    MMM-MLB
    35 Posts 10 Posters 30.6k Views 10 Watching
      jimmrr
      @cowboysdude
      Hi, i’ve tried to install this on my magicmirror running on a pi zero, the module will not load in the browser. Any ideas? I have node v6.10.0 and npm 3.10.10.
      pi@raspberrypi:~/MagicMirror $ node serveronly
      Starting MagicMirror: v2.1.0
      Loading config ...
      Loading module helpers ...
      No helper found for module: calendar_monthly.
      All module helpers loaded.
      Starting server op port 8080 ...
      Server started ...
      Connecting socket for: MMM-MLB
      Starting module: MMM-MLB
      Ready to go! Please point your browser to: http://localhost:8080
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @jimmrr
        @jimmrr i guess you use the midori browser, which cant handle es6 and this module makes use of es6 features
          Durnumosis @cowboysdude
          @cowboysdude Thank you so much for your work on this module! I was digging through the code to see how you did it and noticed there’s some code for getting the MLB standings. Is this something that you are actively working on? It would be great to see the scores as well as the standings. Thanks again for a great module!
          • cowboysdudeC Offline
            cowboysdude Module Developer @Durnumosis
            @Durnumosis Well yes I am working on that part :) I’m running into snags so it’s going to be a while… still trying to figure it all out :)
            Of course the standings is part of the voice part [MMM-voice]… I am also working on a standalone standings module… no voice required…
            • O Offline
              ooom416354
              Question guys, I have the focus_on set to “Yankees” but today they happen to be off so all I see is the header, with the MLB logo and the text MLB Scores 04/20/2017. Is there a way to hide that if the team that is set in the focus_on is not playing that day?
                cowboysdude Module Developer @ooom416354
                @ooom416354 I will have to check into that. :) It’s going to take a little while.
                • O Offline
                  ooom416354 @cowboysdude
                  @cowboysdude no problem, figured it would be a bit difficult
                    @ooom416354 Just from a time aspect :) My business is burying me right now… it’s that time of the year… ;)
                    • O Offline
                      @cowboysdude ha i know the feeling. Thanks again!
                        shanecrozier
                        It loads and shows scores and such but no logos not even MLB. Both are set to true
                        Any ideas ?
                          cowboysdude Module Developer @shanecrozier
                          @shanecrozier I only have one… I just deleted and reinstalled on mine and it’s working fine…
                          SO in the MMM-MLB directory make sure the icon folder is there ;)
                            shanecrozier @cowboysdude
                            @cowboysdude yes it is already checked that and it has all the icons in it
                              @shanecrozier Well I would say reinstall it because it doesn’t require npm install to run…
                              Like I said I just downloaded it and reinstalled it and it’s working. So not really sure what’s going there as I"m not able to reproduce the issue unless the icons dir isn’t there.
                                shanecrozier
                                Ok will try that thanks for the help
                                • emloweE Offline
                                  emlowe Module Developer
                                  I made a small change to this module.
                                  If you add the following:
                                  awayTempColumn.setAttribute(“team-name”, games.away_team_name);
                                  homeTempColumn.setAttribute(“team-name”, games.home_team_name);
                                  Then you can do this in your custom.css:
                                  .MMM-MLB .awayteam[team-name=“Giants”] { color: #FB5B1F; font-weight: bold; }
                                  .MMM-MLB .hometeam[team-name=“Giants”] { color: #FB5B1F; font-weight: bold; }
                                  And now, my Giants are in Giant orange…
                                  -Earle
                                    Mykle1 Project Sponsor Module Developer @emlowe
                                    @emlowe said in MMM-MLB:
                                    Go Gints!
                                      Thank you @emlowe and from kolbyjack for his new changes which are:
                                      Center text in R/H/E columns
                                      Add team record next to team name
                                      Make status and venue text after table optional
                                      Simplify table creation by reducing code duplication
                                      Show scores from yesterday until 4pm UTC (noon EDT/9am PDT)
                                      Go to:
                                      ~MagicMirror/modules/MMM-MLB
                                      do a git pull to update :)
                                        Description:
                                        [Thanks to kolbyjack!!! - His changes]
                                        • Create individual widget types for pregame, ingame, postgame, postponed game, and no game
                                        • Pregame: Show start time and propable pitchers
                                        • In game: Show inning state, runners on base, count, outs, pitcher, and batter
                                        • Postgame: Show R/H/E, winning pitcher, losing pitcher, and save pitcher
                                        • Postponed game: Show reason for postponing (if known)
                                        • No game: Explicitly show that the focus_on team doesn’t have a game today
                                        Screenshots:
                                        Download:
                                        [card:cowboysdude/MMM-MLB]
                                        Version 1.0.8
                                          @cowboysdude said in MMM-MLB:
                                          kolbyjack
                                          Kudos to you for the module and kolbyjack for his input.
                                          • W Offline
                                            wishsolotion
                                            Damn, this is a cool module! I’m building an MM Sports computer for someone as a gift and this is already . I don’t know how you geniuses do it, however I’m happy you do. I tip my hat to you, sir, and I thanks for sharing this high-quality advent of yours. 👏🏼
