Error installing the magicmirror
691 verbose lifecycle electron@1.6.8~postinstall: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/electron/node_modules/.bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games 692 verbose lifecycle electron@1.6.8~postinstall: CWD: /home/pi/MagicMirror/node_modules/electron 693 silly lifecycle electron@1.6.8~postinstall: Args: [ '-c', 'node install.js' ] 694 silly lifecycle electron@1.6.8~postinstall: Returned: code: 1 signal: null 695 info lifecycle electron@1.6.8~postinstall: Failed to exec postinstall script 696 verbose unlock done using /home/pi/.npm/_locks/staging-f4a655787a5bf4d3.lock for /home/pi/MagicMirror/node_modules/.staging 697 silly rollbackFailedOptional Starting 698 silly rollbackFailedOptional Finishing 699 silly runTopLevelLifecycles Finishing 700 silly install printInstalled 701 warn grunt-stylelint@0.8.0 requires a peer of stylelint@^7.8.0 but none was installed. 702 verbose If you need help, you may report this error at: 702 verbose <https://github.com/npm/npm/issues> 703 warn stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none was installed. 704 verbose If you need help, you may report this error at: 704 verbose <https://github.com/npm/npm/issues> 705 verbose stack Error: electron@1.6.8 postinstall: `node install.js` 705 verbose stack Exit status 1 705 verbose stack at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16) 705 verbose stack at emitTwo (events.js:106:13) 705 verbose stack at EventEmitter.emit (events.js:191:7) 705 verbose stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14) 705 verbose stack at emitTwo (events.js:106:13) 705 verbose stack at ChildProcess.emit (events.js:191:7) 705 verbose stack at maybeClose (internal/child_process.js:886:16) 705 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5) 706 verbose pkgid electron@1.6.8 707 verbose cwd /home/pi/MagicMirror 708 error Linux 4.4.21-v7+ 709 error argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "electron" 710 error node v6.10.3 711 error npm v3.10.10 712 error code ELIFECYCLE 713 error electron@1.6.8 postinstall: `node install.js` 713 error Exit status 1 714 error Failed at the electron@1.6.8 postinstall script 'node install.js'. 714 error Make sure you have the latest version of node.js and npm installed. 714 error If you do, this is most likely a problem with the electron package, 714 error not with npm itself. 714 error Tell the author that this fails on your system: 714 error node install.js 714 error You can get information on how to open an issue for this project with: 714 error npm bugs electron 714 error Or if that isn't available, you can get their info via: 714 error npm owner ls electron 714 error There is likely additional logging output above. 715 verbose exit [ 1, true ]Having error installing the magic mirror and getting it to run… some help would greatly be appreciated!
Thanks!
@jubeenshah said in Error installing the magicmirror:
@Jakllo
I initially had that problem too - you need to be logged in as PI - not root.
I’d suggest starting all over: it really wont take that long. Follow the
tutorial @strawberry-3-141 mentioned (https://forum.magicmirror.builders/topic/236/complete-setup-tutorial) to the letter. It was written by @KirAsh4 & made all of my problem go away. I have now done it 4 times, getting it done in less than an hour from unpacking to having it all run!My raspberry all of a sudden even connected via WiFi, and I am expecting my hair to grow back any day now.
I’m telling you - pure magic, these guys.
All the best
@cowboysdude Thanks a lot! I’ll try that and let you know about how it turns about!
@cowboysdude I tried again following the steps… but then in the end it again showed me errors regarding installing dependencies…
I believe two in particular…
npm WARN prefer global coffee-script@1.10.0 should be installed with -g npm WARN prefer global jsonlite@1.6.2 should be installed with -g > electron-chromedriver@1.7.1 install/jome/pi/MagicMirror/node_modules/electron-chromedriver > node ./download-chromedriver.js -
> magicmirror@2.1.1 start /home/pi/MagicMirror > sh run-start.sh /home/pi/MagicMirror/node_modules/electron/index.js:9 throw new Error('Electron failed to install correctly, please delete node_modules/electron and try installing again') ^ Error: Electron failed to install correctly, please delete node_modules/electron and try installing again at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:9:9) at Module._compile (module.js:570:32) at Object.Module._extensions..js (module.js:579:10) at Module.load (module.js:487:32) at tryModuleLoad (module.js:446:12) at Function.Module._load (module.js:438:3) at Module.require (module.js:497:17) at require (internal/module.js:20:19) at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16) at Module._compile (module.js:570:32) npm ERR! code ELIFECYCLE npm ERR! errno 1 npm ERR! magicmirror@2.1.1 start: `sh run-start.sh` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the magicmirror@2.1.1 start script. npm ERR! This is probably not a problem with npm. There is likely additional logging output above. npm ERR! A complete log of this run can be found in: npm ERR! /home/pi/.npm/_logs/2017-05-18T13_11_39_986Z-debug.log -
@cowboysdude Nevermind bro… I solved it on my own and it worked out… Thanksss a lot brother
@jubeenshah Glad you got it.
Perhaps you’ll post how you solved the issue so others might benefit if they have the same issue. :-)
