    I wish there was a module that would show local events...
    19 Posts 3 Posters 9.9k Views 3 Watching
      Shameless plug.
      • cowboysdudeC Offline
        @Mykle1 said in I wish there was a module that would show local events...:
        Shameless plug.
        NO such thing… LOL
        • joela85J Offline
          joela85
          Tried to get this working, only showing “Upcoming Events…” text on the mirror.
          This is my config, can you see why it might not be loading any events?
                              module: 'MMM-Events',
                              position: 'bottom_left',
                                  city: "Leamington Spa, United Kingdom",            // Your City
                                  eventType: "music, comedy, performing_arts, sports, food, food_beer, outdoors_recreation",                 // Choose from Events List below
                                  when: "Future",                 // "All", "Future", "Past", "Today", "Last Week", "This Week", "Next week", and months by name, e.g. "October"
                                  mode: "noFrame",                   // "Frame" or "noFrame" (around picture)
                                  apikey: "verified_api",
                                  rotateInterval: 2 * 60 * 1000,     // New Event Appears every 2 minutes
                                  useHeader: false,                  // Set to true if you want a header
                                  header: "",
                                  animationSpeed: 3000,              // Event fades in and out
                                  picture: true,                     // true, false = no image
          Mykle1M 3 Replies Last reply Reply Quote 0
            Mykle1 Project Sponsor Module Developer @joela85
                                position: 'top_left',
                                    city: "Leamington, England",            // Your City
                                    eventType: "music",                 // Choose from Events List below
                                    apikey: "YOUR API KEY",
                                    header: "",
            This will work. More info to follow shortly . . .
              You can only choose one eventType at a time. I’ll look into multiple entries when I have the time to do so. With Leamington as your city, there is limited data from the API, especially the pictures. If you choose a larger city nearby, say Birmingham, you will have much better results, as the data is more prevalent.
              Leamington does return events, but if you don’t like the fallback picture appearing so often (it does that when the API returns no picture) you can choose picture: false, in the config.
              Please let me know how you like the module.
                @joela85 said in I wish there was a module that would show local events...:
                The above two posts should get you up and running
                  @joela85
                  0_1495903654061_Capture21.JPG .0_1495903672132_Capture33.JPG .0_1495903692329_Capture44.JPG
                  As you can see, the data from the API for Leamington uses the fallback picture quite often
                  • joela85J Offline
                    joela85
                    Ah, that’s great thanks. I was wondering if multiple events were causing that. It would be great to have a few multiple event types. Ye, there aren’t many events in Leamington itself. Can you put a distance radius around your home post code?
                    Thank you for your help, great little module.
                    • joela85J Offline
                      joela85
                      Is there also a way to show the date of the event in dd-mm-yy format? instead of yyyy-dd-mm?
                        cowboysdude Module Developer @joela85
                        @joela85 LOL I’m looking at the pictures I’m not seeing it as yyyy-dd-mm… I"m seeing mm/dd/yyyy.
                          I don’t have any plans to reformat the date. If I change it then undoubtedly, someone will want it the way it was.
                          I’ll get back to you on that. I don’t even think it will require editing the module.
                          Ye, there aren’t many events in Leamington itself. Can >you put a distance radius around your home post code?
                          Not at the moment. Cities are the best route right now. If you want to extend a radius around your post code then you can just choose the nearest major city.
                          You’re welcome, and thank you.
                            Ok, so, your config entry for eventType was not incorrect. You had it formatted correctly, categories separated by commas, all within a single pair of quotes.
                            Caveat: The module GET’s 50 events per updateInterval. If the first category in eventType has 50 or more events, you may never see the secondary categories appear. The module does not, for example, GET 10 events from each of the categories.
                            • joela85J Offline
                              joela85
                              Ah ok, so could put them in preference order then. My dates now appear in dd-mm-yyyy format. Could be doing that on location basis.
