    MMM-ProfileSwitcher, A Profile/User/Layout Switching Module
    userswitchprofilelayoutmodule
    91 Posts 21 Posters 161.4k Views 23 Watching
    • T
      tosti007 Module Developer @Guest
      @PatrickGlatz
      I just gave it a look and I know what’s wrong. The problem is that the code only looks at those times when switching to a different profile than the default profile. So it’s not a fault on your side but on mine.
      Solution: I already solved it on my local pc and will upload the fix later today uploaded. All you will have to do is pull the new changes and the config you showed should work without a problem :)
      Sorry for the inconvenience, a mistake on my part. Thank you for letting me know!
      Greetings
      Brian
      If there is anything don’t hesitate to contact me!
      ProfileSwitcher, TouchNotifications
        pepemujica
        Hi! Thanks for this module, seems it is what I’m looking for.
        Unfortunately, I very new with all this and wolud like to know if there is a step by step guide for this, for example, if I want so show the clock and the wheather in one profile, and in other news feed… is this possible?
        Kind regards
        T 1 Reply Last reply
        • T
          tosti007 Module Developer @pepemujica
          @pepemujica Yes this is totally possible! Unfortunatly there is no step by step guide for this. However I did write a small how-to here.
          In your example you would have to give the weather and clock module the same profile name in classes and give the news feed a different one.
          Is that link enough information? If not let me know and I will try to explain it more in depth.
          P 1 Reply Last reply
            pepemujica @tosti007
            @tosti007 Thanks for answering, at the moment, can’t find where to change the profile name in classes, is it in a specific file?
            • T
              @pepemujica You can set them in your config file. In this example the profile will be TestA for the clock module.
              	module: 'clock',
              	position: 'top_right',
              	classes: 'TestA'
              P 2 Replies Last reply
                  @tosti007 Great! I got it. Is this module compatible with MMM-Voice? So I can change between profiles just with voice?
                  • T
                    @pepemujica Unfortunatly not, that’s up to the maker of MMM-Voice. It would be easiest to ask him to implement it for you, writing a tutorial for it would probably be too complicated.
                      @tosti007 And is it there any way to use it with the remote control? I mean, I’ve seen in the forum people who could do it, but I can’t figure how
                      • A
                        Anhalter42
                        If you have installed MMM-Remote-Control and set up some classes (e.g. “default”, “someclass”), then you can switch between them by calling these URLs:
                        http://[RaspberryURL]:[port]/remote?action=NOTIFICATION& notification=CURRENT_PROFILE&payload=%22default%22
                        http://[RaspberryURL]:[port]/remote?action=NOTIFICATION& notification=CURRENT_PROFILE&payload=%22someclass%22
                        (Remove the whitespace between & and notification. “& not” gets converted to ¬ and i dont know how to prevent this :D)
                          pepemujica @Anhalter42
                          @Anhalter42 said in MMM-ProfileSwitcher, A Profile/User/Layout Switching Module:
                          Awesome!!
                          And is it possible to add a shortcut in the control menu so there is no need to acces via url?
                            pepemujica @pepemujica
                            @Anhalter42 because I’ve added this
                            Custom
                            In the mirror it goes to the Custom profile, but in the remote control it goes to “{“status”:“success”}”
                            • A
                              Anhalter42
                              yeah this is the response from MMM-Remote-Control. You can do anything with this; your browser decides to plainly display it as text: “status”: “success”. Of course in this case, you usually want to just send the command and don’t receive anything. So in general, if you don’t want to see a response like this, have a look at for example Submit form and stay on same page and especially jQuery / XMLHttpRequest.
                              If you want it to be integrated in the Remote-Control menu (the /remote.html), you have to add it yourself or request it from the developer of the MMM-Remote-Control module (unlikely though). It’s similar to the existing options like show/hide modules etc., so it isn’t that difficult to implement.
                                @Anhalter42 Ok, I’ll take a look at this. I’m not good at developing, so I don’t think I could get it, but I’ll try.
                                Thanks!
                                • T
                                  @pepemujica So you have it working now? Sorry I haven’t been online recently.
                                  @Anhalter42 Thank you for your help!
                                    @tosti007 Yes, I’ve got something like this:
                                    <a id="link">Profile</a>
                                    document.getElementById("link").addEventListener("click", function(){
                                        const ventana = window.open("localhost/remote?action=NOTIFICATION& notification=CURRENT_PROFILE&payload=%22default%22");
                                        setTimeout(function(){
                                            ventana.close();
                                        }, 5000); /* 5 Segundos*/
                                      Binog
                                      Hey there, perhaps I am really too stupid,. I can’t get it to run. I have this config:
                                                  module: "MMM-ProfileSwitcher",
                                      				//includeEveryoneToDefault: true,
                                      				title: true,
                                      				enterMessages: {
                                      					"you me": "Hey %profile%!",
                                      					"me": ["looking great!"],
                                      					"you": ["looking great!"],
                                      				leaveMessages: {
                                      					"everyone": "C U %person%!",
                                      					"me": ["Hey why gone...?", true]
                                      				timers: {
                                         				 "you": {},
                                         				 "me": {},
                                      				enterMessages: false,
                                      				leaveMessage: false,
                                      and a modulbar that point out this:
                                      "5": {
                                                             text: "you",
                                                             showUrl: "http://ip:8080/remote?action=NOTIFICATION¬ification=CURRENT_PROFILE&payload=%22you%22",
                                      but if I hid the bottom, nothing happens!
                                      Think I am missing something. Do I need to set anything else off? My default view is quit perfect and loading, so yes I added the classes for the modules.
                                      classes: 'me',
                                      Thank You in advance !
                                      Jimmy
                                      A T 2 Replies Last reply
                                      • A
                                        Anhalter42 @Binog
                                        @Binog For me, the config looks fine. Just to be sure: you actually replaced “ip” in your URL with the actual IP, did you?
                                          Binog
                                          yes, yes,. of course. the two buttons don’t work. the default does work,. and if I say default = you then I get the modules for You,. so that is no problem. but clicking on the bottom does not change a thing, other bottoms do work fine,…
                                          • T
                                            tosti007 Module Developer @Binog
                                            Hello @Binog,
                                            First of all kinda unfortunate that it doesn’t work. I have a vague idea of what might be wrong but will have to do a small test by myself. I will test it tomorrow and let you know once I have more info or fixed the problem :)
                                            • 3 / 5
