    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
    • A
      Advokaten @strawberry 3.141
      @strawberry-3.141 I’m lost. Still can’t figure out what’s wrong. :(
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @Advokaten
        @Advokaten did you try what the second link suggested?
        • A
          @strawberry-3.141 Yes, sir! The ERROR text is gone. Now it’s displaying “Initialising…” and the mic icon has a slash through it and is blinking infinitely. I bet I’m doing a rookie mistake somewhere.
          • strawberry 3.141S
            @Advokaten never had this happened before neither did someone report this issue. I would need to see it myself in order to debug it.
            • A
              @strawberry-3.141 I tried reinstalling it with bash dependencies.sh and it’s back to “ERROR”. Derp.
              Looking at error.log in the MMM-voice folder I can find:
              Error opening audio device plughw:1,0 for capture: Connection refused
              FATAL: "continuous.c", line 245: Failed to open audio device
              Somebody gave a suggestion on running:
              pocketsphinx_continuous -inmic yes -adcdev plughw:1,0
              That too gave me:
              I haven’t attached anything to my RPi except for an USB microphone.
              • strawberry 3.141S
                @Advokaten did. you disable pulseaudio like in the Link?
                • A
                  @strawberry-3.141 Yes.
                  checking pulse/pulseaudio.h usability... no
                  checking pulse/pulseaudio.h presence... no
                  checking for pulse/pulseaudio.h... no
                  checking alsa/asoundlib.h usability... yes
                  checking alsa/asoundlib.h presence... yes
                  checking for alsa/asoundlib.h... yes
                    pepemujica
                    Hi @strawberry-3-141 Now when I launch the mirror first it says “ready choose a mode” and after a few secnods “error” any idea why?
                    • A
                      Advokaten @pepemujica
                      @pepemujica if you scroll to the bottom in your error.log, what does it say? I also cannot get it started.
                        pepemujica @Advokaten
                        @Advokaten Just a ‘1’
                        • A
                          @pepemujica and the debug.log?
                            @Advokaten INFO: dict.c(213): Dictionary size 34, allocated 0 KiB for strings, 0 KiB for phones
                            INFO: dict.c(361): 5 words read
                            INFO: dict2pid.c(396): Building PID tables for dictionary
                            INFO: dict2pid.c(406): Allocating 42^3 * 2 bytes (144 KiB) for word-initial triphones
                            INFO: dict2pid.c(132): Allocated 42672 bytes (41 KiB) for word-final triphones
                            INFO: dict2pid.c(196): Allocated 42672 bytes (41 KiB) for single-phone word triphones
                            INFO: ngram_model_trie.c(354): Trying to read LM in trie binary format
                            INFO: ngram_model_trie.c(365): Header doesn’t match
                            INFO: ngram_model_trie.c(177): Trying to read LM in arpa format
                            INFO: ngram_model_trie.c(193): LM of order 3
                            INFO: ngram_model_trie.c(195): #1-grams: 25
                            INFO: ngram_model_trie.c(195): #2-grams: 46
                            INFO: ngram_model_trie.c(195): #3-grams: 23
                            INFO: lm_trie.c(474): Training quantizer
                            INFO: lm_trie.c(482): Building LM trie
                            INFO: ngram_search_fwdtree.c(74): Initializing search tree
                            INFO: ngram_search_fwdtree.c(101): 28 unique initial diphones
                            INFO: ngram_search_fwdtree.c(186): Creating search channels
                            INFO: ngram_search_fwdtree.c(323): Max nonroot chan increased to 157
                            INFO: ngram_search_fwdtree.c(333): Created 28 root, 29 non-root channels, 5 single-phone words
                            INFO: ngram_search_fwdflat.c(157): fwdflat: min_ef_width = 4, max_sf_win = 25
                            INFO: continuous.c(307): pocketsphinx_continuous COMPILED ON: Mar 29 2017, AT: 15:15:03
                            Error opening audio device plughw:0 for capture: Device or resource busy
                            FATAL: “continuous.c”, line 245: Failed to open audio device
                            • A
                              @pepemujica We have the same error! I feel relieved that I’m not alone! :D
                              P 2 Replies Last reply Reply Quote 0
                                @Advokaten :D
                                  @Advokaten Hi, nothing to do with this, but as far as I couldn’t update the MM, I’ve removed the update notification from the config file and now it seems to be working the MM-Voice. don’t know why
                                    pepemujica
                                    Hi @strawberry-3-141 finally I could get working the module, I say something and I see under the mic, but thats all. Should I do anything else so I can show or hide modules for example?
                                    Kind regards
                                    • strawberry 3.141S
                                      strawberry 3.141 Project Sponsor Module Developer @pepemujica
                                      @pepemujica you have to enter voice mode first
                                        pepemujica @strawberry 3.141
                                        @strawberry-3.141 how do I do that? Is there any tutorial?
                                        • strawberry 3.141S
                                          @pepemujica saying the keyword followed by the mode you want to enter https://github.com/fewieden/MMM-voice#usage
                                            @strawberry-3.141 GOD!!! I’ve change a module and now I get error again ):
                                            Despite of that, I’ve said Magic Mirror Open Help, and nothing happen
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
