    27" custom framed magic mirror - fun to get done
    41 Posts 13 Posters 76.5k Views 17 Watching
    • I
      iwaldrum @jasondreher
      @jasondreher
      Here is the section in my custom.css file for the MMM-WunderGround module.
      /*	MMM-Weatherunderground     */
      .region.top.right .MMM-WunderGround table th {
        display: none; /* removes icons above max-temp, min-temp and % chance of rain */
      .MMM-WunderGround .max-temp {
        color: #f66;
      .MMM-WunderGround .min-temp {
        color: #0ff;
      .MMM-WunderGround .weather-icon {
        color: #f93;
      .MMM-WunderGround .day {
        color: #6f6;
      .region.top.center .MMM-WunderGround table.small,   /* selector for ONLY current weather Thanks to Strawberry-3.141 */
      .region.top.right .MMM-WunderGround table:not(.small),   /* selector for ONLY weather forecast */
      .region.top.right .MMM-WunderGround table.small td:nth-child(6)  {
        display: none;    /* this line and line above selector for NO rain amount column */
      • cowboysdudeC
        I’d be interested in how you hooked your security cameras to it…
        • I
          iwaldrum @iwaldrum
          @cowboysdude
          This is how I integrated my security cameras. If you have any questions or want more details let me know.
          @iwaldrum said in 27" custom framed magic mirror - fun to get done:
          @disakos
          I’m using a program called Netcam Studio on the same pc that I’m running MM in serveronly mode. Netcam Studio allows you to connect to multiple types of cameras, either local or IP based. I’m using it to connect my q-see surveillance system using RSTP connections, as well as several Foscam and PC connected cams.
          Once the cameras are connected to netcamstudio, you can then generate a secure token based url for each one. I then took each url and placed them into a single html file and put it on a webserver (same pc). Using the iFrame module I pointed to the html file to display it on my MM. You’ll need to play with the positioning and sizing of the iframe, as well as the webpage layout and image sizes in the html.
          I typically get 5-10 fps for each camera. Depending on the # of cameras you will be displaying and the type of system your running MM on will drive the performance of the playback.
          I know the setup is a little complex, but I felt it was the best way to get a flexible, integrated look that performed the best.
          Let me know if you have any questions.
            cohron
            I cant find the little weather icons. Temp hi and lo and the umbrella.
            0_1492796477309_upload-210cadc3-e54f-425e-94b6-0466ae88aa00
            C 1 Reply Last reply
              cohron @cohron
              @cohron nevermind im a dummy, copied the custom.css without really reading it:
              Reply Quote 3
                cmille34
                This mirror looks great! It’s been the inspiration to take a stab at making one as well. I like the idea of running MM on an existing windows server I have in the house and just rely on the Pi3 to load the webpage.
                With your mirror do you turn off the screen when no motion is detected or does it display everything constantly? If you do turn off the screen, how are you triggering it on and off? I see there are PIR modules for MM but since you’ve made the decision to simply view the MM page remotely, I was wondering if you had some way to turn off the screen?
                Thanks for taking the time to detail this out!
                I 1 Reply Last reply
                • I
                  iwaldrum @cmille34
                  @cmille34
                  Glad I could inspire you. I do like running it centrally. Since I made this one, I’ve setup another one in my son’s room. Different size screen and content. .All I had to do is run another instance on my server - copy and paste folder and change the config file to my liking… done…
                  I do not turn my screen off. It’s on my todo list… To your point, it might be a little trick to do so since MM isn’t running locally. We’ll need to find an external solution to do so that works on fullpageOS or whatever platform you are running at the endpoint. If I find something Ill post…
                  Reply Quote 3
                  • W
                    wbleek @iwaldrum
                    @iwaldrum your project looks great! It is almost the module configuration I am also aiming for. Could you share how you integrated the surveillance cameras (iframe code)? I have trouble integrating mine. They offer rtsp and also jpegs that you can pull via http request. Which seems to be very similar to your setup. I would be interested in how you used the iframes to do it. Did you simply put the token-url in the iFrame-Module? How did you handle the refresh? Maybe you could share some code.
                    Thanks very much
                    Wolf
                      cmille34 @wbleek
                      @wbleek I achieved the cameras on my mirror pretty easily with Blue Iris. I simply made a custom .HTM file and placed it in the /modules directory of the MagicMirror then using iFrameReload i just call the /modules/custom.htm URL to load the cameras. Below is my custom.htm file I am calling in the iFrameReload module:
                      <table>
                      <tr>
                      </tr><tr>
                      <td>
                      <img src="http://192.168.1.108:81/mjpg/BackyardCam/video.mjpg?q=25&amp;s=25" alt="BackyardCam" />
                      </td>
                      <td>
                      <img src="http://192.168.1.108:81/mjpg/FrontDoor/video.mjpg?q=40&amp;s=40" alt="DrivewayCam" />
                      </td>
                      </tr>
                      <tr>
                      <td>
                      <img src="http://192.168.1.108:81/mjpg/DriveWayCam/video.mjpg?q=25&amp;s=25" alt="FrontdoorCam" />
                      </td>
                      </tr>
                      </table>
                      In lieu of having blue iris you could possibly simply pull the mjpg streams straight from each cameras individually and slap them in the img tag. That may be a better way actually but it seems to be working fine for me through Blue Iris this way.
                      Below is the code from my config.js showing how I am calling this custom HTM file:
                      	module: 'MMM-iFrameReload',
                      	position: 'bottom_bar', // This can be any of the regions.
                      		url: "http://192.168.1.108:9000/modules/custom.htm",
                      		width: "100%", // Optional. Default: 400px
                      		height: "850px", // Optional. Default: 800px
                      		scrolling:"no",
                      		refreshInterval: 600, //Optional. Default: 3600 = 1 hour
                      		animationSpeed: 4000,
                      My setup is similar to the OP in terms of running the MagicMirror server on a central server and simply running fullpageos on the raspberry pi to call the magicmirror page.
                      Hope this helps.
                      W 1 Reply Last reply
                      Reply Quote 2
                        pepemujica
                        Hi! Looks awesome! Congrats!
                        Do you have any photo from the sides and/or back?
                        • W
                          wbleek @cmille34
                          @cmille34 Hey, thanks for your answer. I appreciate that. My NVR only provides still JPEGs or RTSP for pictures. If I use JPEGs I have to reload them in a 200ms interval to achieve acceptable motion.
                          At this point, I have tried the following:
                          1. uses MMM-iFrame
                          • do the reload via embedded HTML meta-tag
                          • strong flickers (approx. half of the time blank)
                          • works, but not visually accaptable
                          • does not scale due to the flickering
                          1. use MMM-iFrame
                          • do the reload via embedded Java-Script function
                          • almost no flicker, almost fluid motion
                          • works for 30-60 minutes, then the module stops
                          • does not scale since it stops earlier with more modules
                          1. use oxmplayer as an overlay
                          • needs '–avdict rtsp_transport:tcp ’ switches to work without banding
                          • rtsp with 640x360 works with 30fps
                          • tested to concurrent streams
                          I am happy with the omxplayer solution even though it is not integrated in the MagicMirror. But for the user it looks integrated and it delivery a very good video quality.
                          Cheers
                          wolf
                          Reply Quote 2
                            Jayh391
                            I would like to know how you brought your Homeseer info in?
                            Jay
                            • zdenekZ
                              zdenek @iwaldrum
                              @iwaldrum MMM-SimpleLogo - pulls updated radar image from wundergound - can u plz share details? What´s exactly in the config?
                              thanks, Zdeněk
                              • I
                                iwaldrum @pepemujica
                                @pepemujica
                                Here are some additional pics… The back isn’t the prettiest, but it does the job. Used painters tape, L brackets and velcro to keep everything in place.
                                0_1496222337049_IMG_1961.JPG 0_1496222343783_IMG_2065.JPG 0_1496222351990_IMG_2788.JPG 0_1496222360052_IMG_2866.JPG 0_1496222364276_IMG_2867.JPG
                                • I
                                  iwaldrum @Jayh391
                                  @Jayh391
                                  I used the MMM-Rest module to pull the device data via the rest api in Homeseer. Here is the section in my config file. Still work in progress…
                                  		module: 'MMM-Rest',
                                  		header: 'House Status',
                                  		position: 'top_right',	// This can be any of the regions.
                                  									// Best results in one of the side regions like: top_left
                                                  debug: false,
                                                  mappings: {
                                                      on_off: {
                                                          true: 'on',
                                                          false: 'off',
                                                      temperature: {
                                                          1: 'cold',
                                                          2: 'warm',
                                                          3: 'HOT',
                                                  sections: [
                                                      format: '%d',
                                                      url: 'http://yourURLhere:port/HomeSeer_REST_API.aspx?function=getdevicestatusvaluebyid¶m1=108¶m2=value',
                                                      format: '%df',
                                                      url: 'http://yourURLhere:port/HomeSeer_REST_API.aspx?function=getdevicestatusvaluebyid¶m1=103¶m2=value',
                                                      format: '%d',
                                                      url: 'http://yourURLhere:port/HomeSeer_REST_API.aspx?function=getdevicestatusvaluebyid¶m1=128¶m2=value',
                                                      format: '%df',
                                                      url: 'http://yourURLhere:port/HomeSeer_REST_API.aspx?function=getdevicestatusvaluebyid¶m1=187¶m2=value',
                                                      format: '%d',
                                                      url: 'http://yourURLhere:port/HomeSeer_REST_API.aspx?function=getdevicestatusvaluebyid¶m1=118¶m2=value',
                                                      format: '%df',
                                                      url: 'http://http://yourURLhere:port/HomeSeer_REST_API.aspx?function=getdevicestatusvaluebyid¶m1=113¶m2=value',
                                                      format: '%df',
                                                      url: 'http://yourURLhere:port/HomeSeer_REST_API.aspx?function=getdevicestatusvaluebyid¶m1=92¶m2=value',
                                                      format: '%s',
                                                      mapping: 'temperature',
                                  		    url: 'http://yourURLhere:port/HomeSeer_REST_API.aspx?function=getdevicestatusvaluebyid¶m1=137¶m2=value',
                                                      format: '%d',
                                                      format: 'Lights %s',
                                                      mapping: 'on_off',
                                              output: [
                                                  ['<b>Location:</b>',,'<b>Temp:</b>'],
                                                  ['Family Room',,'@2'],
                                                  ['Living Room','@6'],
                                                  ['Upstairs','@4'],
                                                  ['Garage','@7'],
                                  J 1 Reply Last reply
                                  • I
                                    iwaldrum @zdenek
                                    @zdenek
                                    I used wunderground.com to create the animated radar image and MMM-SimpleLogo to display it.
                                    Create your custom image at https://www.wunderground.com/weather-radar - looks like US, Canda & Australia only. Once created, copy the URL and place it in the MMM-SimpleLogo module.
                                    Wunderground updates the radar image every 10-20 minutes. Since I’m using FullpageOS as my mm frontend I have the page refresh every 30 minutes which then pulls an updated image.
                                            module: 'MMM-SimpleLogo',
                                    		fileUrl: "https://radblast.wunderground.com/cgi-bin/radar/WUNIDS_map?station=DIX&brand=wui&num=1&delay=15&type=N0R&frame=0&scale=1.000&noclutter=0&showstorms=0&mapx=400&mapy=240¢erx=400¢ery=240&transx=0&transy=0&showlabels=1&severe=0&rainsnow=0&lightning=0&smooth=0&rand=24937062&lat=40.75000000&lon=-74.00000000&label=New+York%2C+NY",
                                    		width: "400px",
                                    		position: "center",
                                    C zdenekZ 2 Replies Last reply
                                      cmille34 @iwaldrum
                                      @iwaldrum said in [27" custom framed magic mirror - fun to get done] Since I’m using FullpageOS as my mm frontend I have the page refresh every 30 minutes which then pulls an updated image.
                                      How is you have the page reload every 30 mins in fullpageOS? My calendar app doesn’t appear to be updating, I’m hoping a page reload every 30 mins will fix that.
                                      • I
                                        iwaldrum @cmille34
                                        @cmille34
                                        There is a refresh script included with fullpageOS. it’s located at /home/pi/scripts/refresh. I added it to the crontab to run every 30min. I also added a line to crontab to reboot at midnight. This helps keep the system fresh and free up any processes or used memory on the Pi.
                                        Here is my config
                                        sudo nano /etc/crontab
                                        Add:
                                        0  0    * * *   root    reboot
                                        */30 *   * * *   pi     /home/pi/scripts/refresh
                                          cmille34 @iwaldrum
                                          Add:
                                          Brilliant! I forgot I was calling that script when I woke the screen with the motion sensor
                                          already. Hopefully adding it to cron every 30 minutes like you’ve shown will help get the calendar to update more regularly. Thanks for the quick help!
                                          • I
                                            iwaldrum @cmille34
                                            @cmille34
                                            I’d love to hear how you have your motion sensor setup with fullpageOS. On my todo list…
