    MMM-Soccer - Standings, Schedules and Top Scorers
    bundesligafootballmodalpremiere leagueprimiera divisionsoccervoice control
    209 Posts 43 Posters 582.7k Views 43 Watching
    • strawberry 3.141S
      @sarthak18593 I removed the module from the pi and reinstalled it from scratch and it’s working like before.
      So let’s try to figure out what causes the problem for you.
      I’m very busy the next days with exams and presentations but I’m trying to help as fast as I possibly can.
      Can you post your config please.
      Did you try to disable all other modules in the config to see if there’s a conflict to another module?
      • zombi27Z
        zombi27
        hey!
        that looks like a great module! Sadly it’s not working for me :(
        I installed it just the way you described, but i just get “No data available”
        Do i have to get an api key? Or is “false” possible like in your config? I just copy and pasted yours, all other modules are working fine…
        greetings from frankfurt, max
        • strawberry 3.141S
          hey max, like I described in the post before yours i did it like in the instructions and it worked fine, but let’s try together to figure out why it’s not working for you.
          you don’t need an api key unless you make over 50 requests a day. at the moment the module only request data from the api if the module gets initialised after starting your mirror. when you dont restart your mirror more than 50 times a day you don’t need one.
          because you can see no data available the module should be loaded correctly, but there is probably a problem with the api itself. did you try to put the url in the browser and see if you get a result there maybe the server of the api isn’t available at the moment
          http://api.football-data.org/v1/soccerseasons/394/leagueTable
          this should give you a result for german bundesliga
          report your result on this and then we can see what we can do otherwise if its not working
          • zombi27Z
            zombi27
            sorry! my fault! silly me!
            i reloaded a hundred times via ctrl+r, but i never restarted the whole mirror -.-
            now it’s working just fine, thank you :)
            • strawberry 3.141S
              i’m happy that it’s working for you
              if you want you can also apply for a free api key here http://api.football-data.org/register to get 50 requests a minute
              • I
                ianperrin
                Hi @strawberry-3-141 - thanks for putting together this module.
                In case it helps anyone, I’ve created a GitHub repository for my version of the module - https://github.com/ianperrin/MMM-FootballData. I renamed it to add the MMM- prefix as that seems the convention round here, and changed soccer to FootballData because a) that’s the name of the game :) and b) it indicates the source (http://api.football-data.org)
                [card:ianperrin/MMM-FootballData]
                ALL CREDIT GOES TO @strawberry-3-141
                “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
                strawberry 3.141S I 3 Replies Last reply
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @ianperrin
                  @ianperrin well that’s kind of an old version meanwhile, I have a work in progress of a newer version on github already
                  I 1 Reply Last reply
                  • I
                    ianperrin @strawberry 3.141
                    @strawberry-3.141 do you have a link?
                    • strawberry 3.141S
                      [card:fewieden/MMM-soccer]
                      as I said it’s work in progress and not finished
                      • I
                        @strawberry-3.141 care to share your plans - perhaps I can contribute?
                        I also notice you’ve hardcoded the leagues into the subclassed start method. Is there a reason for this, because it means that I can’t override them via config to use other leagues?
                        Reply Quote 2
                        • strawberry 3.141S
                          plans are:
                          • i18n
                          • integration of my voice recognition module (also wip), this goes with more use of the api like fixtures etc.
                          • cup support
                          • smaller screen support
                          probably I’m going one step back and will put league codes configurable again
                          Reply Quote 2
                          • I
                            ianperrin
                            @strawberry-3-141
                            I’ve just sent you a pull request which attempts to find a solution for smaller screens (compact mode). Not perfect, but an initial prototype!
                            Here’s the original full table:
                            full table
                            And here’s the compact view:
                            compact table
                            Reply Quote 2
                            • I
                              ianperrin @ianperrin
                              @ianperrin said in Soccer Standings:
                              If anyone is looking for my version of the module, I have now deleted the MMM-FootballData repository and focusing my efforts on a fork of MMM-soccer created by @strawberry-3-141.
                              For those interested, you can find my fork here: https://github.com/ianperrin/MMM-soccer
                              • zombi27Z
                                zombi27
                                hey :)
                                thats a really nice addition with the compact view! i like the highlighting of the focussed team!
                                another idea would be the possibility to highlight that one team in the complete list too, to see your favourite team faster :)
                                Reply Quote 3
                                • MichMichM
                                  MichMich
                                  Nice! Now, if somebody could port this to Formula 1 standings … ;)
                                  • strawberry 3.141S
                                    strawberry 3.141 Project Sponsor Module Developer @MichMich
                                    @MichMich I was thinking about doing this, but couldn’t find a proper free api yet :(
                                    • I
                                      @strawberry-3.141 , @MichMich - would this one do the job http://ergast.com/api/f1/current/driverStandings.json ??
                                      If so, I’m happy to roll something up based on the Soccer Standings module…
                                      MichMichM 1 Reply Last reply
                                      • MichMichM
                                        MichMich @ianperrin
                                        @ianperrin Absolutely! 🎉
                                        • strawberry 3.141S
                                          i just published an update, which allows to focus_on also TOP, BOTTOM and support for coming features, you’re already able to set this per league
                                          • I
                                            ianperrin @MichMich
                                            @MichMich said in Soccer Standings:
                                            Version 1 done - see https://forum.magicmirror.builders/topic/463/formula-1-standings
                                            • 10
                                            • 11
                                            • 1 / 11
