Error installing the magicmirror
8 Posts 3 Posters 4.5k Views 3 Watching
    jubeenshah
    691 verbose lifecycle electron@1.6.8~postinstall: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/electron/node_modules/.bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
    692 verbose lifecycle electron@1.6.8~postinstall: CWD: /home/pi/MagicMirror/node_modules/electron
    693 silly lifecycle electron@1.6.8~postinstall: Args: [ '-c', 'node install.js' ]
    694 silly lifecycle electron@1.6.8~postinstall: Returned: code: 1  signal: null
    695 info lifecycle electron@1.6.8~postinstall: Failed to exec postinstall script
    696 verbose unlock done using /home/pi/.npm/_locks/staging-f4a655787a5bf4d3.lock for /home/pi/MagicMirror/node_modules/.staging
    697 silly rollbackFailedOptional Starting
    698 silly rollbackFailedOptional Finishing
    699 silly runTopLevelLifecycles Finishing
    700 silly install printInstalled
    701 warn grunt-stylelint@0.8.0 requires a peer of stylelint@^7.8.0 but none was installed.
    702 verbose If you need help, you may report this error at:
    702 verbose     <https://github.com/npm/npm/issues>
    703 warn stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none was installed.
    704 verbose If you need help, you may report this error at:
    704 verbose     <https://github.com/npm/npm/issues>
    705 verbose stack Error: electron@1.6.8 postinstall: `node install.js`
    705 verbose stack Exit status 1
    705 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
    705 verbose stack     at emitTwo (events.js:106:13)
    705 verbose stack     at EventEmitter.emit (events.js:191:7)
    705 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
    705 verbose stack     at ChildProcess.emit (events.js:191:7)
    705 verbose stack     at maybeClose (internal/child_process.js:886:16)
    705 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
    706 verbose pkgid electron@1.6.8
    707 verbose cwd /home/pi/MagicMirror
    708 error Linux 4.4.21-v7+
    709 error argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "electron"
    710 error node v6.10.3
    711 error npm  v3.10.10
    712 error code ELIFECYCLE
    713 error electron@1.6.8 postinstall: `node install.js`
    713 error Exit status 1
    714 error Failed at the electron@1.6.8 postinstall script 'node install.js'.
    714 error Make sure you have the latest version of node.js and npm installed.
    714 error If you do, this is most likely a problem with the electron package,
    714 error not with npm itself.
    714 error Tell the author that this fails on your system:
    714 error     node install.js
    714 error You can get information on how to open an issue for this project with:
    714 error     npm bugs electron
    714 error Or if that isn't available, you can get their info via:
    714 error     npm owner ls electron
    714 error There is likely additional logging output above.
    715 verbose exit [ 1, true ]
    Having error installing the magic mirror and getting it to run… some help would greatly be appreciated!
    Thanks!
      @jubeenshah said in Error installing the magicmirror:
      @Jakllo
      I initially had that problem too - you need to be logged in as PI - not root.
      I’d suggest starting all over: it really wont take that long. Follow the
      tutorial @strawberry-3-141 mentioned (https://forum.magicmirror.builders/topic/236/complete-setup-tutorial) to the letter. It was written by @KirAsh4 & made all of my problem go away. I have now done it 4 times, getting it done in less than an hour from unpacking to having it all run!
      My raspberry all of a sudden even connected via WiFi, and I am expecting my hair to grow back any day now.
      I’m telling you - pure magic, these guys.
      All the best
      J 4 Replies Last reply May 18, 2017, 7:23 AM Reply Quote 2
        jubeenshah @cowboysdude
        @cowboysdude Thanks a lot! I’ll try that and let you know about how it turns about!
          @cowboysdude I tried again following the steps… but then in the end it again showed me errors regarding installing dependencies…
          I believe two in particular…
          npm WARN prefer global coffee-script@1.10.0 should be installed with -g
          npm WARN prefer global jsonlite@1.6.2 should be installed with -g
          > electron-chromedriver@1.7.1 install/jome/pi/MagicMirror/node_modules/electron-chromedriver
          > node ./download-chromedriver.js
            @cowboysdude
            > magicmirror@2.1.1 start /home/pi/MagicMirror
            > sh run-start.sh
            /home/pi/MagicMirror/node_modules/electron/index.js:9
              throw new Error('Electron failed to install correctly, please delete node_modules/electron and try installing again')
            Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
                at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:9:9)
                at Module._compile (module.js:570:32)
                at Object.Module._extensions..js (module.js:579:10)
                at Module.load (module.js:487:32)
                at tryModuleLoad (module.js:446:12)
                at Function.Module._load (module.js:438:3)
                at Module.require (module.js:497:17)
                at require (internal/module.js:20:19)
                at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
            npm ERR! code ELIFECYCLE
            npm ERR! errno 1
            npm ERR! magicmirror@2.1.1 start: `sh run-start.sh`
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the magicmirror@2.1.1 start script.
            npm ERR!     /home/pi/.npm/_logs/2017-05-18T13_11_39_986Z-debug.log
              @cowboysdude Nevermind bro… I solved it on my own and it worked out… Thanksss a lot brother
              C M 2 Replies Last reply May 18, 2017, 5:12 PM Reply Quote 1
                cowboysdude Module Developer @jubeenshah
                @jubeenshah Glad you got it.
                  Mykle1 Project Sponsor Module Developer @jubeenshah
                  Perhaps you’ll post how you solved the issue so others might benefit if they have the same issue. :-)
