    MMM-Jarvis-Voice-Control
    27 Posts 10 Posters 29.1k Views 13 Watching
    • cowboysdudeC Offline
      Looks good.
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @merceaemil
        @merceaemil I looked into openjarvis, it’s basically an offline hotword detection with snowboy or pocketsphinx and then it uses online detection for commands with bing or google
        • yawnsY Offline
          yawns Moderator
          Sounds interesting. Would you mind adding some screenshots or even a video showing your module in action?
            merceaemil @strawberry 3.141
            @strawberry-3.141
            Yes you’re right. Default configuration for openjarvis is snowboy for hotword and bing for online detection. Bing offers 5,000 transactions free per month which seems enough for daily usage.
            Also OpenJarvis supports multi language and has a nice setup screen which i think it’s a plus.
            The down side is that their online documentation and tutorials are in french but with google translate works great :)
              merceaemil @yawns
              @yawns
              I will try to make a video right now.
                merceaemil
                Here is the video.
                I integrated Jarvis with 3 of my installed modules: Camera, mm-music-player & one custom radio player.
                There is no sound in this video because my voice is captured on the mirror and on my pc i have no microphone (because i used it when I built my mirror :) ).
                BUT there will be two moments when you will here sound and that is when the music starts playing and when the radio starts playing :) because the video recorder also records sound played by my browser.
                Also you can not here Jarvis in the video because his sound is not played via browser instead it is played directly from OpenJarvis.
                https://youtu.be/EE8_pSKV54Q
                OpenJarvis plugins I installed and are quite usefull:
                • jarvis-magicmirror - This will send events to MMM-Jarvis-Voice-Control
                • jarvis-riverscript - Gives jarvis the posibility for small talk
                • jarvis-youtube-player - You can use commands like: play music from youtube or play video from youtube
                • jarvis-wikipedia - You can get some answers with this one. Command: Give me the definition “of something”
                • jarvis-ui - This gives you a nice interface where you can start chatting with Jarvis via writing.
                • jarvis-system-startup - This will give you the posibility to setup Jarvis to start at boot time
                  Well I reinstalled it following all the recommended settings. The instructions are lacking a lot. I understand this all and I can’t get it working at all. So the average user is going to be totally lost. The instructions here https://github.com/merceaemil/MMM-Jarvis-Voice-Control do not tell the user where to install them… in the MagicMirror directory… outside the directory…unclear. Same with the jarvis plugin… where is the user supposed to install it? It all loads without error but fails to work… I have installed a couple different ways and it fails to work without any errors.
                    merceaemil @cowboysdude
                    @cowboysdude Does it give you any error in console log ? What exactly is not working, JARVIS or the MagicMirror plugin? Is jarvis responding to the wake word?
                    Can you start Jarvis is Troubleshooting mode and Magic mirror in dev mode and share screenshots of logs when you are trying to use it?
                    How to start Jarvis:
                    https://www.openjarvis.com/content/usage
                    If you can respond to this questions i can try to figure out what it’s missing on your enviroment and i can fix the code and documentation
                    cowboysdudeC aro28A A 3 Replies Last reply Reply Quote 0
                      cowboysdude Module Developer @merceaemil
                      @merceaemil I will have to do this when I get home from work. Thank you!
                      • r3z3R Offline
                        r3z3
                        Salut merceaemil !
                        Tiens, ça tombe bien, c’est juste ce que je cherchais :)
                        That sounds good ! Je vais essayer d’installer ce plugin sur mon Jarvis qui marche déjà très bien.
                        Je ferai ensuite un feedback.
                        Encore merci et à bientôt !
                        r3z3R 1 Reply Last reply Reply Quote 0
