    Electron CPU usage
    247 Posts 46 Posters 582.8k Views 42 Watching
      Mykle1 Project Sponsor Module Developer @wtidwell
      @wtidwell said in Electron CPU usage:
      I did remove both compliments and news feed both together and individually to see if it was one particular module but it seems to be both causing problems.
      Well, I’m fairly certain it is neither one of those modules. You’ve got something else going on there. The Pi3 can easily handle the default installation, and more.
      What size SD card are you using? What speed is the SD card you are using? Is there anything else on the SD card other than the OS and the MM software? How much available space is on the SD card?
      • W Offline
        wtidwell
        It’s a Samsung 32gb microsd. It’s Class10, u1 which I was wondering if that may be a problem? It says I have 22.9gb free out of 27.9 total.
        Also I tried to reinstall electron and it said there was an unmet peer dependency for styleint. So now I’m trying to figure out how to install that.
        Edit: got stylelint installed but it’s still laggy.
          @wtidwell
          The capacity is certainly large enough. I don’t know if the U1 designation has anything to do with it. There is a recommended SD card list somewhere. Your free space is more than adequate, assuming you expanded the swap file during installation of the OS, or something like that. If stylelint was a warning, and not an error, then that shouldn’t affect performance. I know, all of this doesn’t help you, so . . .
          A few more thoughts. Are you running Raspbian Jessie? Lite? Are node and npm up to date?
          I know it’s a hassle, but I always suggest a clean, MANUAL installation as opposed to troubleshooting, which could take hours, or days. Some people have had troubles with the automatic installer. That’s just my opinion, for what it’s worth.
            roramirez Core Contributors @wtidwell
            @wtidwell Can you share the configuration when did you get a big CPU usage?
            What version are you using?
            • W Offline
              wtidwell @Mykle1
              @Mykle1
              Looks like I’m running Jessie and my SD card is on the recommended list so I’ll try a manual reinstall.
              Thanks for all your help!
              • W Offline
                wtidwell @roramirez
                @roramirez
                @Mykle1
                I just did a full clean install of everything including Raspian and I had to install stretch instead of Jessie but everything else installed smoothly but I’m still having this lag.
                  @wtidwell
                  2 clean installations, 1 with Jessie and 1 with Stretch and the same issue appears? Unless some step is missing with the OS or MM then I’d hate to assume you have a hardware issue. I really need to get a spare Pi3 so that I can troubleshoot more effectively. I’m only on a dev machine at the moment.
                  Perhaps @roramirez has some input here
                  • SnilleS Offline
                    Snille Module Developer
                    Hmm… I always thought this was a normal behavior? Electron always runs pretty high on my RPI Mirror. This is my “task-list” using nmon on the RPi (via SSH) with basically nothing on the Mirror Screen but as you can see Electron is pretty active. :)
                    I do have quite a lot of active plugins of course…
                    If you cant find it, make it and share it!
                    Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
                    • W Offline
                      wtidwell @Snille
                      @Mykle1
                      Yeah I’d hate that too. =/ gonna try another clean install but this time of Raspian lite. I guess I can try a new SD card as well.
                      @Snille
                      That’s what mine looks like now with only default modules. And it spikes all the time.
                        @wtidwell & @Snille
                        For what it’s worth:
                        Here are my screenshots from my Pi3 mirror, via VNC, as of this morning, August 21, 2017
                        at 8:26am New York time. You can clearly see that Magic Mirror is running. It’s minimized
                        in the top Menu Bar so I could run Task Manager for this test. I marked the significant
                        details with red stars. This is on top of a standard Raspbian Jessie installation that was
                        done in January, 2017 and Magic Mirror version 2.1.0. It has been running this way for
                        8 months now, without a hitch. These screenshots were done with all of the below modules
                        running. I also included a screenshot of my system stats to show the temperature of my Pi’s
                        CPU and my system load, as they both may relate to performance and throttling issues.
                        • Modules running during test and screenshots.
                        motiondetector
                        compliments
                        MMM-Fortune
                        MMM-EasyPix - 2 instances
                        MMM-EARTH
                        clock
                        calendar
                        MMM-Events
                        MMM-SystemStats
                        MMM-NetworkScanner
                        MMM-WunderGround - 2 instances
                        MMM-doomsDay
                        camera
                        MMM-Lottery
                        voicecontrol
                        MMM-EyeCandy
                        newsfeed
                        • 24
                        • 25
                        • 1 / 25
