    MMM-Jarvis-Voice-Control
    27 Posts 10 Posters 31.5k Views 13 Watching
      merceaemil @yawns
      @yawns
      I will try to make a video right now.
        merceaemil
        Here is the video.
        I integrated Jarvis with 3 of my installed modules: Camera, mm-music-player & one custom radio player.
        There is no sound in this video because my voice is captured on the mirror and on my pc i have no microphone (because i used it when I built my mirror :) ).
        BUT there will be two moments when you will here sound and that is when the music starts playing and when the radio starts playing :) because the video recorder also records sound played by my browser.
        Also you can not here Jarvis in the video because his sound is not played via browser instead it is played directly from OpenJarvis.
        https://youtu.be/EE8_pSKV54Q
        OpenJarvis plugins I installed and are quite usefull:
        • jarvis-magicmirror - This will send events to MMM-Jarvis-Voice-Control
        • jarvis-riverscript - Gives jarvis the posibility for small talk
        • jarvis-youtube-player - You can use commands like: play music from youtube or play video from youtube
        • jarvis-wikipedia - You can get some answers with this one. Command: Give me the definition “of something”
        • jarvis-ui - This gives you a nice interface where you can start chatting with Jarvis via writing.
        • jarvis-system-startup - This will give you the posibility to setup Jarvis to start at boot time
        • cowboysdudeC Offline
          Well I reinstalled it following all the recommended settings. The instructions are lacking a lot. I understand this all and I can’t get it working at all. So the average user is going to be totally lost. The instructions here https://github.com/merceaemil/MMM-Jarvis-Voice-Control do not tell the user where to install them… in the MagicMirror directory… outside the directory…unclear. Same with the jarvis plugin… where is the user supposed to install it? It all loads without error but fails to work… I have installed a couple different ways and it fails to work without any errors.
            merceaemil @cowboysdude
            @cowboysdude Does it give you any error in console log ? What exactly is not working, JARVIS or the MagicMirror plugin? Is jarvis responding to the wake word?
            Can you start Jarvis is Troubleshooting mode and Magic mirror in dev mode and share screenshots of logs when you are trying to use it?
            How to start Jarvis:
            https://www.openjarvis.com/content/usage
            If you can respond to this questions i can try to figure out what it’s missing on your enviroment and i can fix the code and documentation
            cowboysdudeC aro28A A 3 Replies Last reply Reply Quote 0
              cowboysdude Module Developer @merceaemil
              @merceaemil I will have to do this when I get home from work. Thank you!
              • r3z3R Offline
                r3z3
                Salut merceaemil !
                Tiens, ça tombe bien, c’est juste ce que je cherchais :)
                That sounds good ! Je vais essayer d’installer ce plugin sur mon Jarvis qui marche déjà très bien.
                Je ferai ensuite un feedback.
                Encore merci et à bientôt !
                r3z3R 1 Reply Last reply Reply Quote 0
                • r3z3R Offline
                  r3z3 @r3z3
                  @r3z3 said in MMM-Jarvis-Voice-Control:
                  Salut merceaemil !
                  … and it works !
                  Ça marche très bien, pas de problème de cohabitation avec Jarvis.
                  Merci merceaemil !
                    merceaemil @r3z3
                    @r3z3 Hy, I am happy that it works for you :)
                    • aro28A Offline
                      aro28 @merceaemil
                        merceaemil
                        Hello
                        Please reconfigure jarvis and change the hotword to something shorter. “Hello my friend!” is to long for your setup. Use something like “Ok Mirror”.
                        The circle will show up after jarvis recognises the hot word. After Jarvis recognised that you said that hotword.
                        Just like in the screen you shared it said that the hotword has to be between 0.5 and 1.5 speaking seconds.
                        After you reconfigure the hotword tell me if it works.
                        aro28A 1 Reply Last reply Reply Quote 0
                        • aro28A Offline
                          aro28 @merceaemil
                          @merceaemil
                          I’ve changed hotword. But I cannot setup my microphone. I can configure either speakers or a microphone. it either asks to increase the signal or reduce during setup process.
                          When I say something during Setup Wizard for speaker it passed successfully but when it asks me to be silent it can’t finish and says decrease microphone gain. Please advise
                          Best,
                          • aro28A Offline
                            aro28 @aro28
                            @aro28
                            I have builted microphone in my touch screen Monitor. Should I try another external USB microphone.
                              merceaemil
                              i think you should try another mic. one that works on usb… or maybe use a webcam which has a builtin mic.
                              • aro28A Offline
                                aro28 @merceaemil
                                @merceaemil
                                Ok. Thank you! Will do tomorrow.
                                • aro28A Offline
                                  aro28 @aro28
                                  @aro28
                                  Today i installed another mic thru the 3D sound card adapter and Setup Wizard has been completed successfully.
                                  But MM is running without animated circle. Also, when i run Jarvis in troubleshooting mode, in the beginning it introduces itself and when i say something it’s just repeating my words
                                  Should i configure something else? How do voice commands work here? I’m generally new to this.
                                  Thank you in advance.
                                  aro28A 1 Reply Last reply Reply Quote 1
                                  • aro28A Offline
                                    aro28 @aro28
                                    @aro28
                                    Hi any updates on above?
                                    What should to be installed first? MM or Jarvis?
                                    Thanks!
                                      Clean it all out and reinstalled it…was good until Microsoft wanted a CC to register… that’s a big fat noooooooooooooooo…so this voice software will not do… ;)
                                      • N Offline
                                        nobita @merceaemil
                                        @merceaemil
                                        and to Anyone
                                        How to Connect (Usage) Jarvis in Magic Mirror
                                        such as How to open/close currentweather (Default module) ,
                                        How to open/close clock (default module)
                                        can you explain in detail becuase I,m Beginner
                                        Thanks for your kind
                                        • W Offline
                                          Waldehead
                                          although this thread is quite old, I have a question.
                                          Is it possible to display the inner circle (e.g. in blue) when Jarvis is in standby mode?
                                            aljosie @merceaemil
                                            @merceaemil give me the example/tutorial how to create of code how to jarvis can control homedevice, because i was try and get some failed
