    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 777.1k Views 59 Watching
      Install MagicMirror on a PC Windows 7/10 - Complete walkthrough
      I just finished a fresh install of Windows 7 on a Compaq Presario CQ57 laptop with 3.5GB of RAM and 32-bit OS.
      Worthless really, but it runs Magic Mirror like a champ, as it is far more robust than a Pi of any kind.
      No graphics problems. No system load issues. Even this old laptop makes a decent MM dev machine.
      Ok, lets get to it!
      First things first
      • Go to https://nodejs.org/en/download/ and download the Windows Installer. In this case it’s the
        node-v6.11.0-x86.msi file because I’m running 32-bit Windows 7. Double Click the installer and
        let it do its thing. You don’t have to change anything. The default installation is what you want.
        You may have noticed that npm was also installed. Isn’t that nice? :-)
      • Now go to https://git-for-windows.github.io/ and download git for Windows. Double Click the
        installer. Again, you can use the defaults but if you want to use TrueType fonts in your terminal
        windows then choose that in the Components section of the installer. Also, you can choose to use
        Git only from the Git Bash terminal. The default allows you to use Git commands from the Windows Command
        prompt. Other than that, this walkthrough assumes the defaults for Git installation.
      Lets get the MagicMirror software
      • Go to https://github.com/MichMich/MagicMirror to get the MagicMirror software.
      • Click on the green Code button on the right and copy the url (https://github.com/MichMich/MagicMirror.git)
      • Open and new terminal and type git clone and one space, then paste the url you just copied.
      • It should look like this git clone https://github.com/MichMich/MagicMirror.git
      Now you wait patiently as it installs.
      You’re so close you can taste it!
      Remember we installed Git? Click Start/All Programs/Git/Git Bash. This opens your Git Bash terminal
      window.
      • Type cd MagicMirror and press the Enter key. Now you’re in the ~/MagicMirror directory.
      • Type npm install and press the Enter key. This will install the dependencies for MagicMirror.
        It will take some time to complete depending on your PC. Mine took 6 minutes.
        You may see npm WARN for a few items but these are NOT errors and don’t affect anything.
        When that’s done, we continue, still in the ~/MagicMirror directory.
      • Type npm start and press the Enter key. You WILL get a “Please create a config file.” message
        I just wanted you to see it. No worries. We’re almost done. Follow me!
      • Press the Alt key on your keyboard. This drops down a menu bar at the top of your screen.
        You won’t see your mouse cursor until you move it all the way to the top of the screen into the
        menu bar. There it is! Click on the File menu and click Exit. This brings you back to your
        desktop. If there is a “Windows Security Alert” window concerning “Electron” click the Allow access button.
        You’ll notice “fatal: Not a git repository (or any of the parent directories): .git” in your teminal window.
        Not to worry. Minimize your terminal window or move it out of the way.
      Here we create your working config.js file.
      We’re not going to use the terminal to do this. This way is just easier, especially for beginners.
      From your desktop, navigate to your MagicMirror folder. Remember where it is? :-)
      • Double click the MagicMirror folder.
      • Double click the config folder.
      • Right click the config.js.sample file.
      • Choose Copy
      • Right click somewhere else in that same window and choose Paste.
      • Rename the “COPY” you just pasted to config.js
        Windows may ask about changing the file type. Accept! It’s now a JScript Script File.
        The config.js file that you just created is your working config file.
        This is where you’ll add your entries for other modules to your mirror.
      Had enough? Lets run that MagicMirror, NOW!
      If your Git Bash terminal window is still open (I never told you to close it) we can continue.
      If you need to open a new one then do so now and type cd MagicMirror to enter the MagicMirror directory.
      Now that you’re in the ~/MagicMirror directory of your terminal:
      Your Clock, Calendar, Compliments and Newsfeed modules are now operational!
      You’re welcome!
      Why did I bother?
      Well, for a number of reasons. When I discovered MagicMirror (January 2017) I knew less than you.
      I am completely serious. I had to learn all of this from scratch. Fortunately for me, there were some
      very generous and kind users on this forum that helped me. One in particular continues to help and
      tutor me to this day. I will call him, “Broffessor” for the sake of this walkthrough. I approached
      him for help on my very first module and he was more than willing. Now, I have 10 modules under
      my belt (7 published, 2 about to be released and 1 that will NEVER be released) and a good friend
      to go along with them. This walkthrough is a way for me to say thank you to those people that helped
      me, by helping others. I hope I have done so.
      How it all began
      My son mentioned the Raspberry Pi in passing one day. Now I’m doing some simple coding and creating
      modules for MagicMirror.
      Who woulda thought?
      Edit! Windows 10 users!
      I have not tested this but I’ve been assured that MM will indeed work on Windows 10, following the instructions above. You must absolutely use the Git Bash terminal window because the Windows CMD window does not recognize bash or sh. However, Git Bash creates a linux-like environment in which MM runs very well. :-)
      D H J U G 8 Replies Last reply Reply Quote 19
        Damian @Mykle1
        @Mykle1
        Hello. Thank you for this guide.
        Can you help me with one very small problem?
        I did this word for word and everything went perfect. I have MM showing up with the stock modules clock, calendar, compliments, news feed.
        I then go to the config.js file I created with the config.js sample as you stated, to have a look at it before I start getting other modules downloaded, but I get the following error when I try and open it.
        I did try and delete the config.js, and C/P the sample again and rename to config.js but same thing happens. MM works with stock modules, just that I cannot get into the config.js file at all.
        Windows Script Host
        Script:  C:\Users\Damian\MagicMirror\config\config.js
        Line:    26
        Char:    3
        Error:   Expected identifier, string or number
        Code:    800A0404
        Source:  Microsoft JScript compilation error
        Edit - I have now tried to open the other JS files, with same result. Just tried to open Compliments JScript Script File and that is showing similar error.
        This is a fresh install of Win 7 Home Premium SP1 and wondering if this needs anything downloaded to be able to read/execute the file, or whether there is another problem in the MM files/install?
          Mykle1 Project Sponsor Module Developer @Damian
          @Damian
          What are you trying to open the config.js file with? Open it with your text editor. I prefer Notepad++ because it can open, edit and save just about any code file but any text editor should work on the config.js file.
            Damian @Mykle1
            @Mykle1 said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7:
            @Damian
            Ahhhhhh I was simply clicking on it as I do with my Pi which then opens the file straight away. So I have to right click on it > open with > and then select Notepad, ect?
            I was too impatient and uninstalled everything, to download and start again incase I did something wrong first time, so it is just finishing off now, and will try as you suggest.
            Thank you for fast reply.
            Edit: Thanks, that worked. Although, even with Word Wrap in notepad enabled, the document is a continuous line that I will have to sort out to resemble the proper layout as it is within my Pi - Neat and tidy.
            Thanks again for your time making this Guide, which was very helpful, and to your timely manner in reply to helping with my school boy error problem
              @Damian
              Yes, that should do it. The default Win7 Notepad will work just fine. Notepadd++ is a free download and makes life a whole lot easier if you’re going to be coding or making many edits.
              Oh no! You trashed the entire installation??? But it was working. That was NOT in my Complete Walkthrough.
                Damian @Mykle1
                @Damian
                I will download that now as Notepad seems to just make an unworkable continuous line in every MM file, and seeing as I will be adding more modules, and editing them, your suggestion might work better?
                Yeah, your guide did indeed work, I just overlooked the obvious that I’m back on a PC, with a fresh win7 install, and need to allocate what opens what first. I was just way too excited to see MM through a PC, my brain was far too much on the end game :-(
                Thanks again for your help.
                Edit:
                Notepad++
                Brilliant, just brilliant. :-)
                  @Damian said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7:
                  Been there. Done that. No worries.
                  You’re welcome, mate. Cheers!
                  Edit:
                  Notepad++
                  There are other text editors for coding (my son uses Atom) but I have taken a liking to Notepad++. I think it’s safe to say that you’ll enjoy it too.
                  Enjoy your PC/mirror.
                  • L Offline
                    luizcarlosnery
                    Hello mykle1,
                    I followed your guide in: https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners, however my problem is not installing modules, I can install almost all, but some do not work … like, voice-control and play-music for ex …
                    Remembering that I’m following your guide complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10
                    My MagicMirror is in Windows 7 64Bits.
                    Thank you so much.
                      Mykle1 Project Sponsor Module Developer @luizcarlosnery
                      @luizcarlosnery said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                      So, based on your comments I can assume that your MM software is up and running. Some modules are a bit more complicated than others to get working. Perhaps voice-control and play-music are 2 such modules. I don’t use them so I am unable to help you with them. Pay particular attention to the README files that come with them.
                      You can post another topic in TROUBLESHOOTING and ask for help there. Hopefully, someone with experience with those modules can help you.
                        barnosch
                        great tutorial. Will give it a try later on.
                        I made the complicated way around it and created a VirtualMaschine with Debian, with a standalone MM installation.
                        This natively running thing is way better. Thanks
                        • 32
                        • 33
                        • 1 / 33
