    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 874.6k Views 59 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @Damian
      @Damian
      Yes, that should do it. The default Win7 Notepad will work just fine. Notepadd++ is a free download and makes life a whole lot easier if you’re going to be coding or making many edits.
      Oh no! You trashed the entire installation??? But it was working. That was NOT in my Complete Walkthrough.
        Damian @Mykle1
        @Mykle1 said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7:
        @Damian
        I will download that now as Notepad seems to just make an unworkable continuous line in every MM file, and seeing as I will be adding more modules, and editing them, your suggestion might work better?
        Yeah, your guide did indeed work, I just overlooked the obvious that I’m back on a PC, with a fresh win7 install, and need to allocate what opens what first. I was just way too excited to see MM through a PC, my brain was far too much on the end game :-(
        Thanks again for your help.
        Edit:
        Notepad++
        Brilliant, just brilliant. :-)
        • Mykle1M
          @Damian said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7:
          Been there. Done that. No worries.
          You’re welcome, mate. Cheers!
          Edit:
          Notepad++
          There are other text editors for coding (my son uses Atom) but I have taken a liking to Notepad++. I think it’s safe to say that you’ll enjoy it too.
          Enjoy your PC/mirror.
          • L
            luizcarlosnery
            Hello mykle1,
            I followed your guide in: https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners, however my problem is not installing modules, I can install almost all, but some do not work … like, voice-control and play-music for ex …
            Remembering that I’m following your guide complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10
            My MagicMirror is in Windows 7 64Bits.
            Thank you so much.
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @luizcarlosnery
              @luizcarlosnery said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
              So, based on your comments I can assume that your MM software is up and running. Some modules are a bit more complicated than others to get working. Perhaps voice-control and play-music are 2 such modules. I don’t use them so I am unable to help you with them. Pay particular attention to the README files that come with them.
              You can post another topic in TROUBLESHOOTING and ask for help there. Hopefully, someone with experience with those modules can help you.
                barnosch
                great tutorial. Will give it a try later on.
                I made the complicated way around it and created a VirtualMaschine with Debian, with a standalone MM installation.
                This natively running thing is way better. Thanks
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @barnosch
                  @barnosch said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                  You’re welcome.
                  Yes, MM runs beautifully on a PC running windows. Alternately, if you prefer Linux, you can install uBuntu on a PC. That also runs beautifully.
                    barnosch
                    Runs perfect on a Win 10 x64.
                    One thing for me is, i don’t like the fullscreen, because i want to test some stuff before i bring it to the real MM.
                    Try instead of
                    “npm start” a
                    “node serveronly”
                    This launches the MM not in full screen. You can point now to your browser and type
                    localhost:8080
                    This will show your MM installation in your favourit browser.
                    In my case, the better option :)
                    • WominatorW
                      Wominator
                      Hi Mykle1!
                      Great job! I installed it on an older Lenovo Miix 8 tablet as my “kitchen mirror” and it works smooth.
                      Have you or anyone else tried to make a “start.bat” or something like that to auto start it with windows or by a shortcut on the desktop?
                      That would be a great improvement.
                      Thanks in advance and regards
                      womi
                      If you want to make it idiot proof, someone will build a better idiot.
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @Wominator
                        @Wominator said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                        Well, I never did, but you can try this. I can’t test at the moment, but it should work. Save this as a .bat file and put it on your desktop.
                        :: This should work if this bat file is on the desktop
                        :: Also, CMD window needs ability to run bash commands (done during install of GIT)
                        :: Start CMD window
                        start cmd.exe /k
                        :: cd back one directory
                        cd ..
                        :: cd to MM directory
                        cd MagicMirror
                        :: start MM
                        npm start
                        WominatorW 1 Reply Last reply Reply Quote 0
                        • WominatorW
                          Wominator @Mykle1
                          @Mykle1
                          Hi!
                          Thanks for the quick reply!
                          It didn’t work out that way. I found a documentation on:
                          https://stackoverflow.com/questions/21564275/windows-shortcut-to-run-git-bash-script
                          So, I generated a script C:\Users\USER\npmstart.sh with
                          cd ..
                          npm start
                          Afterwards I generated a shortcut on the desktop with following path:
                          "C:\Program Files\Git\bin\sh.exe" -l -i "C:\Users\USER\npmstart.sh"
                          And it works. It starts the Bash and runs MagicMirror and leaves the Bash open in the background, so I can get back to it by pressing the Windows-Button. (remember, I run the MagicMirror on a tablet without keyboard and mouse)
                          In the Bash, I can stop MagicMirror with the onscreen keyboard by pressing Ctrl+C.
                          Regards
                          womi
                          • Mykle1M
                            @Wominator
                            Well done!
                            • H
                              Henrik @Mykle1
                              @Mykle1 Fantastic, thanks!
                              • Mykle1M
                                Mykle1 Project Sponsor Module Developer @Henrik
                                @Henrik
                                You’re welcome, mate! Enjoy your mirror. :-)
                                Peace!
                                • H
                                  Henrik @Mykle1
                                  @Mykle1 I fully am. :) Now the time has come to develop my first module.
                                    djsunrise19
                                    I switched from raspberry to a mini-itx windows10 system, too. With my raspy system I had way too much performance issues. Thanks for your walkthrough, it works really well. But, modules like MMM-voice or Hello Lucy won’t work, am I right? That would be too bad :/.
                                    • H
                                      Henrik @djsunrise19
                                      @djsunrise19 Maybe a bit late, but are you sure the performance issues were not caused by the incompatible Electron version? That seems to have been fixed in the latest MM (by downgrading Electron).
                                      Anyway, MMM-voice should work, but it’ll probably be a lot of hassle to get it going!
                                        djsunrise19 @Henrik
                                        @Henrik No, I tried a lot of electron versions, a lot of raspberries, ATB, odroids. I created that electron topic :-D. I like it smooth, none of them was. All in all I have to say, that electron seems to be the problem. The renderer / the performance is too bad. Within chrome only, the website runs super smooth. With electron its a huge difference. Even under windows (8GB RAM, G4600 CPU), electron doesn’t perform like chrome does. But it’s okay, and expensive, :-D. MagicMirror V1 was a website only. Way better than V2 with the electron framework (only the performance aspect).
                                        Perhaps @Mykle1 has an idea for MMM-voice under windows?
                                        • Mykle1M
                                          Mykle1 Project Sponsor Module Developer @djsunrise19
                                          @djsunrise19 said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                                          The problem with MMM-voice under windows is dependencies. The installer script will not work under Windows, only Raspbian or linux. So, unless you can install the dependencies independent of the installer, you’re out of luck. I don’t even know if the dependencies are available for Windows. I never really tried to find out. Let me know if you do.
                                          Now that you are running on a mini-itx board, you do have some options. You could make it a dual boot machine, which is fairly simple. One side Windows, one side ubuntu. Then you can run MMM-voice with Hello-Lucy like a champion.
                                            djsunrise19 @Mykle1
                                            @Mykle1 Thank you! First I installed ubuntu (and ubuntu mate) on that system. But there were some graphic-issues (f.e. marquee-fx in display-rotate mode looks very awful) and my microphone doesn’t work. I checked 4 or 5 of them. I thought, MMM-voice works with windows as well.
                                            After that I decided to go with windows. It works pretty well. More performant than ubuntu. There is only one problem: Each 10min (or something like that) there are very much git processes within the electron process (cpu usage is 70% for a few seconds, windows antivirus checks something too; MM2 lags a little bit). Don’t know why. Do you have the same with your windows environment?
                                            • 16
                                            • 17
                                            • 1 / 17
