    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
      Advokaten @pepemujica
      @pepemujica We have the same error! I feel relieved that I’m not alone! :D
      P 2 Replies Last reply Reply Quote 0
        pepemujica @Advokaten
        @Advokaten :D
          @Advokaten Hi, nothing to do with this, but as far as I couldn’t update the MM, I’ve removed the update notification from the config file and now it seems to be working the MM-Voice. don’t know why
            pepemujica
            Hi @strawberry-3-141 finally I could get working the module, I say something and I see under the mic, but thats all. Should I do anything else so I can show or hide modules for example?
            Kind regards
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @pepemujica
              @pepemujica you have to enter voice mode first
                pepemujica @strawberry 3.141
                @strawberry-3.141 how do I do that? Is there any tutorial?
                  @pepemujica saying the keyword followed by the mode you want to enter https://github.com/fewieden/MMM-voice#usage
                    @strawberry-3.141 GOD!!! I’ve change a module and now I get error again ):
                    Despite of that, I’ve said Magic Mirror Open Help, and nothing happen
                      @pepemujica you still didnt enter the mode yet
                        @strawberry-3.141 Could you give me an example please?
                          @pepemujica MAGIC MIRROR VOICE OPEN HELP
                            Advokaten
                            A fresh install of Jessie and MM and this module works without any problems whatsoever. Awesome!
                              @strawberry-3.141 Hi! I was verry busy with work. Any way, Is it possible to hide or show specific modules, such as show/hide clock or weather? Or to change profile with profileswitcher?
                              Kind regards
                                @pepemujica that is not possible atm
                                  @strawberry-3.141 So, what’s the final purpose of this module, sorry I can’t get in to it
                                    @pepemujica atm you can control the following modules (mmm-soccer, mmm-fuel, mmm-nhl and mmm-ip)
                                    and some basic commands in the voice module itself
                                    COMMANDS:
                                    • HIDE MODULES
                                    • SHOW MODULES
                                    • WAKE UP
                                    • GO TO SLEEP
                                    • OPEN HELP
                                    • CLOSE HELP
                                      pawpawsoswag
                                      im having a problem with this module i try to speak the magic mirror-> then go to command like “GO TO SLEEP” but nothing will happen also when i speak the command “Magic Mirror” then the mic flashing it does nothing
                                        Advokaten @pawpawsoswag
                                        @pawpawsoswag try saying “MAGIC MIRROR VOICE”
                                          pawpawsoswag @Advokaten
                                          @Advokaten still not working :(
                                            @pawpawsoswag MAGIC MIRROR VOICE OPEN HELP? Maybe pause a bit before saying “VOICE”?
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
