    27" custom framed magic mirror - fun to get done
    41 Posts 13 Posters 70.2k Views 17 Watching
    • W Offline
      wbleek @cmille34
      @cmille34 Hey, thanks for your answer. I appreciate that. My NVR only provides still JPEGs or RTSP for pictures. If I use JPEGs I have to reload them in a 200ms interval to achieve acceptable motion.
      At this point, I have tried the following:
      1. uses MMM-iFrame
      • do the reload via embedded HTML meta-tag
      • strong flickers (approx. half of the time blank)
      • works, but not visually accaptable
      • does not scale due to the flickering
      1. use MMM-iFrame
      • do the reload via embedded Java-Script function
      • almost no flicker, almost fluid motion
      • works for 30-60 minutes, then the module stops
      • does not scale since it stops earlier with more modules
      1. use oxmplayer as an overlay
      • needs '–avdict rtsp_transport:tcp ’ switches to work without banding
      • rtsp with 640x360 works with 30fps
      • tested to concurrent streams
      I am happy with the omxplayer solution even though it is not integrated in the MagicMirror. But for the user it looks integrated and it delivery a very good video quality.
      Cheers
      wolf
        Jayh391
        I would like to know how you brought your Homeseer info in?
        Jay
        I 1 Reply Last reply Reply Quote 1
        • zdenekZ Offline
          zdenek @iwaldrum
          @iwaldrum MMM-SimpleLogo - pulls updated radar image from wundergound - can u plz share details? What´s exactly in the config?
          thanks, Zdeněk
          • I Offline
            iwaldrum @pepemujica
            @pepemujica
            Here are some additional pics… The back isn’t the prettiest, but it does the job. Used painters tape, L brackets and velcro to keep everything in place.
            0_1496222337049_IMG_1961.JPG 0_1496222343783_IMG_2065.JPG 0_1496222351990_IMG_2788.JPG 0_1496222360052_IMG_2866.JPG 0_1496222364276_IMG_2867.JPG
            • I Offline
              iwaldrum @Jayh391
              @Jayh391
              I used the MMM-Rest module to pull the device data via the rest api in Homeseer. Here is the section in my config file. Still work in progress…
              		module: 'MMM-Rest',
              		header: 'House Status',
              		position: 'top_right',	// This can be any of the regions.
              									// Best results in one of the side regions like: top_left
                              debug: false,
                              mappings: {
                                  on_off: {
                                      true: 'on',
                                      false: 'off',
                                  temperature: {
                                      1: 'cold',
                                      2: 'warm',
                                      3: 'HOT',
                              sections: [
                                  format: '%d',
                                  url: 'http://yourURLhere:port/HomeSeer_REST_API.aspx?function=getdevicestatusvaluebyid¶m1=108¶m2=value',
                                  format: '%df',
                                  url: 'http://yourURLhere:port/HomeSeer_REST_API.aspx?function=getdevicestatusvaluebyid¶m1=103¶m2=value',
                                  format: '%d',
                                  url: 'http://yourURLhere:port/HomeSeer_REST_API.aspx?function=getdevicestatusvaluebyid¶m1=128¶m2=value',
                                  format: '%df',
                                  url: 'http://yourURLhere:port/HomeSeer_REST_API.aspx?function=getdevicestatusvaluebyid¶m1=187¶m2=value',
                                  format: '%d',
                                  url: 'http://yourURLhere:port/HomeSeer_REST_API.aspx?function=getdevicestatusvaluebyid¶m1=118¶m2=value',
                                  format: '%df',
                                  url: 'http://http://yourURLhere:port/HomeSeer_REST_API.aspx?function=getdevicestatusvaluebyid¶m1=113¶m2=value',
                                  format: '%df',
                                  url: 'http://yourURLhere:port/HomeSeer_REST_API.aspx?function=getdevicestatusvaluebyid¶m1=92¶m2=value',
                                  format: '%s',
                                  mapping: 'temperature',
              		    url: 'http://yourURLhere:port/HomeSeer_REST_API.aspx?function=getdevicestatusvaluebyid¶m1=137¶m2=value',
                                  format: '%d',
                                  format: 'Lights %s',
                                  mapping: 'on_off',
                          output: [
                              ['<b>Location:</b>',,'<b>Temp:</b>'],
                              ['Family Room',,'@2'],
                              ['Living Room','@6'],
                              ['Upstairs','@4'],
                              ['Garage','@7'],
              • I Offline
                iwaldrum @zdenek
                @zdenek
                I used wunderground.com to create the animated radar image and MMM-SimpleLogo to display it.
                Create your custom image at https://www.wunderground.com/weather-radar - looks like US, Canda & Australia only. Once created, copy the URL and place it in the MMM-SimpleLogo module.
                Wunderground updates the radar image every 10-20 minutes. Since I’m using FullpageOS as my mm frontend I have the page refresh every 30 minutes which then pulls an updated image.
                        module: 'MMM-SimpleLogo',
                		fileUrl: "https://radblast.wunderground.com/cgi-bin/radar/WUNIDS_map?station=DIX&brand=wui&num=1&delay=15&type=N0R&frame=0&scale=1.000&noclutter=0&showstorms=0&mapx=400&mapy=240¢erx=400¢ery=240&transx=0&transy=0&showlabels=1&severe=0&rainsnow=0&lightning=0&smooth=0&rand=24937062&lat=40.75000000&lon=-74.00000000&label=New+York%2C+NY",
                		width: "400px",
                		position: "center",
                C zdenekZ 2 Replies Last reply Reply Quote 0
                  cmille34 @iwaldrum
                  @iwaldrum said in [27" custom framed magic mirror - fun to get done] Since I’m using FullpageOS as my mm frontend I have the page refresh every 30 minutes which then pulls an updated image.
                  How is you have the page reload every 30 mins in fullpageOS? My calendar app doesn’t appear to be updating, I’m hoping a page reload every 30 mins will fix that.
                  • I Offline
                    iwaldrum @cmille34
                    @cmille34
                    There is a refresh script included with fullpageOS. it’s located at /home/pi/scripts/refresh. I added it to the crontab to run every 30min. I also added a line to crontab to reboot at midnight. This helps keep the system fresh and free up any processes or used memory on the Pi.
                    Here is my config
                    sudo nano /etc/crontab
                    Add:
                    0  0    * * *   root    reboot
                    */30 *   * * *   pi     /home/pi/scripts/refresh
                      cmille34 @iwaldrum
                      @iwaldrum said in 27" custom framed magic mirror - fun to get done:
                      Add:
                      Brilliant! I forgot I was calling that script when I woke the screen with the motion sensor
                      already. Hopefully adding it to cron every 30 minutes like you’ve shown will help get the calendar to update more regularly. Thanks for the quick help!
                      • I Offline
                        iwaldrum @cmille34
                        @cmille34
                        I’d love to hear how you have your motion sensor setup with fullpageOS. On my todo list…
                          cmille34 @iwaldrum
                          @cmille34
                          This is far from perfect but it appears to work for me. Generally the screen is dim when I look at the mirror from afar or an angle but if I walk near it, it comes to life. I’m using the cheapie ol’ HC-SR501 motion sensor for this. I think I got a 5 pack for like 5 bucks on eBay. I actually have my sensor dangling at the bottom of my mirror, essentially aiming at the floor. These things are pretty darn sensitive it seems.
                          I essentially have the sensor hooked up to the Pi and and have converted the following Python script to a service that runs at startup. The monitor still has power but the HDMI signal is essentially disabled when motion isn’t detected with the tvservice command (whatever it is! ha).
                          /home/pi/motiondetector.py
                          import os
                          import subprocess
                          import time
                          from gpiozero import MotionSensor
                          pir = MotionSensor(4)
                          while True:
                                  pir.wait_for_motion()
                                  print("Motion!")
                                  subprocess.call(["/bin/sh","/home/pi/scripts/refresh"])
                                  os.system("tvservice -p; fbset -depth 8; fbset -depth 16")
                                  pir.wait_for_no_motion()
                                  print("No motion...")
                                  os.system("tvservice -o")
                          The sources I used to cobble this together:
                          Install gpiozero
                          https://gpiozero.readthedocs.io/en/stable/
                          I think I had some issue getting the gpiozero module to load, but this thread looks familiar. I think the issue is I started with Jessie Lite.
                          https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=126320
                          Script as service
                          http://www.diegoacuna.me/how-to-run-a-script-as-a-service-in-raspberry-pi-raspbian-jessie/
                          Sensitivity Adjustment (this takes some tinkering for sure)
                          http://henrysbench.capnfatz.com/henrys-bench/arduino-sensors-and-input/arduino-hc-sr501-motion-sensor-tutorial/
                          You could probably gather all this with a few minutes of googling but I figured I’d share what I’ve cobbled together so far. A short range IR type sensor may be better if you only want the screen to activate when you get right in front of it, if you just want some mostly automated way of turning the screen off, this should work though.
                            Jayh391 @iwaldrum
                            @iwaldrum
                            Thanks ! I will give it a try!
                            • zdenekZ Offline
                              zdenek @iwaldrum
                              @iwaldrum great, thanks. I’ll try. Any idea, how to refresh on “basic” Jess OS? Via cron? How?
                              unfortunately, on https://www.wunderground.com/weather-radar is just for US and so on, but Europe is not here. Please, any idea, how to add this
                              http://portal.chmi.cz/files/portal/docs/meteo/rad/data_jsradview.html
                              or better this
                              http://portal.chmi.cz/files/portal/docs/meteo/rad/inca-cz/short.html
                              in the worst scenario
                              http://portal.chmi.cz/files/portal/docs/meteo/rad/mobile/ra6_30min.gif
                              thanks, Zdeněk
                                Jayh391 @Jayh391
                                @Jayh391
                                Worked GREAT!
                                • zdenekZ Offline
                                  zdenek @iwaldrum
                                  @iwaldrum can u pls share refres script? Maybe I can use it with Jessie
                                  thanks, Zdenek
                                  • I Offline
                                    iwaldrum @zdenek
                                    @zdenek
                                    This is the refresh script included with FullpageOS. Not sure if you need anything else to be able to run it.
                                    #!/bin/bash
                                    export DISPLAY=:0
                                    WID=$(xdotool search --onlyvisible --class chromium|head -1)
                                    xdotool windowactivate ${WID}
                                    xdotool key ctrl+F5
                                    xdotool key F11
                                    zdenekZ 1 Reply Last reply Reply Quote 0
                                    • zdenekZ Offline
                                      zdenek @iwaldrum
                                      @iwaldrum stupid question - what extension should have the file “refresh”?
                                      • I Offline
                                        iwaldrum @zdenek
                                        @zdenek The script included doesn’t have an extension. If that doesn’t work for you try adding the extension of .sh
                                          shbatm Module Developer @disakos
                                          @disakos I just posted a module for pulling an RTSP Stream from my Hikvision Cameras. Check it out here:
                                          [card:shbatm/MMM-RTSPStream]
                                          • zdenekZ Offline
                                            zdenek @iwaldrum
                                            @iwaldrum so, I’ve installed xdotools, created script, but it doesn’t do anything… :-(
                                            • 2 / 3
