    27" custom framed magic mirror - fun to get done
    41 Posts 13 Posters 76.5k Views 17 Watching
      Jayh391
      I would like to know how you brought your Homeseer info in?
      Jay
      I 1 Reply Last reply
      • zdenekZ
        zdenek @iwaldrum
        @iwaldrum MMM-SimpleLogo - pulls updated radar image from wundergound - can u plz share details? What´s exactly in the config?
        thanks, Zdeněk
        • I
          iwaldrum @pepemujica
          @pepemujica
          Here are some additional pics… The back isn’t the prettiest, but it does the job. Used painters tape, L brackets and velcro to keep everything in place.
          0_1496222337049_IMG_1961.JPG 0_1496222343783_IMG_2065.JPG 0_1496222351990_IMG_2788.JPG 0_1496222360052_IMG_2866.JPG 0_1496222364276_IMG_2867.JPG
          • I
            iwaldrum @Jayh391
            @Jayh391
            I used the MMM-Rest module to pull the device data via the rest api in Homeseer. Here is the section in my config file. Still work in progress…
            		module: 'MMM-Rest',
            		header: 'House Status',
            		position: 'top_right',	// This can be any of the regions.
            									// Best results in one of the side regions like: top_left
                            debug: false,
                            mappings: {
                                on_off: {
                                    true: 'on',
                                    false: 'off',
                                temperature: {
                                    1: 'cold',
                                    2: 'warm',
                                    3: 'HOT',
                            sections: [
                                format: '%d',
                                url: 'http://yourURLhere:port/HomeSeer_REST_API.aspx?function=getdevicestatusvaluebyid¶m1=108¶m2=value',
                                format: '%df',
                                url: 'http://yourURLhere:port/HomeSeer_REST_API.aspx?function=getdevicestatusvaluebyid¶m1=103¶m2=value',
                                format: '%d',
                                url: 'http://yourURLhere:port/HomeSeer_REST_API.aspx?function=getdevicestatusvaluebyid¶m1=128¶m2=value',
                                format: '%df',
                                url: 'http://yourURLhere:port/HomeSeer_REST_API.aspx?function=getdevicestatusvaluebyid¶m1=187¶m2=value',
                                format: '%d',
                                url: 'http://yourURLhere:port/HomeSeer_REST_API.aspx?function=getdevicestatusvaluebyid¶m1=118¶m2=value',
                                format: '%df',
                                url: 'http://http://yourURLhere:port/HomeSeer_REST_API.aspx?function=getdevicestatusvaluebyid¶m1=113¶m2=value',
                                format: '%df',
                                url: 'http://yourURLhere:port/HomeSeer_REST_API.aspx?function=getdevicestatusvaluebyid¶m1=92¶m2=value',
                                format: '%s',
                                mapping: 'temperature',
            		    url: 'http://yourURLhere:port/HomeSeer_REST_API.aspx?function=getdevicestatusvaluebyid¶m1=137¶m2=value',
                                format: '%d',
                                format: 'Lights %s',
                                mapping: 'on_off',
                        output: [
                            ['<b>Location:</b>',,'<b>Temp:</b>'],
                            ['Family Room',,'@2'],
                            ['Living Room','@6'],
                            ['Upstairs','@4'],
                            ['Garage','@7'],
            J 1 Reply Last reply
            • I
              iwaldrum @zdenek
              @zdenek
              I used wunderground.com to create the animated radar image and MMM-SimpleLogo to display it.
              Create your custom image at https://www.wunderground.com/weather-radar - looks like US, Canda & Australia only. Once created, copy the URL and place it in the MMM-SimpleLogo module.
              Wunderground updates the radar image every 10-20 minutes. Since I’m using FullpageOS as my mm frontend I have the page refresh every 30 minutes which then pulls an updated image.
                      module: 'MMM-SimpleLogo',
              		fileUrl: "https://radblast.wunderground.com/cgi-bin/radar/WUNIDS_map?station=DIX&brand=wui&num=1&delay=15&type=N0R&frame=0&scale=1.000&noclutter=0&showstorms=0&mapx=400&mapy=240¢erx=400¢ery=240&transx=0&transy=0&showlabels=1&severe=0&rainsnow=0&lightning=0&smooth=0&rand=24937062&lat=40.75000000&lon=-74.00000000&label=New+York%2C+NY",
              		width: "400px",
              		position: "center",
              C zdenekZ 2 Replies Last reply
                cmille34 @iwaldrum
                @iwaldrum said in [27" custom framed magic mirror - fun to get done] Since I’m using FullpageOS as my mm frontend I have the page refresh every 30 minutes which then pulls an updated image.
                How is you have the page reload every 30 mins in fullpageOS? My calendar app doesn’t appear to be updating, I’m hoping a page reload every 30 mins will fix that.
                • I
                  iwaldrum @cmille34
                  @cmille34
                  There is a refresh script included with fullpageOS. it’s located at /home/pi/scripts/refresh. I added it to the crontab to run every 30min. I also added a line to crontab to reboot at midnight. This helps keep the system fresh and free up any processes or used memory on the Pi.
                  Here is my config
                  sudo nano /etc/crontab
                  Add:
                  0  0    * * *   root    reboot
                  */30 *   * * *   pi     /home/pi/scripts/refresh
                    cmille34 @iwaldrum
                    @iwaldrum said in 27" custom framed magic mirror - fun to get done:
                    Add:
                    Brilliant! I forgot I was calling that script when I woke the screen with the motion sensor
                    already. Hopefully adding it to cron every 30 minutes like you’ve shown will help get the calendar to update more regularly. Thanks for the quick help!
                    • I
                      iwaldrum @cmille34
                      @cmille34
                      I’d love to hear how you have your motion sensor setup with fullpageOS. On my todo list…
                      C 1 Reply Last reply
                        cmille34 @iwaldrum
                        @cmille34
                        This is far from perfect but it appears to work for me. Generally the screen is dim when I look at the mirror from afar or an angle but if I walk near it, it comes to life. I’m using the cheapie ol’ HC-SR501 motion sensor for this. I think I got a 5 pack for like 5 bucks on eBay. I actually have my sensor dangling at the bottom of my mirror, essentially aiming at the floor. These things are pretty darn sensitive it seems.
                        I essentially have the sensor hooked up to the Pi and and have converted the following Python script to a service that runs at startup. The monitor still has power but the HDMI signal is essentially disabled when motion isn’t detected with the tvservice command (whatever it is! ha).
                        /home/pi/motiondetector.py
                        import os
                        import subprocess
                        import time
                        from gpiozero import MotionSensor
                        pir = MotionSensor(4)
                        while True:
                                pir.wait_for_motion()
                                print("Motion!")
                                subprocess.call(["/bin/sh","/home/pi/scripts/refresh"])
                                os.system("tvservice -p; fbset -depth 8; fbset -depth 16")
                                pir.wait_for_no_motion()
                                print("No motion...")
                                os.system("tvservice -o")
                        The sources I used to cobble this together:
                        Install gpiozero
                        https://gpiozero.readthedocs.io/en/stable/
                        I think I had some issue getting the gpiozero module to load, but this thread looks familiar. I think the issue is I started with Jessie Lite.
                        https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=126320
                        Script as service
                        http://www.diegoacuna.me/how-to-run-a-script-as-a-service-in-raspberry-pi-raspbian-jessie/
                        Sensitivity Adjustment (this takes some tinkering for sure)
                        http://henrysbench.capnfatz.com/henrys-bench/arduino-sensors-and-input/arduino-hc-sr501-motion-sensor-tutorial/
                        You could probably gather all this with a few minutes of googling but I figured I’d share what I’ve cobbled together so far. A short range IR type sensor may be better if you only want the screen to activate when you get right in front of it, if you just want some mostly automated way of turning the screen off, this should work though.
                          Jayh391 @iwaldrum
                          @iwaldrum
                          Thanks ! I will give it a try!
                          • zdenekZ
                            zdenek @iwaldrum
                            @iwaldrum great, thanks. I’ll try. Any idea, how to refresh on “basic” Jess OS? Via cron? How?
                            unfortunately, on https://www.wunderground.com/weather-radar is just for US and so on, but Europe is not here. Please, any idea, how to add this
                            http://portal.chmi.cz/files/portal/docs/meteo/rad/data_jsradview.html
                            or better this
                            http://portal.chmi.cz/files/portal/docs/meteo/rad/inca-cz/short.html
                            in the worst scenario
                            http://portal.chmi.cz/files/portal/docs/meteo/rad/mobile/ra6_30min.gif
                            thanks, Zdeněk
                              Jayh391 @Jayh391
                              @Jayh391
                              Worked GREAT!
                              • zdenekZ
                                zdenek @iwaldrum
                                @iwaldrum can u pls share refres script? Maybe I can use it with Jessie
                                thanks, Zdenek
                                • I
                                  iwaldrum @zdenek
                                  @zdenek
                                  This is the refresh script included with FullpageOS. Not sure if you need anything else to be able to run it.
                                  #!/bin/bash
                                  export DISPLAY=:0
                                  WID=$(xdotool search --onlyvisible --class chromium|head -1)
                                  xdotool windowactivate ${WID}
                                  xdotool key ctrl+F5
                                  xdotool key F11
                                  zdenekZ 1 Reply Last reply
                                  • zdenekZ
                                    zdenek @iwaldrum
                                    @iwaldrum stupid question - what extension should have the file “refresh”?
                                    • I
                                      iwaldrum @zdenek
                                      @zdenek The script included doesn’t have an extension. If that doesn’t work for you try adding the extension of .sh
                                        shbatm Module Developer @disakos
                                        @disakos I just posted a module for pulling an RTSP Stream from my Hikvision Cameras. Check it out here:
                                        [card:shbatm/MMM-RTSPStream]
                                        Reply Quote 2
                                        • zdenekZ
                                          zdenek @iwaldrum
                                          @iwaldrum so, I’ve installed xdotools, created script, but it doesn’t do anything… :-(
                                            PaulB
                                            Dear @iwaldrum ,
                                            this is such a cool set-up. Well done! :)
                                            • 2 / 3
