    MMM-Soccer - Standings, Schedules and Top Scorers
    bundesligafootballmodalpremiere leagueprimiera divisionsoccervoice control
    209 Posts 43 Posters 553.8k Views 43 Watching
    • strawberry 3.141S Offline
      this is how the module looks like for the german league
      0_1466075701079_soccer standings
      M 2 Replies Last reply Reply Quote 1
        Mitchfarino Module Developer @strawberry 3.141
        @strawberry-3.141 nice one!
        I’ll be looking to add this for my son, this with a rss feed for team news will work great for him
          @strawberry-3.141 Are you putting them in a GitHub repository?
            sarthak18593
            I dont get the standings , shows me “soccer_module_8” under the socer heading
            • K Offline
              KirAsh4 Moderator @sarthak18593
              That generally means there’s an error and the module isn’t loading properly.
                sarthak18593
                So what could be the problem? The config.js file or the files in the soccer folder ?
                • K Offline
                  KirAsh4 Moderator
                  I will leave that for the author of the module to help you with. I am not familiar with the module.
                    @sarthak18593 I removed the module from the pi and reinstalled it from scratch and it’s working like before.
                    So let’s try to figure out what causes the problem for you.
                    I’m very busy the next days with exams and presentations but I’m trying to help as fast as I possibly can.
                    Can you post your config please.
                    Did you try to disable all other modules in the config to see if there’s a conflict to another module?
                    • Z Offline
                      zombi27
                      hey!
                      that looks like a great module! Sadly it’s not working for me :(
                      I installed it just the way you described, but i just get “No data available”
                      Do i have to get an api key? Or is “false” possible like in your config? I just copy and pasted yours, all other modules are working fine…
                      greetings from frankfurt, max
                        hey max, like I described in the post before yours i did it like in the instructions and it worked fine, but let’s try together to figure out why it’s not working for you.
                        you don’t need an api key unless you make over 50 requests a day. at the moment the module only request data from the api if the module gets initialised after starting your mirror. when you dont restart your mirror more than 50 times a day you don’t need one.
                        because you can see no data available the module should be loaded correctly, but there is probably a problem with the api itself. did you try to put the url in the browser and see if you get a result there maybe the server of the api isn’t available at the moment
                        http://api.football-data.org/v1/soccerseasons/394/leagueTable
                        this should give you a result for german bundesliga
                        report your result on this and then we can see what we can do otherwise if its not working
                        • Z Offline
                          zombi27
                          sorry! my fault! silly me!
                          i reloaded a hundred times via ctrl+r, but i never restarted the whole mirror -.-
                          now it’s working just fine, thank you :)
                            i’m happy that it’s working for you
                            if you want you can also apply for a free api key here http://api.football-data.org/register to get 50 requests a minute
                            • I Offline
                              ianperrin
                              Hi @strawberry-3-141 - thanks for putting together this module.
                              In case it helps anyone, I’ve created a GitHub repository for my version of the module - https://github.com/ianperrin/MMM-FootballData. I renamed it to add the MMM- prefix as that seems the convention round here, and changed soccer to FootballData because a) that’s the name of the game :) and b) it indicates the source (http://api.football-data.org)
                              [card:ianperrin/MMM-FootballData]
                              ALL CREDIT GOES TO @strawberry-3-141
                              "Live as if you were to die tomorrow. Learn as if you were to live forever." - Mahatma Gandhi
                              strawberry 3.141S I 3 Replies Last reply Reply Quote 1
                                strawberry 3.141 Project Sponsor Module Developer @ianperrin
                                @ianperrin well that’s kind of an old version meanwhile, I have a work in progress of a newer version on github already
                                • I Offline
                                  ianperrin @strawberry 3.141
                                  @strawberry-3.141 do you have a link?
                                    [card:fewieden/MMM-soccer]
                                    as I said it’s work in progress and not finished
                                    • I Offline
                                      @strawberry-3.141 care to share your plans - perhaps I can contribute?
                                      I also notice you’ve hardcoded the leagues into the subclassed start method. Is there a reason for this, because it means that I can’t override them via config to use other leagues?
                                        plans are:
                                        • i18n
                                        • integration of my voice recognition module (also wip), this goes with more use of the api like fixtures etc.
                                        • cup support
                                        • smaller screen support
                                        probably I’m going one step back and will put league codes configurable again
                                        • I Offline
                                          ianperrin
                                          @strawberry-3-141
                                          I’ve just sent you a pull request which attempts to find a solution for smaller screens (compact mode). Not perfect, but an initial prototype!
                                          Here’s the original full table:
                                          full table
                                          And here’s the compact view:
                                          compact table
                                          • I Offline
                                            ianperrin @ianperrin
                                            @ianperrin said in Soccer Standings:
                                            If anyone is looking for my version of the module, I have now deleted the MMM-FootballData repository and focusing my efforts on a fork of MMM-soccer created by @strawberry-3-141.
                                            For those interested, you can find my fork here: https://github.com/ianperrin/MMM-soccer
                                            • 10
                                            • 11
                                            • 1 / 11
