    Motion Detector
    213 Posts 38 Posters 578.7k Views 39 Watching
    • mickyasM
      mickyas @alexyak
      @alexyak Does this module switch off the pi, i’m only asking since i have Alexa running in the background which requires 3 terminals to be open all the time? If the pi goes into ‘standby’ or goes off i have to re-enter the information into the 3 terminals consecutively to get it up and running again. Thanks
      Mick
        bhepler Module Developer @Kimzer
        @Kimzer I wrote up a method using a version of Motion for the RasPi. It’s under the tutorials section of the forum. It’s a non-module solution, so there’s some weirdness involved. But I did get it to work with a Raspicam.
        @mickyas - This module doesn’t switch off the pi, it just switches off the output to the monitor.
        • cowboysdudeC
          cowboysdude Module Developer @bhepler
          @bhepler Yup that’s what I did too.
          • H
            Hawking
            I’m trying to use this model on my Raspberry Pi Zero W with the Raspberry Cam. I run
            MM in serveronly mode, using the Midori-browser. This setup itself works fine and also the camera is able to make pictures
            However, if I try to add the ‘motiondetector’ module to the config I just get an empty (black, but not switched of) screen after reboot. This is even the case for a very small config.js :
            var config = {
                    port: 8080,
                    language: "en",
                    timeFormat: 24,
                    units: "metric",
                                    module: "clock",
                                    position: "top_left"
                                module: 'motiondetector',
                                        timeout: 5*60*1000
            Things I did:
            cd ~/MagicMirror/modules
            git clone https://github.com/alexyak/motiondetector
            Added line bcm2835-v4l2 to /etc/modules and hdmi_blanking=1 to /boot/config.txt
            If I omit the motiondetecotor entry in the config.js it loads fine and I can see the loaded modules. If I execute
            /opt/vc/bin/tvservice -o
            the screen goes off (completely black). I I afterwards run
            /opt/vc/bin/tvservice --preferred && sudo chvt 6 && sudo chvt 7
            the background light of the screen goes on, however the modules that were there previously don’t show up again ( I waited for several minutes).
            If I run
            /opt/vc/bin/tvservice --preferred && sudo chvt 6 && sudo chvt 2
            the modules become visible again. Therefore I changed the line in
            ~/MagicMirror/modules/motiondetector/node_helper.js
            accordingly. However then I got still an empty screen and in the log:
            Jul 16 18:59:23 me startMagicMirror.sh[480]: ** Message: console message: [native code] @0: Starting module: motiondetector
            Jul 16 18:59:23 me startMagicMirror.sh[480]: ** Message: console message: http://localhost:8080/modules/motiondetector//motiondetector.js @39: TypeError: Attempted to assign to readonly property.
            Jul 16 18:59:24 me startMagicMirror.sh[480]: monitor :state 0x12000a [HDMI DMT (82) RGB full 16:9], 1920x1080 @ 60.00Hz, progressive
            Jul 16 18:59:24 me startMagicMirror.sh[480]: ** Message: console message: http://localhost:8080/js/main.js @134: TypeError: null is not an object (evaluating 'moduleWrapper.getElementsByClassName')
            To me as a beginner it looks like a permission problem. However even making the motiondetector folder and all files therein rw for everybody it didn’t work.
            I hope that somebody who has knowledge about JS can comment on this issue. Many thanks in advance.
            • strawberry 3.141S
              strawberry 3.141 Project Sponsor Module Developer @Hawking
              @Hawking try to change line 39 to:
              cameraPreview.style.visibility = "hidden";
              • H
                Hawking
                Thanks for the quick help. I also found the line in motiondetector.js a bit strange (why the semicolon within the parenthesis…) but as I don’t know JS or details about the code, I couldn’t judge.
                I still have the same effect (blank screen) but the new error message is
                Jul 17 23:16:55 me startMagicMirror.sh[445]: ** Message: console message: [native code] @0: Starting module: motiondetector
                Jul 17 23:16:55 me startMagicMirror.sh[445]: ** Message: console message: http://localhost:8080/modules/motiondetector//diff-cam-engine.js @81: TypeError: undefined is not an object (evaluating '(navigator.getUserMedia || navigator.webkitGetUserMedia || navigator.mozGetUserMedia || navigator.msGetUserMedia).call')
                Maybe all these things give empty? As a workaround I surrounded the function by
                function requestWebcam() {
                         var self = this;
                         method = (navigator.getUserMedia || navigator.webkitGetUserMedia || navigator.mozGetUserMedia || navigator.msGetUserMedia);
                                   if ( !! method ) {
                Now at least the other modules load successfully.
                However, the modules don’t get deactivated after some minutes :-/ I assume that one of these navigator methods is needed for the motiondetector to work? If I look at https://developer.mozilla.org/en/docs/Web/API/Navigator/getUserMedia they seem anyway outdated? How would the user grand permission in a headless setup? Does somebody know if they are supported by the Midori browser?
                • strawberry 3.141S
                  @Hawking As far as I know electron exposes the audio and video access, but in midori you probably need to allow the access manually
                    mongo116 Module Developer
                    Hi, I’m a total noob to all this, but have recently started a project to build a magic mirror. I’ve got MagicMirror setup, and have the modules I want working. Now I’d like to use the motiondetector module, but although it appears to run without any error, the monitor itself is not turning off.
                    I’ve tested the camera module and that is working, and I can see an image / record video etc. I’ve also tested running the tvservice commands directly and both of these work as expected:
                    Only change I have made is to the timeout (30000 so I’m not waiting for too long before the screen should turn off).
                    My config.js has the following entry for motiondetector:
                    /* Magic Mirror Config Sample
                     * MIT Licensed.
                    var config = {
                    	port: 8080,
                    	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1","192.168.7.4"], // Set [] to allow all IP addresses
                    	language: "en",
                    	timeFormat: 24,
                    	units: "metric",
                    			module: "alert",
                    			module: "updatenotification",
                    			position: "top_bar"
                    			module: "clock",
                    			header: "UK Holidays",
                    						symbol: "calendar-check-o ",
                    						url: "webcal://www.gov.uk/bank-holidays/england-and-wales.ics"
                    			module: "currentweather",
                    				locationID: "xxxxxxx",  //ID from http://www.openweathermap.org/help/city_list.txt
                    				appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
                    			module: "weatherforecast",
                    			header: "Weather Forecast",
                    			module: "newsfeed",
                    			position: "bottom_bar",
                    				feeds: [
                    						title: "BBC News",
                    						url: "http://feeds.bbci.co.uk/news/rss.xml?edition=uk"
                    						title: "BBC London",
                    						url: "http://feeds.bbci.co.uk/news/england/london/rss.xml"
                    				showSourceTitle: true,
                    				showPublishDate: true
                    		module: 		'MMM-UKNationalRail',
                    		position: 		'top_left',
                    		header:			'Departures',		//Optional - delete this line to turn OFF the header completely
                    			stationCode: 		'xxx', 		// CRS code for station
                    			app_id: 			'xxxxxxx', 		// TransportAPI App ID
                    			app_key: 			'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx', 		// TransportAPI App Key
                    			maxResults: 		5,  		//Optional - Maximum results to display.
                    			showOrigin: 		false   	//Optional - Show the origin of the train in the table
                        module:		'MMM-Tube-Status',
                        header:		'Tube Status',
                        config:		{
                                    show_all:	 true
                    		module: 	'MMM-UKLiveBusStopInfo',
                    			atcocode: 		'xxxxxxxxxx', 		// ATCO code for specific bus stop
                    			limit: 			5, 					// Optional - Maximum results to display.
                          		nextBuses: 		'yes',              	// Optional - Use expensive RealTime info from NextBuses
                          		showRealTime: 	true,          	// Optional - show realtime departure info
                          		showDelay: 		true              	// Optional - show delay in minutes based on Real Time info vs Time table
                    		module: 'MMM-SystemStats',
                    		position: 'bottom_right', // This can be any of the regions.
                    		classes: 'small dimmed', // Add your own styling. Optional.
                    			updateInterval: 10000,
                    			animationSpeed: 0,
                    			align: 'left', // align labels
                    			//header: 'System Stats', // This is optional
                    			module: "MMM-ip",
                    			position: "bottom_right"
                        module: 'MMM-Remote-Control'
                        // , position: 'bottom_left'
                    Weird thing is, if I try to have a config section in the config.js with the timeout, and restart MagicMirror, I get an error that the config.js is corrupt. But if I remove the config part, MagicMirror loads without error. MM log below:
                    0|mm       | Connecting socket for: MMM-ip
                    0|mm       | Starting module helper: MMM-ip
                    0|mm       | Connecting socket for: MMM-Remote-Control
                    0|mm       | Starting node helper for: MMM-Remote-Control
                    0|mm       | Connecting socket for: motiondetector
                    0|mm       | Sockets connected & modules started ...
                    0|mm       | monitor on: true
                    0|mm       | monitor :state 0x120006 [DVI DMT (82) RGB full 16:9], 1920x1080 @ 60.00Hz, progressive
                    0|mm       |
                    0|mm       | Launching application.
                    0|mm       | Create new calendar fetcher for url: http://www.gov.uk/bank-holidays/england-and-wales.ics - Interval: 300000
                    0|mm       | Create new news fetcher for url: http://feeds.bbci.co.uk/news/rss.xml?edition=uk - Interval: 300000
                    0|mm       | Create new news fetcher for url: http://feeds.bbci.co.uk/news/england/london/rss.xml - Interval: 300000
                    0|mm       |
                    Any ideas on what could be the problem?
                    Thanks…
                    • H
                      Hawking @strawberry 3.141
                      @strawberry-3.141
                      Thanks for your help. Unfortunately I don’t find any information about media access or how to activate it in the Midori browser…
                      @mongo116
                      I cant’ help you why the motiondetector does not turn off your screen (it also does not work in my case). However, how does the config.js with the additional time-out section that results in an error look like? At least in my case a section like
                                                 timeout: 5*60*1000
                      gave no complaints about errors in the config file (for a complete config-file see my post above).
                        mongo116 Module Developer @Hawking
                        @Hawking Thank you, that works. Monitor is still not turning off, but that’s one issue off the list :)
                          Just to add to this, I have checked that the camera is working and motion is detected by testing with https://github.com/pageauc/motion-track. All appears to be working as expected. No motion is detected unless I move in front of the camera.
                          • strawberry 3.141S
                            strawberry 3.141 Project Sponsor Module Developer @mongo116
                            @mongo116 maybe the value that gets returned is different than the value set in the module, so he always tries to activate the monitor?
                              I’ve got the motion detection now working - had to add bcm2835-v4l2 to \etc\modules - restarted and screen now turns off after defined period and on when motion is detected. This is really great, and I’m nearly there - but… Now when the motiondetector is running, the RPi3 temp just goes up and up and up, until it eventually crashes/freezes and I have to pull the power as RPi is completely unresponsive. If I remove motiondetector from MagicMirror, temperature stays stable and no crashing. Is there something I can change in the config to sort out this performance issue?
                              • strawberry 3.141S
                                @mongo116 it looks like https://github.com/alexyak/motiondetector/blob/master/diff-cam-engine.js#L37 it creates 10 images per second and compares it to the previous which is probably the intensive part
                                  mongo116 Module Developer @strawberry 3.141
                                  @strawberry-3.141 Thanks for that. I’ve amended this slightly so will keep an eye on it. Might also have a look at putting on some heatsinks to see if that helps.
                                  One (hopefully!) final question. When the monitor is turned off, is there a way to ‘freeze’ the other modules, so they stop running for the duration that the monitor is off? This would hopefully help with performance, in that the other modules are no longer running.
                                  • strawberry 3.141S
                                    @mongo116 every module has a suspend and resume function, but nearly none module that I’m aware of has implemented stopping intervals and fetching data in there. so calling those functions wouldn’t make a difference then just hiding it on the display.
                                    Furthermore I doubt that it would really make a difference if you’re not using another cpu intensive task like voice recognition …
                                      reaper81
                                      sorry for my noob-Question but is there an setup or a explaination how to use the three .js files from alexeyak on github? normaly there is an readme-file.
                                        mongo116 Module Developer @reaper81
                                        @reaper81 I had the following in my config.js:
                                                        timeout: 5*60*1000
                                        You will need to ensure that the 3 files are located in the modules/motiondetector folder.
                                        I ended up using a different method for motion detection though, as tvservice kept stopping working.
                                          jdahli1
                                          So after far too many months, I’ve finally gotten my mirror put together. Everything is working great, except for this module (sometimes). After a reboot everything works at least once, meaning that the monitor will turn off when no motion is detected and turn on once motion is detected. Sometimes, it will work correctly for an entire day. Others, it will work once and then the monitor will not turn back on until I reboot the pi. After the monitor refuses to wake up, I receive the following in the pm2 logs when it does detect motion.
                                          0|mm       | monitor :state 0x7ee68dbc [HDMI unknown AR x38128 HDCP], 2129038664x4287062190 @ 45744.00Hz, interlaced
                                          0|mm       | monitor :state 0x7ee8bdbc [HDMI unknown AR x13552 HDCP], 2129182024x4287062190 @ 21168.00Hz, interlaced
                                          0|mm       | monitor has been deactivated
                                          0|mm       | monitor :state 0x7ebe5dbc [HDMI unknown AR x25840 HDCP], 2126404936x4287062190 @ 33456.00Hz, interlaced
                                          0|mm       | monitor :state 0x7e9afdbc [HDMI unknown AR x13552 HDCP], 2124086600x4287062190 @ 21168.00Hz, interlaced
                                          0|mm       | monitor :state 0x7e8dadbc [HDMI unknown AR x21744 HDCP], 2123214152x4287062190 @ 29360.00Hz, interlaced
                                          0|mm       | monitor :state 0x7efdcdbc [HDMI unknown AR x54512 HDCP], 2130562376x4287062190 @ 62128.00Hz, interlaced```
                                          Does anyone have any thoughts on how to prevent this from happening? Is there a better place to look at logs other than pm2 to see exactly what is happening. It is very odd to me that it works for different amounts of time after each reboot.
                                          For what it’s worth, when the screen stops waking up, I can navigate to rasperrybi.local:8080 in a browser and all of the modules are up and running.
                                          Any thoughts or comments are appreciated.
                                          • H
                                            Hawking @jdahli1
                                            @jdahli1
                                            I don’t know this error, therefore the following two comments might be totally wrong:
                                            The motion detector uses
                                            to switch the monitor on. What happens if you execute this command manually while the observed problem occurs (I assume you can still login to the PI?). Then you might know weather it is a problem of the motion detection (and MMM) or if it is a more general problem. Maybe you even get additional error messages that help you to identify the problem
                                            1. Do you know the HDMI-settings in /boot/config.txt ?
                                              Maybe it is worth to play around with hdmi_force_hotplug, hdmi_drive, hdmi_group and hdmi_mode . See the file and here https://raspberrypi.stackexchange.com/tags/config.txt/info for more information. Maybe the “AR” in your error stands for “aspect ratio”, this could be set explicitly be these parameters.
                                            If somebody got this module to work on a Raspberry Pi Zero (using the Midori browser) I would be highly interested in how it was done!
                                            • 10
                                            • 11
                                            • 9 / 11
