    Help to modify existing modules
    11 Posts 3 Posters 7.8k Views 2 Watching
    • G Offline
      greda
      I am a beginner in this field. I’m stuck for the following things:
      1- Modify the rss stream while I modify it in the configuration file newsfeed.js with a new url: http://www.lemonde.fr/rss/une.xml
      2- I will also activate the color weather on the MagicMirror by setting my country of origin.
      For the moment, I managed to edit compliments
      Thank you very much for your help.
      • G Offline
        greda
        Sorry,
        I found or had to modify the parameters for the rss feed (MagicMirror/config/config.js).
        Now I try to display the color weather of my country.
          Mykle1 Project Sponsor Module Developer @greda
          @greda said in Help to modify existing modules:
          What weather module are you using?
          • G Offline
            greda
            I use module currentweather and weatherforecast.
            Here’s my configuration :
            			module: "currentweather",
            				locationID: "https://openweathermap.org/city/2977892",  //ID from http://www.openweathermap.org/help/city_list.txt
            				appid: "MyAPI"
            			module: "weatherforecast",
            			header: "Weather Forecast",
            				appid: "MyAPI"
            No information is displayed on screen.
            Thank you for you help
              locationID: “https://openweathermap.org/city/2977892”,
              Change your locationID in both modules to this:
              locationID: "2977892",
              And, of course, enter your apiKey in both
              • G Offline
                greda
                Super thank you so much.
                I ve got weather on my magic mirror :-)
                  @greda
                  Excellent! :^)
