    MMM-ProfileSwitcher, A Profile/User/Layout Switching Module
    userswitchprofilelayoutmodule
    91 Posts 21 Posters 158.6k Views 23 Watching
      pepemujica
      Hi! Thanks for this module, seems it is what I’m looking for.
      Unfortunately, I very new with all this and wolud like to know if there is a step by step guide for this, for example, if I want so show the clock and the wheather in one profile, and in other news feed… is this possible?
      Kind regards
      • T Offline
        tosti007 Module Developer @pepemujica
        @pepemujica Yes this is totally possible! Unfortunatly there is no step by step guide for this. However I did write a small how-to here.
        In your example you would have to give the weather and clock module the same profile name in classes and give the news feed a different one.
        Is that link enough information? If not let me know and I will try to explain it more in depth.
        If there is anything don’t hesitate to contact me!
        ProfileSwitcher, TouchNotifications
          pepemujica @tosti007
          @tosti007 Thanks for answering, at the moment, can’t find where to change the profile name in classes, is it in a specific file?
          • T Offline
            @pepemujica You can set them in your config file. In this example the profile will be TestA for the clock module.
            	module: 'clock',
            	position: 'top_right',
            	classes: 'TestA'
            P 2 Replies Last reply Reply Quote 0
                @tosti007 Great! I got it. Is this module compatible with MMM-Voice? So I can change between profiles just with voice?
                • T Offline
                  @pepemujica Unfortunatly not, that’s up to the maker of MMM-Voice. It would be easiest to ask him to implement it for you, writing a tutorial for it would probably be too complicated.
                    @tosti007 And is it there any way to use it with the remote control? I mean, I’ve seen in the forum people who could do it, but I can’t figure how
                      Anhalter42
                      If you have installed MMM-Remote-Control and set up some classes (e.g. “default”, “someclass”), then you can switch between them by calling these URLs:
                      http://[RaspberryURL]:[port]/remote?action=NOTIFICATION& notification=CURRENT_PROFILE&payload=%22default%22
                      http://[RaspberryURL]:[port]/remote?action=NOTIFICATION& notification=CURRENT_PROFILE&payload=%22someclass%22
                      (Remove the whitespace between & and notification. “& not” gets converted to ¬ and i dont know how to prevent this :D)
                        pepemujica @Anhalter42
                        @Anhalter42 said in MMM-ProfileSwitcher, A Profile/User/Layout Switching Module:
                        Awesome!!
                        And is it possible to add a shortcut in the control menu so there is no need to acces via url?
                          pepemujica @pepemujica
                          @Anhalter42 because I’ve added this
                          Custom
                          In the mirror it goes to the Custom profile, but in the remote control it goes to “{“status”:“success”}”
                            Anhalter42
                            yeah this is the response from MMM-Remote-Control. You can do anything with this; your browser decides to plainly display it as text: “status”: “success”. Of course in this case, you usually want to just send the command and don’t receive anything. So in general, if you don’t want to see a response like this, have a look at for example Submit form and stay on same page and especially jQuery / XMLHttpRequest.
                            If you want it to be integrated in the Remote-Control menu (the /remote.html), you have to add it yourself or request it from the developer of the MMM-Remote-Control module (unlikely though). It’s similar to the existing options like show/hide modules etc., so it isn’t that difficult to implement.
                              @Anhalter42 Ok, I’ll take a look at this. I’m not good at developing, so I don’t think I could get it, but I’ll try.
                              Thanks!
                              • T Offline
                                @pepemujica So you have it working now? Sorry I haven’t been online recently.
                                @Anhalter42 Thank you for your help!
                                  @tosti007 Yes, I’ve got something like this:
                                  <a id="link">Profile</a>
                                  document.getElementById("link").addEventListener("click", function(){
                                      const ventana = window.open("localhost/remote?action=NOTIFICATION& notification=CURRENT_PROFILE&payload=%22default%22");
                                      setTimeout(function(){
                                          ventana.close();
                                      }, 5000); /* 5 Segundos*/
                                    Binog
                                    Hey there, perhaps I am really too stupid,. I can’t get it to run. I have this config:
                                                module: "MMM-ProfileSwitcher",
                                    				//includeEveryoneToDefault: true,
                                    				title: true,
                                    				enterMessages: {
                                    					"you me": "Hey %profile%!",
                                    					"me": ["looking great!"],
                                    					"you": ["looking great!"],
                                    				leaveMessages: {
                                    					"everyone": "C U %person%!",
                                    					"me": ["Hey why gone...?", true]
                                    				timers: {
                                       				 "you": {},
                                       				 "me": {},
                                    				enterMessages: false,
                                    				leaveMessage: false,
                                    and a modulbar that point out this:
                                    "5": {
                                                           text: "you",
                                                           showUrl: "http://ip:8080/remote?action=NOTIFICATION¬ification=CURRENT_PROFILE&payload=%22you%22",
                                    but if I hid the bottom, nothing happens!
                                    Think I am missing something. Do I need to set anything else off? My default view is quit perfect and loading, so yes I added the classes for the modules.
                                    classes: 'me',
                                    Thank You in advance !
                                    Jimmy
                                    A T 2 Replies Last reply Reply Quote 0
                                      Anhalter42 @Binog
                                      @Binog For me, the config looks fine. Just to be sure: you actually replaced “ip” in your URL with the actual IP, did you?
                                        Binog
                                        yes, yes,. of course. the two buttons don’t work. the default does work,. and if I say default = you then I get the modules for You,. so that is no problem. but clicking on the bottom does not change a thing, other bottoms do work fine,…
                                        • T Offline
                                          tosti007 Module Developer @Binog
                                          Hello @Binog,
                                          First of all kinda unfortunate that it doesn’t work. I have a vague idea of what might be wrong but will have to do a small test by myself. I will test it tomorrow and let you know once I have more info or fixed the problem :)
                                            Blackmirror
                                            thanks for the modul,
                                            but when I start this module my magic mirror get blank.
                                                 module: 'MMM-Buttons',
                                                minShortPressTime: 10,
                                                         buttons: [
                                                         pin: 10,
                                                         longPress: {
        notification: "PROFILE_SWITCH",
        payload: {action: "Radio_OFF"}},
                                                         shortPress: {
        payload: {action: "Radio"}}},
                                                        pin: 11,
                                                        longPress: undefined,
                                                       shortPress: {
                                                          notification: "BUTTON_PRESSED"
                                                         //   payload: {action: "SHUTDOWN"}
                                                module: 'MMM-ProfileSwitcher',
                                                module: 'MMM-RadioDe',
                                                classes: 'Radio',
                                                position: 'bottom_left', // This can be any of the regions.
        // See 'Configuration options' for more$
        station: "hr3",
        // can be obtained in embed section of $
        api_key: 'XXX',
        //optional,
        height:"92", // in pixel
        width:"360", // in pixel
                                            • 3 / 5
