    Help to modify existing modules
    11 Posts 3 Posters 7.0k Views 2 Watching
    • G Offline
      greda
      I would like to modify the following modules: weather, news, holidays to put those of my country.
      How can I do ?
      Thank you for your help.
        Mykle1 Project Sponsor Module Developer @greda
        @greda
        Weather usually requires that you enter a location ID of some sort, so that the module knows what information to display.
        Newsfeed? Do a google search for an .rss newsfeed that interests you, local to you and/or in your native language. You’ll need the url to that newsfeed to add to the module.
        MMM-Holiday2? Change the country code in the config.
        The README file included with each module has directions for use
        • cowboysdudeC Offline
          Holiday module that should work for your country…
          https://github.com/cowboysdude/MMM-Holiday2
          • G Offline
            greda
            Thanks you so much everybody
            • G Offline
              greda
              I am a beginner in this field. I’m stuck for the following things:
              1- Modify the rss stream while I modify it in the configuration file newsfeed.js with a new url: http://www.lemonde.fr/rss/une.xml
              2- I will also activate the color weather on the MagicMirror by setting my country of origin.
              For the moment, I managed to edit compliments
              Thank you very much for your help.
              • G Offline
                greda
                Sorry,
                I found or had to modify the parameters for the rss feed (MagicMirror/config/config.js).
                Now I try to display the color weather of my country.
                  @greda said in Help to modify existing modules:
                  What weather module are you using?
                  • G Offline
                    greda
                    I use module currentweather and weatherforecast.
                    Here’s my configuration :
                    			module: "currentweather",
                    				locationID: "https://openweathermap.org/city/2977892",  //ID from http://www.openweathermap.org/help/city_list.txt
                    				appid: "MyAPI"
                    			module: "weatherforecast",
                    			header: "Weather Forecast",
                    				appid: "MyAPI"
                    No information is displayed on screen.
                    Thank you for you help
                      locationID: “https://openweathermap.org/city/2977892”,
                      Change your locationID in both modules to this:
                      locationID: "2977892",
                      And, of course, enter your apiKey in both
                      • G Offline
                        greda
                        Super thank you so much.
                        I ve got weather on my magic mirror :-)
