    MMM-Lunartic
    Scheduled Pinned Locked Moved Education
    266 Posts 30 Posters 543.7k Views 29 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @Fonfon
      @Fonfon said in MMM-Lunartic:
      Now is good
      You rock! :-)
      • Mykle1M
        Now is good
        Please do this one as well
        “waxing”: “croissance”,
        “waxing gibbous”:“Glacier”,
        “full”: “plein”,
        “wanning gibbous”:“lune gibbeuse décroissante”,
        “third quarter”: “troisième quart”,
        “waning crescent”:“Croissant décroissant”,
        “new”: “Nouveau”,
        “waxing crescent”:“Croissant de cire”,
        “first quarter”:“premier quart”
        • F
          Fonfon @Mykle1
          I think that’s it
          @Mykle1 said in MMM-Lunartic:
          Now is good
          “waxing”: “croissante”,
          “waxing gibbous”:“Gibbeuse croissante”,
          “full”: “pleine”,
          “wanning gibbous”:“Gibbeuse décroissante”,
          “third quarter”: “troisième quartier”,
          “waning crescent”:“Croissante”,
          “new”: “Nouvelle”,
          “waxing crescent”:“Décroissante”,
          “first quarter”:“premier quartier”
          • Mykle1M
            I think that’s it
            Thank you again. I’ll add that to the module right now
            • Mykle1M
              A special Thank You to @Fonfon for his English to French translation for this module. Bravo!
              • Mykle1M
                Also, a special Thank You to @cowboysdude for his help and guidance on implementing translations within the module.
                • Mykle1M
                  In the unlikely event that someone else is interested in translating this module to their own language, simply substitute your language translation on the right, replacing the French translation INSIDE the quotes. I will gladly add it to the module.
                  "Distance from Earth's core = ": "Distance du noyau terrestre = ",
                  "Distance from sun = ": "Distance du soleil = ",
                  "The next full moon is ": "Prochaine pleine lune: ",
                  "The next new moon is ": "Prochaine nouvelle lune: ",
                  "The current moon is ": "La lune actuelle a ",
                  "The moon is ": "La lune a ",
                  "% illuminated": "% illuminée",
                  " days old": " jours",
                  "waxing": " croissance",
                  "waning": "décroissante",
                  "waxing": "croissante",
                  "waxing gibbous":"Gibbeuse croissante",
                  "full": "pleine",
                  "wanning gibbous":"Gibbeuse décroissante",
                  "third quarter": "troisième quartier",
                  "waning crescent":"Croissante",
                  "new": "Nouvelle",
                  "waxing crescent":"Décroissante",
                  "first quarter":"premier quartier",
                  "When the Moon hits your eye . . .": "Quand la lune frappe votre œil. . ."
                  • Mykle1M
                    Description:
                    Up to the minute information about our Lunar partner, with a splash of EyeCandy, to boot!
                    Update:
                    Now with French translation. Other languages to follow, upon request.
                    Download:
                    [card:mykle1/MMM-Lunartic]
                    Version 1.0.1
                    • F
                      Fonfon
                      Hi !
                      module work great but small mistakes
                      here is the perfect french translation.
                      Distance from Earth’s core = ": "Distance du noyau terrestre = ",
                      "The current moon is ": "La lune actuelle est a ",
                      "The moon is “: “La lune est “,
                      “% illuminated”: “% illuminée”,
                      " days old”: " jours”,
                      “waxing”: " croissante”,
                      “waning”: “décroissante”,
                      “When the Moon hits your eye . . .”: “Quand la lune frappe votre œil. . .”
                      Other question the text is not perfectly under the animated picture but a little on the left.
                      is it possible to modify that ?
                      thanks Mykle1 ;)
                      Mykle1M 3 Replies Last reply Reply Quote 0
                      • Mykle1M
                        Good morning Fonfon,
                        Take a look at the MMM-Lunartic.css file in your MMM-Lunartic folder. There you can change the color and positioning of every line of the module. You can also change the position of the animated picture, up, down, left, right. Ideally, you should copy and paste those entries into your custom.css file and do the editing there.
                        Take a screenshot of the module, post it here, and tell me what you want to achieve.
                        By default, all the text is aligned to the left text-align: left;. If you want to center the text under the animated picture, simply change all the text-align: left; to text-align: center;
                        • Mykle1M
                          Fixed, thank you!
                          git pull in the MagicMirror/modules/MMM-Lunartic folder for the corrected translation
                          • Mykle1M
                            • Mykle1M
                              Update:
                              The API I was using for this module is no longer available. What was I to do?
                              Provide my own API. :^)
                              So, along with the new API, there is a new config option to view an image of the appearance of the current moon, updated minutely. Courtesy of the U.S. Navy. Salute!
                              Download:
                              Version 1.0.2
                              Example
                              • T
                                thetalentedfool
                                Noob questions!
                                1. When I pull the latest files, both the core .js files have Windows control characters in them. (I don’t think this is the source of my problems, but it seems maybe unintentional.)
                                2. My fresh stock MM install does not like the config files for this module. It’s the only custom module I’ve tried to add in this install. Whenever I add it to my main config, startup throws a config validation error and reverts to the default file. I’m having a hard time debugging it to provide a more precise error, since it’s just failing out at the initial validation stage. Any ideas how I can debug more precisely?
                                Thanks!
                                strawberry 3.141S Mykle1M 2 Replies Last reply Reply Quote 1
                                • strawberry 3.141S
                                  strawberry 3.141 Project Sponsor Module Developer @thetalentedfool
                                  @thetalentedfool you can put your config here so we can have a look
                                  • Mykle1M
                                    Mykle1 Project Sponsor Module Developer @thetalentedfool
                                    @thetalentedfool said in MMM-Lunartic:
                                    It’s not, but thank you for bringing that to my attention.
                                    The problem is/was completely my fault. In a recent update to the repo, specifically the README file, I failed to place a comma at the end of the image: "animation" line of the config entry. I’ve updated the repo and apologize for the error. Your config entry should now look like this:
                                            module: 'MMM-Lunartic',
                                            position: 'top_left',                   // Best in left, center, or right regions
                                    		image: "animation",                     // animation, current or static
                                    		distance: "miles",                      // miles or km
                                    		useHeader: false,                       // true if you want a header
                                    		header: "The Lunartic is in my head",   // Any text you want
                                    		maxWidth: "300px",
                                    		animationSpeed: 3000,                   // updated info fades in and out
                                    If you have any further problems or questions, don’t hesitate to post for assistance. Thanks!
                                    Peace
                                    • T
                                      thetalentedfool @Mykle1
                                      @Mykle1 D’oh! Can’t believe I missed that too - my kingdom for an actual helpful nodejs debug message with pointers to the offending line. Works great now. Thanks for the response!
                                      • Mykle1M
                                        @thetalentedfool
                                        No, thank you. Just a stupid mistake on my part.
                                        MM has a command that will check your config and point out the errors but that command escapes me. I’ll take a look for it. Otherwise, jshint.com and jslint.com are pretty useful when I remember to actually USE them. :-)
                                        Cheers
                                        • Mykle1M
                                          @thetalentedfool
                                          Found it! Here is the command that will check your config if you get that error at launch. I assume you need to run it in the MagicMirror directory
                                          npm run config:check
                                          • Mykle1M
                                            @thetalentedfool
                                            I removed the comma from the config and ran npm run config:check. The result would be enough to determine the cause.
                                            daddle@daddle-Presario-CQ57-Notebook-PC:~/MagicMirror$ npm run config:check
                                            > magicmirror@2.1.3 config:check /home/daddle/MagicMirror
                                            > node tests/configs/check_config.js
                                            Checking file...  /home/daddle/MagicMirror/config/config.js
                                            Line 30 col 9 Expected '}' to match '{' from line 28 and instead saw 'distance'.
                                            Line 30 col 17 Expected '}' to match '{' from line 25 and instead saw ':'.
                                            Line 30 col 19 Expected ']' to match '[' from line 24 and instead saw 'miles'.
                                            Line 35 col 6 Missing semicolon.
                                            Line 35 col 5 Unrecoverable syntax error. (55% scanned).
                                            • 13
                                            • 14
                                            • 2 / 14
