    [ORDER CLOSED] Two way mirror order in Germany
    Scheduled Pinned Locked Moved Solved Hardware
    558 Posts 80 Posters 2.9m Views 60 Watching
    • T Offline
      tomster
      The broken one was 740 x 540 mm’s. The other is 1000 x 800 mm’s.
      • G Offline
        Goldjunge_Chriz @tomster
        @tomster
        First of all many thanks for the positive recession to the mirror and the delivery itself.
        It makes me sad to hear that your mirror has unfortunately broken :( Are you really sure that nothing happened in the night? (Children, woman / girlfriend, pets …)? What exactly do you mean with chip? In my opinion, it looks like a thumb print. Perhaps the mirror was only applied and worn on one side of the edge, and therefore the break has arisen (I refer to the lever law). Can you really rule out that it did not happen to yourself when you put the mirror from A to B at home? When I packed the mirrors all, I looked at each and could not see any damage. So it must have happened later. I’m really sorry :( :(
        • T Offline
          tomster
          Thx for your reply Chriz,
          of course I cannot outrule anything. I took the mirrors from the driver and brought them directly to my living-room. To my dearest knowledge no-one else but me has touched the mirror since. That is why I came to the assumption it might have been transport damage.
          The glass chip (~7mm in diameter) looks like a “Abplatzung” as if the mirror was put to the floor on the edge-side and some sort of tiny pebble was sitting there. I do have no real explanation for the cracks though.
            Binog
            Hey there !
            I thought I should pose some pictures of my mirror. At first: Thanx to You @Goldjunge_Chriz for all Your effort. It was kind of challenging my human faith, too. Had the same crazy thoughts as @yawns had. As specially as the recipient of the mirror (and the guy who paid ;-) had no idea, that this was actually his present. (so not much financial risk,. put a friendship…so it had to end well!) So, thx god, nothing was cracked - I feel really sorry for You, @tomster !!
            Short review:
            As in the last picture, the mirror seems darker, compared to the wall,. the red shiny is the light installation and confuses a little bit.
            Comparing the first image (monitor settings eco2 of 4(no eco), brightness 45%) to the other one, You see the mirror is indeed dropping light emission significantly. In a sunny condition, You have to really concentrate to read the text. (light is coming from the ceiling and the window a meter next to the mirror’s wall. None the less, it is more important in the evening and the morning hours.
            To those who might ask. Yes, the monitor is smaller than the mirror, that is not that bad, so don’t have so much heating problem. I was been able to put a pass-par-tout around with a tiny whole for the NOIR-Cam which switches the monitor on and off.
            I want to put out, that it wasn’t that easy to fix the mirror on the frame, and I am not that sure, if my way was the best. How did You guys fix the mirror on your wodden frame??
            Thanx again Chriz for all Your effort !! I really appreciate that !!
            0_1491672417892_picture1.jpg 0_1491672426891_picture2.jpg 0_1491672438503_picture3.jpg
              Advokaten
              If insurance won’t cover the damages - I’d like to propose a funding for @tomster as one of his mirrors broke, if there is any interest in this community for such a thing? If everyone chips in, it won’t be that much each.
              • G Offline
                Goldjunge_Chriz @Binog
                @Binog
                Thanks for your review and the great pictures :) Did I understand correctly that you are altogether very satisfied? As already described above, there is no mirror that works perfectly in hundreds of different light conditions. This one makes it however already quite properly and is a good mixture. If on a television for example the sunshine falls directly on it you can see nothing more ;) You can see, nothing is absolutely Perfect.
                @Advokaten
                Great Idea. I am in ;)
                @all
                New additional insights about the mirror glass we could make from the first order:
                • The mirror glass works easily with cameras and motion detection systems behind it
                • the mirror glass can easily be glued for the frame-free use.
                A H 2 Replies Last reply Reply Quote 0
                  Advokaten @Goldjunge_Chriz
                  @Goldjunge_Chriz so a PIR sensor, for example, can see through it? That’s awesome!
                  • strawberry 3.141S Offline
                    strawberry 3.141 Project Sponsor Module Developer @Advokaten
                    @Advokaten I guess he means motion detection with a camera
                    • H Offline
                      Hawking @Goldjunge_Chriz
                      @Goldjunge_Chriz said in [ORDER CLOSED] Two way mirror order in Germany:
                      Can you provide more details (what type of camera, how did you attach it to the mirror. …) and maybe even a picture of the setup?. Thanks.
                      • G Offline
                        Goldjunge_Chriz @Hawking
                        @Hawking
                        @Lolobyte can say more about that :)
                          cpramhofer
                          The most important Question: will there be a second chance to place an order? this time i will organize a personal transport from Germany to Vienna :)
                          • G Offline
                            Goldjunge_Chriz @cpramhofer
                            @cpramhofer said in [ORDER CLOSED] Two way mirror order in Germany:
                            Please have a look at this thread:
                            https://forum.magicmirror.builders/topic/2016/two-way-mirror-order-in-germany-accumulation-for-2nd-round/
                            The transport of big mirrors to austria is now also possible ;)
                              Ali Baba
                              Today Finale My mirror arrived. All Fine. Trank you Chris for your exzellent work.👍🏽
                                Binog
                                @Goldjunge_Chriz Yes I am very satisfied !
                                @Hawking I used a official Raspberry NoIR Camera attached via the wired-band to the cis-port of a Raspberry 3. The attachments to the mirror is kind of special, cause it is depending of ones setting.
                                As You can see in the pictures I used the cut-off of the pass-par-tout as a first framework, pooled two screws in it, unfortunately one was shorter than the other one, that is, in the other picture, You realized the camera is odd, but that doesn’t matter as I didn’t want to take photos rather then detect motion. The image by raspistill is very unsharp, but that isn’t important either. It does what it does, detecting motion.
                                As the pass-par-tout is kind of foam I could screw-in the screw directly. In total the framework fits neatly between monitor and mirror-frame.
                                Hopefully that helps build Your mirror.
                                  Binog
                                  Hey folks, could You please post some photos, how You fixed the mirrorglas to Your framework!? Thank You !
                                  • L Offline
                                    lolobyte @Goldjunge_Chriz
                                    @Hawking
                                    Here is my Cam picture behind the mirror from @Goldjunge_Chriz.
                                    RaspiCam with old mirror glass
                                    RaspiCam with new mirror glass
                                    my Mirror
                                    H 1 Reply Last reply Reply Quote 3
                                    • T Offline
                                      tomster @Advokaten
                                      @Advokaten
                                      Thank you very much for the kind offer. But having had a good sleep or two over the issue I managed to find peace with myself again ;-) All in all it’s just a broken mirror…
                                      I did order a second mirror along with the first and decided to simply change my plans for its use. I went to my local glass shop and asked them to cut it in half. That way I will end up with 2 mirrors. Ok, they are different in size now, but hey? I will end up with 2 mirrors still :)
                                      Again, I really do appreciate your offer as it proves a hell of a lot in regards of community spirit. Especially since it is not the fault of any of you. I do hope though that you do not bother that I have to turn down your offer. Everything is fine.
                                      • H Offline
                                        Hawking @lolobyte
                                        Thanks for the pictures.
                                        @lolobyte said in [ORDER CLOSED] Two way mirror order in Germany:
                                        @Hawking
                                        What do you mean by “old mirror glass” and “new mirror glass”? Anyway, both pictures look very good, I hope that even gesture detection trough the glass should be possible. Can you also provide details how you attached the raspi-camera (regular or also noir variant?) at the back of the mirror?
                                        • L Offline
                                          lolobyte @Hawking
                                          @Hawking
                                          like @Goldjunge_Chriz said and i mentioned, the new mirror glass is the one from @Goldjunge_Chriz .
                                          My setup is like this.
                                            Advokaten @lolobyte
                                            @lolobyte, and the front/side?? Thanks!
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 27 / 28
