    Electron CPU usage
    247 Posts 46 Posters 644.3k Views 42 Watching
      Mykle1 Project Sponsor Module Developer @wtidwell
      @wtidwell
      That’s with just the default installation? Have you added any modules?
      • W Offline
        wtidwell
        Yeah that’s just default, no additional modules. I did remove both compliments and news feed both together and individually to see if it was one particular module but it seems to be both causing problems.
        Mykle1M R 2 Replies Last reply Reply Quote 0
          @wtidwell said in Electron CPU usage:
          Well, I’m fairly certain it is neither one of those modules. You’ve got something else going on there. The Pi3 can easily handle the default installation, and more.
          What size SD card are you using? What speed is the SD card you are using? Is there anything else on the SD card other than the OS and the MM software? How much available space is on the SD card?
          • W Offline
            wtidwell
            It’s a Samsung 32gb microsd. It’s Class10, u1 which I was wondering if that may be a problem? It says I have 22.9gb free out of 27.9 total.
            Also I tried to reinstall electron and it said there was an unmet peer dependency for styleint. So now I’m trying to figure out how to install that.
            Edit: got stylelint installed but it’s still laggy.
              @wtidwell
              The capacity is certainly large enough. I don’t know if the U1 designation has anything to do with it. There is a recommended SD card list somewhere. Your free space is more than adequate, assuming you expanded the swap file during installation of the OS, or something like that. If stylelint was a warning, and not an error, then that shouldn’t affect performance. I know, all of this doesn’t help you, so . . .
              A few more thoughts. Are you running Raspbian Jessie? Lite? Are node and npm up to date?
              I know it’s a hassle, but I always suggest a clean, MANUAL installation as opposed to troubleshooting, which could take hours, or days. Some people have had troubles with the automatic installer. That’s just my opinion, for what it’s worth.
                roramirez Core Contributors @wtidwell
                @wtidwell Can you share the configuration when did you get a big CPU usage?
                What version are you using?
                • W Offline
                  wtidwell @Mykle1
                  @Mykle1
                  Looks like I’m running Jessie and my SD card is on the recommended list so I’ll try a manual reinstall.
                  Thanks for all your help!
                  • W Offline
                    wtidwell @roramirez
                    @roramirez
                    @Mykle1
                    I just did a full clean install of everything including Raspian and I had to install stretch instead of Jessie but everything else installed smoothly but I’m still having this lag.
                      @wtidwell
                      2 clean installations, 1 with Jessie and 1 with Stretch and the same issue appears? Unless some step is missing with the OS or MM then I’d hate to assume you have a hardware issue. I really need to get a spare Pi3 so that I can troubleshoot more effectively. I’m only on a dev machine at the moment.
                      Perhaps @roramirez has some input here
                      • SnilleS Offline
                        Snille Module Developer
                        Hmm… I always thought this was a normal behavior? Electron always runs pretty high on my RPI Mirror. This is my “task-list” using nmon on the RPi (via SSH) with basically nothing on the Mirror Screen but as you can see Electron is pretty active. :)
                        I do have quite a lot of active plugins of course…
                        • W Offline
                          wtidwell @Snille
                          @Mykle1
                          Yeah I’d hate that too. =/ gonna try another clean install but this time of Raspian lite. I guess I can try a new SD card as well.
                          @Snille
                          That’s what mine looks like now with only default modules. And it spikes all the time.
                            @wtidwell & @Snille
                            For what it’s worth:
                            Here are my screenshots from my Pi3 mirror, via VNC, as of this morning, August 21, 2017
                            at 8:26am New York time. You can clearly see that Magic Mirror is running. It’s minimized
                            in the top Menu Bar so I could run Task Manager for this test. I marked the significant
                            details with red stars. This is on top of a standard Raspbian Jessie installation that was
                            done in January, 2017 and Magic Mirror version 2.1.0. It has been running this way for
                            8 months now, without a hitch. These screenshots were done with all of the below modules
                            running. I also included a screenshot of my system stats to show the temperature of my Pi’s
                            CPU and my system load, as they both may relate to performance and throttling issues.
                            • Modules running during test and screenshots.
                            motiondetector
                            compliments
                            MMM-Fortune
                            MMM-EasyPix - 2 instances
                            MMM-EARTH
                            clock
                            calendar
                            MMM-Events
                            MMM-SystemStats
                            MMM-NetworkScanner
                            MMM-WunderGround - 2 instances
                            MMM-doomsDay
                            camera
                            MMM-Lottery
                            voicecontrol
                            MMM-EyeCandy
                            newsfeed
                            • SnilleS Offline
                              @Mykle1 Can you do a screenshot from a terminal running nmon?
                              If you are ok with that… Here is how to do it.
                              1. Open a terminal (or log in via SSH).
                              2. Install nmon (sudo apt-get install nmon).
                              3. Open nmon by just typing “nmon”. :)
                              4. Press “t”, “l” and “m” to get “task list”, “longer term CPU averages” and “Memory & Swap stats”.
                              5. Press + to increase the update rate.
                              6. Let nmon fill the “CPU” meter and take a screenshot. :)
                                Press “q” to quit nmon.
                                Good thing about nmon is that you can use it from ssh (via putty). :)
                              Thank you!
                                roramirez Core Contributors @Mykle1
                                @Mykle1 said in Electron CPU usage:
                                What version of electron did you is installed in the system?
                                  Mykle1 Project Sponsor Module Developer @Snille
                                  @Snille said in Electron CPU usage:
                                  I think I did this correctly and I think you wanted a screenshot of each, so here they are. How do my stats look?
                                    Yeah, you gotta try something to eliminate all possibilities. Let me know how you make out. Good luck!
                                    • W Offline
                                      wtidwell @Mykle1
                                      @Mykle1
                                      I just made sure I updated to electron1.7.5 and it’s still chugging like before. I got some errors aboutHere is my nmon reading as well.
                                      Imgur.com/np2mv54
                                      I don’t know what to make of this haha
                                        It can be frustrating. Hang in there. We’ll try to get you sorted or at least find out what the issue is so it can be corrected.
                                        Now, let me look at your nmon
                                        Edit: Ouch! :-(
                                        • SnilleS Offline
                                          @Mykle1 Thank you! :) You can actually get all three on the same “screen”. :) But what matters is that your CPU is hovering around 5% and mine (ours) are hovering around 20%x2… That is strange.
                                          @wtidwell Are you rinnung a “lite” version or a full version of the OS?
                                          W Mykle1M 2 Replies Last reply Reply Quote 0
                                          • W Offline
                                            wtidwell @Snille
                                            @Snille
                                            I’m running a full version. I intend on reinstalling Raspian lite when I have some free time if I can’t troubleshoot it until then.
                                            When I was installing electron, I tried to install it globally with the -g command like it suggested in the electron readme. However it said I didn’t have permission and I tried to repeat it with sudo and it still said the same thing. Not sure if that means anything significant. I did get it to install non globally with no errors but I dunno if that may be my problem.
                                            • 12
                                            • 13
                                            • 1 / 13
