    Electron CPU usage
    247 Posts 46 Posters 668.3k Views 42 Watching
      roramirez Core Contributors @wtidwell
      @wtidwell Can you share the configuration when did you get a big CPU usage?
      What version are you using?
      W 1 Reply Last reply
      • W
        wtidwell @Mykle1
        @Mykle1
        Looks like I’m running Jessie and my SD card is on the recommended list so I’ll try a manual reinstall.
        Thanks for all your help!
        • W
          wtidwell @roramirez
          @roramirez
          @Mykle1
          I just did a full clean install of everything including Raspian and I had to install stretch instead of Jessie but everything else installed smoothly but I’m still having this lag.
          Mykle1M 1 Reply Last reply
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @wtidwell
            @wtidwell
            2 clean installations, 1 with Jessie and 1 with Stretch and the same issue appears? Unless some step is missing with the OS or MM then I’d hate to assume you have a hardware issue. I really need to get a spare Pi3 so that I can troubleshoot more effectively. I’m only on a dev machine at the moment.
            Perhaps @roramirez has some input here
            R 1 Reply Last reply
            • SnilleS
              Snille Module Developer
              Hmm… I always thought this was a normal behavior? Electron always runs pretty high on my RPI Mirror. This is my “task-list” using nmon on the RPi (via SSH) with basically nothing on the Mirror Screen but as you can see Electron is pretty active. :)
              I do have quite a lot of active plugins of course…
              • W
                wtidwell @Snille
                @Mykle1
                Yeah I’d hate that too. =/ gonna try another clean install but this time of Raspian lite. I guess I can try a new SD card as well.
                @Snille
                That’s what mine looks like now with only default modules. And it spikes all the time.
                Mykle1M 2 Replies Last reply
                • Mykle1M
                  @wtidwell & @Snille
                  For what it’s worth:
                  Here are my screenshots from my Pi3 mirror, via VNC, as of this morning, August 21, 2017
                  at 8:26am New York time. You can clearly see that Magic Mirror is running. It’s minimized
                  in the top Menu Bar so I could run Task Manager for this test. I marked the significant
                  details with red stars. This is on top of a standard Raspbian Jessie installation that was
                  done in January, 2017 and Magic Mirror version 2.1.0. It has been running this way for
                  8 months now, without a hitch. These screenshots were done with all of the below modules
                  running. I also included a screenshot of my system stats to show the temperature of my Pi’s
                  CPU and my system load, as they both may relate to performance and throttling issues.
                  • Modules running during test and screenshots.
                  motiondetector
                  compliments
                  MMM-Fortune
                  MMM-EasyPix - 2 instances
                  MMM-EARTH
                  clock
                  calendar
                  MMM-Events
                  MMM-SystemStats
                  MMM-NetworkScanner
                  MMM-WunderGround - 2 instances
                  MMM-doomsDay
                  camera
                  MMM-Lottery
                  voicecontrol
                  MMM-EyeCandy
                  newsfeed
                  • SnilleS
                    @Mykle1 Can you do a screenshot from a terminal running nmon?
                    If you are ok with that… Here is how to do it.
                    1. Open a terminal (or log in via SSH).
                    2. Install nmon (sudo apt-get install nmon).
                    3. Open nmon by just typing “nmon”. :)
                    4. Press “t”, “l” and “m” to get “task list”, “longer term CPU averages” and “Memory & Swap stats”.
                    5. Press + to increase the update rate.
                    6. Let nmon fill the “CPU” meter and take a screenshot. :)
                      Press “q” to quit nmon.
                      Good thing about nmon is that you can use it from ssh (via putty). :)
                    Thank you!
                      roramirez Core Contributors @Mykle1
                      @Mykle1 said in Electron CPU usage:
                      What version of electron did you is installed in the system?
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @Snille
                        @Snille said in Electron CPU usage:
                        I think I did this correctly and I think you wanted a screenshot of each, so here they are. How do my stats look?
                        • Mykle1M
                          @wtidwell said in Electron CPU usage:
                          Yeah, you gotta try something to eliminate all possibilities. Let me know how you make out. Good luck!
                          • W
                            wtidwell @Mykle1
                            @Mykle1
                            I just made sure I updated to electron1.7.5 and it’s still chugging like before. I got some errors aboutHere is my nmon reading as well.
                            Imgur.com/np2mv54
                            I don’t know what to make of this haha
                            • Mykle1M
                              It can be frustrating. Hang in there. We’ll try to get you sorted or at least find out what the issue is so it can be corrected.
                              Now, let me look at your nmon
                              Edit: Ouch! :-(
                              • SnilleS
                                @Mykle1 Thank you! :) You can actually get all three on the same “screen”. :) But what matters is that your CPU is hovering around 5% and mine (ours) are hovering around 20%x2… That is strange.
                                @wtidwell Are you rinnung a “lite” version or a full version of the OS?
                                W Mykle1M 2 Replies Last reply
                                • W
                                  wtidwell @Snille
                                  @Snille
                                  I’m running a full version. I intend on reinstalling Raspian lite when I have some free time if I can’t troubleshoot it until then.
                                  When I was installing electron, I tried to install it globally with the -g command like it suggested in the electron readme. However it said I didn’t have permission and I tried to repeat it with sudo and it still said the same thing. Not sure if that means anything significant. I did get it to install non globally with no errors but I dunno if that may be my problem.
                                  • SnilleS
                                    @wtidwell Nah, I’m running the “lite” version of Jessie… So it’s not that… I did not do a separate install of electron actually. I used the “install-script” from MM at the beginning… It’s goning to be interesting to see if you get any better results with another SD card…
                                    • W
                                      wtidwell @Snille
                                      @Snille
                                      Speaking of hardware, and this may be a dumb question, but any chance the mouse and keyboard are causing this performance hitch? I just plugged in the ones on my desk which are the corsair strafe and logitech g600, both more intricate than normal pnp mouse and keyboard…
                                      • SnilleS
                                        @wtidwell Nope, I don’t think so. I have not had any keyboard nor mouse connected since I installed it. :)
                                        • Mykle1M
                                          I followed your directions but only one appeared at a time. I’ll try again later if you want me to. Getting ready for work at the moment.
                                          • SnilleS
                                            @Mykle1 Don’t worry about it. You provided the information. :) But if you want to do it anyway, do it via SSH instead, you need to have more “screen-space” to fit all the information at the same time. Check my screenshot. The number of columns and rows are much higher. :)
                                            • 12
                                            • 13
                                            • 1 / 13
