    Shopping list off Amazon
    7 Posts 5 Posters 8.4k Views 5 Watching
    • I Offline
      ipluto
      Hi, I’m looking to build my first magic mirror, and since I live in the US, I would like to get all the required hardware off Amazon (and preferably, Prime).
      Here’s what I have so far:
      Raspberry PI 3 Model B A1.2GHz 64-bit quad-core ARMv8 CPU, 1GB RAM
      CanaKit 5V 2.5A Raspberry Pi 3 Power Supply / Adapter / Charger
      18" x 24" Acrylic See-Through Mirror, 3mm, 30% Transparent
      ArtToFrames 16x20 inch Eggshell Rustic Barnwood Wood Picture Frame, WOM0066-1343-YWHT-16x20
      AmazonBasics HDMI Input to DVI Output Adapter Cable - 6 Feet (Latest Standard)
      SCIGRIP 16 10315 Acrylic Cement, Low-VOC, Medium bodied, 5 Ounce Tube, Clear
      NT Cutter Multi-Use Plastic Cutter with Plastic Cutting Blade and Precision Knife Blade, 1 Cutter (M-500P)
      Cable Leader Power Cord Splitter Cable For 2 NEMA 5-15R to 1 NEMA 5-15P (14 inches / 16 AWG)
      I already have an old ViewSonic monitor that takes DVI input, and about the size of 20x13.
      Is there any major flaw with my selection? All suggestions are welcomed.
        Mykle1 Project Sponsor Module Developer @ipluto
        @ipluto said in Shopping list off Amazon:
        Really, there can be no flaw in your selections. Everyone’s mirror is custom and personal. No two are alike. That’s part of the beauty of it.
        With that said, I also bought most of my items from Amazon.
        CanaKit that included Pi3 B, charger, SD Card, case, heat sinks.
        12" x 24" acrylic 2 way mirror
        HDMI to DVI cable (my monitor is DVI also)
        3 outlet mini power strip
        I built my frame from wood I had on hand and casing from a local Home Depot. I only had to shorten the length of my acrylic mirror. I used a standard utility knife and a metal T-sqaure to score the glass, carefully making several passes with the blade, then I snapped it like a piece of sheetrock. The only glue I used was wood glue while making the frame. My mirror is not affixed in any way.
        Best of luck to you and enjoy the process.
        Have a look at mine
        https://forum.magicmirror.builders/topic/1678/1-old-noob-1-rpi-i-can-t-believe-i-did-it-revisited
        • I Offline
          ipluto @Mykle1
          @Mykle1 Thanks for your response!
          • QiuyiWuQ Offline
            QiuyiWu
            This is awesome!!! Thank you for sharing!
            I’m also preparing for making a magic mirror by myself, so your experience would definitely help me a lot!
            By the way, is your magic mirror touch-screen? And if I want to make a touchable magic mirror, does that mean I need a touchable led monitor?
            Thank you so much!
            I’m statistically significant.
            • cowboysdudeC Offline
              I bought a 32" TV and a mini-itx running unbuntu and SSD Hard drive… LOL That’s how different they can be ;)
                Chiumanfu
                I would add a USB Microphone
                https://www.amazon.com/Kinobo-Microphone-Desktop-Recognition-Software/dp/B00IR8R7WQ/
                And a PIR Sensor
                https://www.amazon.com/PIR-motion-sensor-HC-SR501-Arduino/dp/B00L9GKN3I/
                If I was to do it again, I would call your local glass shops first. I got the same acrylic mirror from Amazon and no matter how careful I was with the frame, it flexes and create a funhouse mirror effect. I called around and the first glass shop I contacted had glass two-way mirror for roughly the same price.
                What are you planning to do with the acrylic cement?
                  cowboysdude Module Developer @Chiumanfu
                  @Chiumanfu said in Shopping list off Amazon:
                  And a PIR Sensor
                  I bought a real two way mirror and it was not cheap… BUT worth it :)
