    MMM-MLB
    35 Posts 10 Posters 32.9k Views 10 Watching
    • ooom416354O
      ooom416354 @cowboysdude
      @cowboysdude love it!!! amazing work!
      • Mykle1M
        @cowboysdude
        You’re a freakin magician and a guru! :clap_tone1:
        • cowboysdudeC
          @Mykle1 said in MMM-MLB:
          @cowboysdude
          Yes with a lot of help from a very good guy! :baseball:
            jimmrr
            @cowboysdude
            Hi, i’ve tried to install this on my magicmirror running on a pi zero, the module will not load in the browser. Any ideas? I have node v6.10.0 and npm 3.10.10.
            pi@raspberrypi:~/MagicMirror $ node serveronly
            Starting MagicMirror: v2.1.0
            Loading config ...
            Loading module helpers ...
            No helper found for module: calendar_monthly.
            All module helpers loaded.
            Starting server op port 8080 ...
            Server started ...
            Connecting socket for: MMM-MLB
            Starting module: MMM-MLB
            Ready to go! Please point your browser to: http://localhost:8080
            • strawberry 3.141S
              strawberry 3.141 Project Sponsor Module Developer @jimmrr
              @jimmrr i guess you use the midori browser, which cant handle es6 and this module makes use of es6 features
                Durnumosis @cowboysdude
                @cowboysdude Thank you so much for your work on this module! I was digging through the code to see how you did it and noticed there’s some code for getting the MLB standings. Is this something that you are actively working on? It would be great to see the scores as well as the standings. Thanks again for a great module!
                • cowboysdudeC
                  cowboysdude Module Developer @Durnumosis
                  @Durnumosis Well yes I am working on that part :) I’m running into snags so it’s going to be a while… still trying to figure it all out :)
                  Of course the standings is part of the voice part [MMM-voice]… I am also working on a standalone standings module… no voice required…
                  • ooom416354O
                    ooom416354
                    Question guys, I have the focus_on set to “Yankees” but today they happen to be off so all I see is the header, with the MLB logo and the text MLB Scores 04/20/2017. Is there a way to hide that if the team that is set in the focus_on is not playing that day?
                    • cowboysdudeC
                      cowboysdude Module Developer @ooom416354
                      @ooom416354 I will have to check into that. :) It’s going to take a little while.
                      ooom416354O 1 Reply Last reply
                      • ooom416354O
                        @cowboysdude no problem, figured it would be a bit difficult
                        • cowboysdudeC
                          @ooom416354 Just from a time aspect :) My business is burying me right now… it’s that time of the year… ;)
                          • ooom416354O
                            @cowboysdude ha i know the feeling. Thanks again!
                              shanecrozier
                              It loads and shows scores and such but no logos not even MLB. Both are set to true
                              Any ideas ?
                              • cowboysdudeC
                                cowboysdude Module Developer @shanecrozier
                                @shanecrozier I only have one… I just deleted and reinstalled on mine and it’s working fine…
                                SO in the MMM-MLB directory make sure the icon folder is there ;)
                                  shanecrozier @cowboysdude
                                  @cowboysdude yes it is already checked that and it has all the icons in it
                                  • cowboysdudeC
                                    @shanecrozier Well I would say reinstall it because it doesn’t require npm install to run…
                                    Like I said I just downloaded it and reinstalled it and it’s working. So not really sure what’s going there as I"m not able to reproduce the issue unless the icons dir isn’t there.
                                      shanecrozier
                                      Ok will try that thanks for the help
                                      • emloweE
                                        emlowe Module Developer
                                        I made a small change to this module.
                                        If you add the following:
                                        awayTempColumn.setAttribute(“team-name”, games.away_team_name);
                                        homeTempColumn.setAttribute(“team-name”, games.home_team_name);
                                        Then you can do this in your custom.css:
                                        .MMM-MLB .awayteam[team-name=“Giants”] { color: #FB5B1F; font-weight: bold; }
                                        .MMM-MLB .hometeam[team-name=“Giants”] { color: #FB5B1F; font-weight: bold; }
                                        And now, my Giants are in Giant orange…
                                        -Earle
                                        Mykle1M 1 Reply Last reply
                                        Reply Quote 2
                                        • Mykle1M
                                          Mykle1 Project Sponsor Module Developer @emlowe
                                          @emlowe said in MMM-MLB:
                                          Go Gints!
                                          • cowboysdudeC
                                            Thank you @emlowe and from kolbyjack for his new changes which are:
                                            Center text in R/H/E columns
                                            Add team record next to team name
                                            Make status and venue text after table optional
                                            Simplify table creation by reducing code duplication
                                            Show scores from yesterday until 4pm UTC (noon EDT/9am PDT)
                                            Go to:
                                            ~MagicMirror/modules/MMM-MLB
                                            do a git pull to update :)
