MMM-voice
@Advokaten :D
@Advokaten Hi, nothing to do with this, but as far as I couldn’t update the MM, I’ve removed the update notification from the config file and now it seems to be working the MM-Voice. don’t know why
Hi @strawberry-3-141 finally I could get working the module, I say something and I see under the mic, but thats all. Should I do anything else so I can show or hide modules for example?
Kind regards -
@pepemujica you have to enter voice mode first
@strawberry-3.141 how do I do that? Is there any tutorial?
@pepemujica saying the keyword followed by the mode you want to enter https://github.com/fewieden/MMM-voice#usage
@strawberry-3.141 GOD!!! I’ve change a module and now I get error again ):
Despite of that, I’ve said Magic Mirror Open Help, and nothing happen -
@pepemujica you still didnt enter the mode yet
@strawberry-3.141 Could you give me an example please?
@pepemujica MAGIC MIRROR VOICE OPEN HELP
A fresh install of Jessie and MM and this module works without any problems whatsoever. Awesome!
@strawberry-3.141 Hi! I was verry busy with work. Any way, Is it possible to hide or show specific modules, such as show/hide clock or weather? Or to change profile with profileswitcher?
Kind regards
@pepemujica that is not possible atm
@strawberry-3.141 So, what’s the final purpose of this module, sorry I can’t get in to it
@pepemujica atm you can control the following modules (mmm-soccer, mmm-fuel, mmm-nhl and mmm-ip)
and some basic commands in the voice module itself
COMMANDS:
- HIDE MODULES
- SHOW MODULES
- WAKE UP
- GO TO SLEEP
- OPEN HELP
- CLOSE HELP
im having a problem with this module i try to speak the magic mirror-> then go to command like “GO TO SLEEP” but nothing will happen also when i speak the command “Magic Mirror” then the mic flashing it does nothing
@pawpawsoswag try saying “MAGIC MIRROR VOICE”
@Advokaten still not working :(
@pawpawsoswag MAGIC MIRROR VOICE OPEN HELP? Maybe pause a bit before saying “VOICE”?
maybe someone can help me…I installed this module and when I starting the Magic Mirror, everything seems to be fine.
But since I installed this Module, my microfone and the audio output is not working anymore (I tested the microfone and the speaker before I installed this module).
Iḿ using a USB-Dongle and like I sayed, everything was fine until I installed this module.
When I choose the “Audio Device Setting”, I can choose between “bcm2385 ALSA” and “USB PnP Sound Device”. Both are not working anymore.
Someone have some advise?
Thank you very much.
