    Question About Mounting a Mirror in a Dorm
    Scheduled Pinned Locked Moved Unsolved Hardware
    framemount
    15 Posts 6 Posters 16.1k Views 6 Watching
    • O Offline
      oldversions
      I’ve projected that, when finished, my mirror will be in the range of 20-30 lbs. Does anyone know a way that I could mount this in a school dorm, that doesn’t require me nailing anything into a wall? It’s only supposed to be a temporary mount that will last to the end of the year, and it has to be removable without damaging the wall, so I was thinking of using command tape, but the highest rated one is for 16 lbs. I’m not sure if I can combine multiple of those to support that much weight.
      • O Offline
        orayoflighto Project Sponsor
        You are going to be hard pressed to find something that supports 30 lbs that is non-destructive. I would suggest making a stand for it or put it on a table.
        Any tape rating is going to be highly dependent on the cleanliness of the surface prep. I would not trust tape to hold something that you are going to pour a lot of time and money into. Maybe you can hang it from something?
          Mykle1 Project Sponsor Module Developer @oldversions
          @oldversions
          25 cents worth of spackle would fill the hole needed for a lag bolt that would hold the mirror, then a dab of paint. Done.
          • yawnsY Offline
            yawns Moderator @Mykle1
            @Mykle1 said in Question About Mounting a Mirror in a Dorm:
            @oldversions
            True in theory. I don’t know where oldversions lives, but in Germany it is illegal to even put a single nail into the wall. The only one who is allowed to do so is the official janitor.
            Some years ago a colleague of my wife wanted to mount something to the wall for her classroom. Hey boyfriend said “no big deal” and drilled a small hole into the wall, added a plug and a screw and was done. When the schools principle found out they discussed on a penalty and/or fire her.
            Mykle1M O 2 Replies Last reply Reply Quote 0
              Mykle1 Project Sponsor Module Developer @yawns
              @yawns
              Yikes! Then forget my suggestion. I’d hate to be responsible for something like that happening.
              I’m glad my son doesn’t go to THAT school. What the hell kind of punishment do you get for a REAL crime over there?
              • O Offline
                oldversions @yawns
                @yawns @Mykle1
                Well, I mean… the school would probably frown upon it, but I also know that they can barely enforce the day-to-day rules, so…
                  @oldversions
                  If you’re a student in North Korea then definitely DO NOT do that.
                  • O Offline
                    oldversions @orayoflighto
                    @orayoflighto
                    When I said tape, I was thinking of this kind of thing: https://smile.amazon.com/Command-Picture-Hanging-Strips-Damage-Free/dp/B01N0X6SA5/ref=sr_1_27?s=hi&ie=UTF8&qid=1500916733&sr=1-27&keywords=command+strips
                    • O Offline
                      oldversions @Mykle1
                      @Mykle1
                      I’m in New York State. So not that far off! XD
                      Also just totally realized you’re the guy who developed the cocktails module I’m using.
                        @oldversions
                        I can’t comment on that tape. I have no experience with it.
                        Nice! What university?
                        • O Offline
                          oldversions @Mykle1
                          @Mykle1 Fredonia. SUNY system.
                            @oldversions
                            Cold winters off the lake up there. I’m in NYC
                            • O Offline
                              oldversions @Mykle1
                              @Mykle1
                              Ah, the king city. Nice.
                              Also, it’s never the cold. Always the snow. Dear God, the snow…
                                bwente
                                I have used ook hangers to hang 50lb. objects. Here is one rated for 75lbs.
                                http://picturehangers.ooks.com/item/professional-hanging-line/tremor-hangers-2/53102
                                You can find them at lots of places locally. It will leave three tiny holes that are easy to cover up later.
                                  I would certainly NOT trust it to tape, and if you are not allowed to put any holes in the wall at all, then the only thing you might want to try is hanging the mirror using an over-the-door hook, something like this:
                                  You should be able to find something similar, and likely more apt at a local hardware store.
                                  Otherwise I’d recommend just leaning it against the wall and don’t bother hanging it until you move to a permanent home.
