Two way mirror netherlands
Hello all,
Very inspired by this project.
I want to buy a good two way -real glass- mirror, any advice on a good supplier? I see different suppliers but i want good transparrancy, some only have 1 percent. Thanks. -
@kingofsnake Where do you live? I’m in Canada and I needed to go to a glass supplier to get mine. As my mirror is large (460mm X 1500mm ) it was expensive, as I couldn’t find one that manufactured it locally. It needed to be imported, then cut to size.
If your mirror is small, then you can likely use this cost-effective option:
https://smartmirrors.ca/products/two-way-acrylic-mirror-thinIf you live in the US, then you have some options available:
https://www.twowaymirrors.com/
https://www.tapplastics.com/product/plastics/cut_to_size_plastic/two_way_mirrored_acrylic/558Hopefully other people can comment on other parts of the world.
As far as transparency is concerned, you want about 15-20% light transmission, unless your mirror is going to be in a dark room, in which case you can get away with lower. If your mirror will be in direct sunlight, then you might need more light transmission.
thanks for your reply, but i live in the Netherlands. Looking into Pilkington mirroview right now but few suppliers, and the ones that can supply are on holliday for a month ;-(. But i will keep searching.
@kingofsnake I just noticed that the topic subject says Netherlands! Next time I’ll do a better job reading.
@j.e.f.f np
@kingofsnake as a beginning builder in NL i am interested too. Maybe we could team up if the goods need to come from abroad.
I live also in NL and I am also looking for a good supplier for the mirror.
@Arjen @WebSpider I believe Two way mirrors does actually ship internationally, at least that’s what their website says! Best of luck!
Also from the Netherlands. I’ve got no idea where to buy a two way mirror. Some people said: https://www.pyrasied.nl/product/doorkijkspiegel/ But I don’t think that’s the right place.
@malibu you can order from Germany. There are a few shops. I think shipping will be supported.
Where can I buy them? And for what price?
@malibu And mine is
http://www.glas-per-klick.de/spiegel-antikspiegel/spionspiegel.html
not bad. -
I have already sent mirrors to the Netherlands several times and will continue to serve the Netherlands in the future ;) If you are interested, please look in this thread: https://forum.magicmirror.builders/topic/4816/two-way-community-order-for-europe-open-until-11-november-2017
Best regards
Chriz -
@malibu Why do you say you don’t think its right, have you heard bad things?
