    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
      pepemujica @Advokaten
      @Advokaten Just a ‘1’
        Advokaten @pepemujica
        @pepemujica and the debug.log?
          @Advokaten INFO: dict.c(213): Dictionary size 34, allocated 0 KiB for strings, 0 KiB for phones
          INFO: dict.c(361): 5 words read
          INFO: dict2pid.c(396): Building PID tables for dictionary
          INFO: dict2pid.c(406): Allocating 42^3 * 2 bytes (144 KiB) for word-initial triphones
          INFO: dict2pid.c(132): Allocated 42672 bytes (41 KiB) for word-final triphones
          INFO: dict2pid.c(196): Allocated 42672 bytes (41 KiB) for single-phone word triphones
          INFO: ngram_model_trie.c(354): Trying to read LM in trie binary format
          INFO: ngram_model_trie.c(365): Header doesn’t match
          INFO: ngram_model_trie.c(177): Trying to read LM in arpa format
          INFO: ngram_model_trie.c(193): LM of order 3
          INFO: ngram_model_trie.c(195): #1-grams: 25
          INFO: ngram_model_trie.c(195): #2-grams: 46
          INFO: ngram_model_trie.c(195): #3-grams: 23
          INFO: lm_trie.c(474): Training quantizer
          INFO: lm_trie.c(482): Building LM trie
          INFO: ngram_search_fwdtree.c(74): Initializing search tree
          INFO: ngram_search_fwdtree.c(101): 28 unique initial diphones
          INFO: ngram_search_fwdtree.c(186): Creating search channels
          INFO: ngram_search_fwdtree.c(323): Max nonroot chan increased to 157
          INFO: ngram_search_fwdtree.c(333): Created 28 root, 29 non-root channels, 5 single-phone words
          INFO: ngram_search_fwdflat.c(157): fwdflat: min_ef_width = 4, max_sf_win = 25
          INFO: continuous.c(307): pocketsphinx_continuous COMPILED ON: Mar 29 2017, AT: 15:15:03
          Error opening audio device plughw:0 for capture: Device or resource busy
          FATAL: “continuous.c”, line 245: Failed to open audio device
            @pepemujica We have the same error! I feel relieved that I’m not alone! :D
            P 2 Replies Last reply Reply Quote 0
              @Advokaten :D
                @Advokaten Hi, nothing to do with this, but as far as I couldn’t update the MM, I’ve removed the update notification from the config file and now it seems to be working the MM-Voice. don’t know why
                  pepemujica
                  Hi @strawberry-3-141 finally I could get working the module, I say something and I see under the mic, but thats all. Should I do anything else so I can show or hide modules for example?
                  Kind regards
                  • strawberry 3.141S Offline
                    strawberry 3.141 Project Sponsor Module Developer @pepemujica
                    @pepemujica you have to enter voice mode first
                      pepemujica @strawberry 3.141
                      @strawberry-3.141 how do I do that? Is there any tutorial?
                        @pepemujica saying the keyword followed by the mode you want to enter https://github.com/fewieden/MMM-voice#usage
                          @strawberry-3.141 GOD!!! I’ve change a module and now I get error again ):
                          Despite of that, I’ve said Magic Mirror Open Help, and nothing happen
                            @pepemujica you still didnt enter the mode yet
                              @strawberry-3.141 Could you give me an example please?
                                @pepemujica MAGIC MIRROR VOICE OPEN HELP
                                  Advokaten
                                  A fresh install of Jessie and MM and this module works without any problems whatsoever. Awesome!
                                    @strawberry-3.141 Hi! I was verry busy with work. Any way, Is it possible to hide or show specific modules, such as show/hide clock or weather? Or to change profile with profileswitcher?
                                    Kind regards
                                      @pepemujica that is not possible atm
                                        @strawberry-3.141 So, what’s the final purpose of this module, sorry I can’t get in to it
                                          @pepemujica atm you can control the following modules (mmm-soccer, mmm-fuel, mmm-nhl and mmm-ip)
                                          and some basic commands in the voice module itself
                                          COMMANDS:
                                          • HIDE MODULES
                                          • SHOW MODULES
                                          • WAKE UP
                                          • GO TO SLEEP
                                          • OPEN HELP
                                          • CLOSE HELP
                                            pawpawsoswag
                                            im having a problem with this module i try to speak the magic mirror-> then go to command like “GO TO SLEEP” but nothing will happen also when i speak the command “Magic Mirror” then the mic flashing it does nothing
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
