    I wish there was a module that would show local events...
    19 Posts 3 Posters 10.5k Views 3 Watching
    • joela85J Offline
      joela85
      That looks spot on. I think I’ll be adding that module later.
      Requesting an API key, what do you put in the “Application URL” box etc
        Mykle1 Project Sponsor Module Developer @joela85
        @joela85 said in I wish there was a module that would show local events...:
        You can just use the url of this forum.
        https://forum.magicmirror.builders/
          @cowboysdude said in I wish there was a module that would show local events...:
          https://github.com/mykle1/MMM-Events
          Oh, no you d’int! You old some beach! ;-)
          Well, seeing as you wished for it, and seeing as you forced my hand, here it is.
          https://forum.magicmirror.builders/topic/2628/mmm-events
            Shameless plug.
            • cowboysdudeC Offline
              @Mykle1 said in I wish there was a module that would show local events...:
              Shameless plug.
              NO such thing… LOL
              • joela85J Offline
                joela85
                Tried to get this working, only showing “Upcoming Events…” text on the mirror.
                This is my config, can you see why it might not be loading any events?
                                    module: 'MMM-Events',
                                    position: 'bottom_left',
                                        city: "Leamington Spa, United Kingdom",            // Your City
                                        eventType: "music, comedy, performing_arts, sports, food, food_beer, outdoors_recreation",                 // Choose from Events List below
                                        when: "Future",                 // "All", "Future", "Past", "Today", "Last Week", "This Week", "Next week", and months by name, e.g. "October"
                                        mode: "noFrame",                   // "Frame" or "noFrame" (around picture)
                                        apikey: "verified_api",
                                        rotateInterval: 2 * 60 * 1000,     // New Event Appears every 2 minutes
                                        useHeader: false,                  // Set to true if you want a header
                                        header: "",
                                        animationSpeed: 3000,              // Event fades in and out
                                        picture: true,                     // true, false = no image
                Mykle1M 3 Replies Last reply Reply Quote 0
                                      position: 'top_left',
                                          city: "Leamington, England",            // Your City
                                          eventType: "music",                 // Choose from Events List below
                                          apikey: "YOUR API KEY",
                                          header: "",
                  This will work. More info to follow shortly . . .
                    You can only choose one eventType at a time. I’ll look into multiple entries when I have the time to do so. With Leamington as your city, there is limited data from the API, especially the pictures. If you choose a larger city nearby, say Birmingham, you will have much better results, as the data is more prevalent.
                    Leamington does return events, but if you don’t like the fallback picture appearing so often (it does that when the API returns no picture) you can choose picture: false, in the config.
                    Please let me know how you like the module.
                      The above two posts should get you up and running
                        @joela85
                        0_1495903654061_Capture21.JPG .0_1495903672132_Capture33.JPG .0_1495903692329_Capture44.JPG
                        As you can see, the data from the API for Leamington uses the fallback picture quite often
                        • joela85J Offline
                          joela85
                          Ah, that’s great thanks. I was wondering if multiple events were causing that. It would be great to have a few multiple event types. Ye, there aren’t many events in Leamington itself. Can you put a distance radius around your home post code?
                          Thank you for your help, great little module.
                          • joela85J Offline
                            joela85
                            Is there also a way to show the date of the event in dd-mm-yy format? instead of yyyy-dd-mm?
                              cowboysdude Module Developer @joela85
                              @joela85 LOL I’m looking at the pictures I’m not seeing it as yyyy-dd-mm… I"m seeing mm/dd/yyyy.
                                I don’t have any plans to reformat the date. If I change it then undoubtedly, someone will want it the way it was.
                                I’ll get back to you on that. I don’t even think it will require editing the module.
                                Ye, there aren’t many events in Leamington itself. Can >you put a distance radius around your home post code?
                                Not at the moment. Cities are the best route right now. If you want to extend a radius around your post code then you can just choose the nearest major city.
                                You’re welcome, and thank you.
                                  Ok, so, your config entry for eventType was not incorrect. You had it formatted correctly, categories separated by commas, all within a single pair of quotes.
                                  Caveat: The module GET’s 50 events per updateInterval. If the first category in eventType has 50 or more events, you may never see the secondary categories appear. The module does not, for example, GET 10 events from each of the categories.
                                  • joela85J Offline
                                    joela85
                                    Ah ok, so could put them in preference order then. My dates now appear in dd-mm-yyyy format. Could be doing that on location basis.
