot get it started.
                  pepemujica @Advokaten
                  @Advokaten Just a ‘1’
                  • A
                    @pepemujica and the debug.log?
                      @Advokaten INFO: dict.c(213): Dictionary size 34, allocated 0 KiB for strings, 0 KiB for phones
                      INFO: dict.c(361): 5 words read
                      INFO: dict2pid.c(396): Building PID tables for dictionary
                      INFO: dict2pid.c(406): Allocating 42^3 * 2 bytes (144 KiB) for word-initial triphones
                      INFO: dict2pid.c(132): Allocated 42672 bytes (41 KiB) for word-final triphones
                      INFO: dict2pid.c(196): Allocated 42672 bytes (41 KiB) for single-phone word triphones
                      INFO: ngram_model_trie.c(354): Trying to read LM in trie binary format
                      INFO: ngram_model_trie.c(365): Header doesn’t match
                      INFO: ngram_model_trie.c(177): Trying to read LM in arpa format
                      INFO: ngram_model_trie.c(193): LM of order 3
                      INFO: ngram_model_trie.c(195): #1-grams: 25
                      INFO: ngram_model_trie.c(195): #2-grams: 46
                      INFO: ngram_model_trie.c(195): #3-grams: 23
                      INFO: lm_trie.c(474): Training quantizer
                      INFO: lm_trie.c(482): Building LM trie
                      INFO: ngram_search_fwdtree.c(74): Initializing search tree
                      INFO: ngram_search_fwdtree.c(101): 28 unique initial diphones
                      INFO: ngram_search_fwdtree.c(186): Creating search channels
                      INFO: ngram_search_fwdtree.c(323): Max nonroot chan increased to 157
                      INFO: ngram_search_fwdtree.c(333): Created 28 root, 29 non-root channels, 5 single-phone words
                      INFO: ngram_search_fwdflat.c(157): fwdflat: min_ef_width = 4, max_sf_win = 25
                      INFO: continuous.c(307): pocketsphinx_continuous COMPILED ON: Mar 29 2017, AT: 15:15:03
                      Error opening audio device plughw:0 for capture: Device or resource busy
                      FATAL: “continuous.c”, line 245: Failed to open audio device
                      • A
                        @pepemujica We have the same error! I feel relieved that I’m not alone! :D
                        P 2 Replies Last reply Reply Quote 0
                          @Advokaten :D
                            @Advokaten Hi, nothing to do with this, but as far as I couldn’t update the MM, I’ve removed the update notification from the config file and now it seems to be working the MM-Voice. don’t know why
                              pepemujica
                              Hi @strawberry-3-141 finally I could get working the module, I say something and I see under the mic, but thats all. Should I do anything else so I can show or hide modules for example?
                              Kind regards
                              • strawberry 3.141S
                                strawberry 3.141 Project Sponsor Module Developer @pepemujica
                                @pepemujica you have to enter voice mode first
                                  pepemujica @strawberry 3.141
                                  @strawberry-3.141 how do I do that? Is there any tutorial?
                                  • strawberry 3.141S
                                    @pepemujica saying the keyword followed by the mode you want to enter https://github.com/fewieden/MMM-voice#usage
                                      @strawberry-3.141 GOD!!! I’ve change a module and now I get error again ):
                                      Despite of that, I’ve said Magic Mirror Open Help, and nothing happen
                                      • strawberry 3.141S
                                        @pepemujica you still didnt enter the mode yet
                                          @strawberry-3.141 Could you give me an example please?
                                          • strawberry 3.141S
                                            @pepemujica MAGIC MIRROR VOICE OPEN HELP
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
