    MMM-MLB
    35 Posts 10 Posters 30.1k Views 10 Watching
      rodleland @cowboysdude
      @cowboysdude WORKS LIKE A CHARM. AMPED. thank you!
      • O Offline
        ooom416354 @cowboysdude
        @cowboysdude love it!!! amazing work!
          @cowboysdude
          You’re a freakin magician and a guru! :clap_tone1:
          • cowboysdudeC Offline
            @Mykle1 said in MMM-MLB:
            @cowboysdude
            Yes with a lot of help from a very good guy! :baseball:
              jimmrr
              @cowboysdude
              Hi, i’ve tried to install this on my magicmirror running on a pi zero, the module will not load in the browser. Any ideas? I have node v6.10.0 and npm 3.10.10.
              pi@raspberrypi:~/MagicMirror $ node serveronly
              Starting MagicMirror: v2.1.0
              Loading config ...
              Loading module helpers ...
              No helper found for module: calendar_monthly.
              All module helpers loaded.
              Starting server op port 8080 ...
              Server started ...
              Connecting socket for: MMM-MLB
              Starting module: MMM-MLB
              Ready to go! Please point your browser to: http://localhost:8080
              • strawberry 3.141S Offline
                strawberry 3.141 Project Sponsor Module Developer @jimmrr
                @jimmrr i guess you use the midori browser, which cant handle es6 and this module makes use of es6 features
                  Durnumosis @cowboysdude
                  @cowboysdude Thank you so much for your work on this module! I was digging through the code to see how you did it and noticed there’s some code for getting the MLB standings. Is this something that you are actively working on? It would be great to see the scores as well as the standings. Thanks again for a great module!
                    cowboysdude Module Developer @Durnumosis
                    @Durnumosis Well yes I am working on that part :) I’m running into snags so it’s going to be a while… still trying to figure it all out :)
                    Of course the standings is part of the voice part [MMM-voice]… I am also working on a standalone standings module… no voice required…
                    • O Offline
                      ooom416354
                      Question guys, I have the focus_on set to “Yankees” but today they happen to be off so all I see is the header, with the MLB logo and the text MLB Scores 04/20/2017. Is there a way to hide that if the team that is set in the focus_on is not playing that day?
                        cowboysdude Module Developer @ooom416354
                        @ooom416354 I will have to check into that. :) It’s going to take a little while.
                        • O Offline
                          @cowboysdude no problem, figured it would be a bit difficult
                            @ooom416354 Just from a time aspect :) My business is burying me right now… it’s that time of the year… ;)
                            • O Offline
                              @cowboysdude ha i know the feeling. Thanks again!
                                shanecrozier
                                It loads and shows scores and such but no logos not even MLB. Both are set to true
                                Any ideas ?
                                  cowboysdude Module Developer @shanecrozier
                                  @shanecrozier I only have one… I just deleted and reinstalled on mine and it’s working fine…
                                  SO in the MMM-MLB directory make sure the icon folder is there ;)
                                    shanecrozier @cowboysdude
                                    @cowboysdude yes it is already checked that and it has all the icons in it
                                      @shanecrozier Well I would say reinstall it because it doesn’t require npm install to run…
                                      Like I said I just downloaded it and reinstalled it and it’s working. So not really sure what’s going there as I"m not able to reproduce the issue unless the icons dir isn’t there.
                                        shanecrozier
                                        Ok will try that thanks for the help
                                        • emloweE Offline
                                          emlowe Module Developer
                                          I made a small change to this module.
                                          If you add the following:
                                          awayTempColumn.setAttribute(“team-name”, games.away_team_name);
                                          homeTempColumn.setAttribute(“team-name”, games.home_team_name);
                                          Then you can do this in your custom.css:
                                          .MMM-MLB .awayteam[team-name=“Giants”] { color: #FB5B1F; font-weight: bold; }
                                          .MMM-MLB .hometeam[team-name=“Giants”] { color: #FB5B1F; font-weight: bold; }
                                          And now, my Giants are in Giant orange…
                                          -Earle
                                            Mykle1 Project Sponsor Module Developer @emlowe
                                            @emlowe said in MMM-MLB:
                                            Go Gints!
