    MMM-GQuotes
    62 Posts 5 Posters 67.0k Views 6 Watching
      pauabaer
      @Mykle1 said in MMM-GQuotes:
      As did I.
      Me too.
      • FistandantilusF Offline
        Fistandantilus
        @cowboysdude: this is exactly the procedure I was following. Could it probably be caused by some shared ressources with another module?
        The following modules are installed:
        iFrame
        MMM-FHEM
        MMM-nasaastropic
        MMM-SystemStats
        MMM-iCloud-Client
        MMM-RadioDe
        MMM-GQuotes
        F.
          Fistandantilus
          Just tested with only GQuotes activated - screen stays black.
          The following error shows up:
          • cowboysdudeC Offline
            cowboysdude Module Developer @Fistandantilus
            @Fistandantilus I can’t begin to imagine what the issue is. You’re the only one having it. Three of us have uninstalled and reinstalled the module and no one is getting any errors.
            There is the module running with other modules and my developers window… no errors.
            So unless it’s conflicting with another module I don’t have an answer for you.
              Fistandantilus
              I´m using a RPi 2 B+ with the latest Jessie release. In addidion to MM2 I have installed midnight commander, x11vnc, cec-utils and xscreensaver.
              Does the error give any hint what I could look at?
                No that error is a MM error… Cannot read property ‘appendChild’ of undefined and ‘getElementByClassName’ of null…
                It’s a getDom function error but like I said unless there’s a conflict of some type… do me a favor and open the ‘package.json’ file you have with GQuotes and tell me what the dependencies say…
                  Fistandantilus
                  "qs-iconv": "^1.0.4",
                  "request": "^2.81.0",
                  "xml2js": "^0.4.17"
                    OK that looks good… you have the newest version…
                    What I would do is run GQuotes and disable all the other modules… and enable one at a time until you get a conflict… that may go a long way to helping figure out what’s wrong here.
                      Fistandantilus
                      That is what I already did. Just running GQuote itself without other modules also shows the mentioned error.
                        Fistandantilus
                        Just run a “npm outdated” with the following result:
                        Package Current Wanted Latest Location
                        electron 1.6.6 1.6.8 1.6.6 magicmirror
                        grunt-markdownlint 1.0.33 1.0.37 1.0.37 magicmirror
                        iconv-lite 0.4.16 0.4.17 0.4.17 magicmirror
                          @Fistandantilus said in MMM-GQuotes:
                          qs-iconv
                          Yes but if you go into the MMM-GQuote dir and run “npm outdated” it returns nothing… soooooo that’s not the issue…
                          iconv-lite only appears when you run it from the MagicMirror root dir…
                          Which means GQuotes is using all the latest version of npm modules…
                          This is my config:
                          module: ‘MMM-GQuotes’,
                          position: ‘top_left’,
                          maxWidth: “100%”,
                          header: “Zitat des Tages”,
                          I cannot find anything wrong with the module that would cause that error.
                            Fistandantilus
                            Same as my config:
                            position: ‘top_right’,
                            maxWidth: “100%”,
                            Maybe we find some other users for testing. Cannot imagine that I´am the only one…
                            cowboysdudeC Mykle1M 2 Replies Last reply Reply Quote 0
                              @Fistandantilus So far you are the only one… if you look above there are others testing it… they are having no issues either…
                                Mykle1 Project Sponsor Module Developer @Fistandantilus
                                I don’t see anything wrong with this module. It does not report any errors in the console or the terminal. It does not affect other modules. See my picture below. GQuotes is running happily in between two other modules. Perhaps there was some failure in your install of MM, or the Pi you are using. Have you changed any of the system or module files?
                                  Fistandantilus
                                  Hi guys,
                                  I just found the reason that was causing the error. There was a typo in the position in the config :face_palm:
                                  Sorry for causing such trouble! Now it is working like a charm :)
                                  F.
                                    pauabaer
                                    That’s good @Fistandantilus :))
                                    @cowboysdude i noticed today, that the quote did not updated. Any suggestion why?
                                      Wow . . . and . . . wow
                                        @Fistandantilus LOL well it happens…
                                          pauabaer
                                          hi @cowboysdude
                                          at which time does the quotes getting updated? does it change at a specific time? depends this time on your timezone?
                                          every morning (CEST) i see the same quote like in the evening. at the homepage it is getting updated at 02.00 a.m. that would be nice if your module is getting updated at the same time. so i see each morning the new quote.
                                          is this possible?
                                            cowboysdude Module Developer @pauabaer
                                            @pauabaer It checks the date on the file…
                                            • 3 / 4
