    MMM-Lunartic
    Scheduled Pinned Locked Moved Education
    266 Posts 30 Posters 515.4k Views 29 Watching
      Mykle1 Project Sponsor Module Developer @Fonfon
      @Fonfon said in MMM-Lunartic:
      Other question the text is not perfectly under the animated picture but a little on the left.
      is it possible to modify that ?
      Good morning Fonfon,
      Take a look at the MMM-Lunartic.css file in your MMM-Lunartic folder. There you can change the color and positioning of every line of the module. You can also change the position of the animated picture, up, down, left, right. Ideally, you should copy and paste those entries into your custom.css file and do the editing there.
      Take a screenshot of the module, post it here, and tell me what you want to achieve.
      By default, all the text is aligned to the left text-align: left;. If you want to center the text under the animated picture, simply change all the text-align: left; to text-align: center;
        here is the perfect french translation.
        Fixed, thank you!
        git pull in the MagicMirror/modules/MMM-Lunartic folder for the corrected translation
            Update:
            The API I was using for this module is no longer available. What was I to do?
            Provide my own API. :^)
            So, along with the new API, there is a new config option to view an image of the appearance of the current moon, updated minutely. Courtesy of the U.S. Navy. Salute!
            Download:
            [card:mykle1/MMM-Lunartic]
            Version 1.0.2
            Example
            • T Offline
              thetalentedfool
              Noob questions!
              1. When I pull the latest files, both the core .js files have Windows control characters in them. (I don’t think this is the source of my problems, but it seems maybe unintentional.)
              2. My fresh stock MM install does not like the config files for this module. It’s the only custom module I’ve tried to add in this install. Whenever I add it to my main config, startup throws a config validation error and reverts to the default file. I’m having a hard time debugging it to provide a more precise error, since it’s just failing out at the initial validation stage. Any ideas how I can debug more precisely?
              Thanks!
              strawberry 3.141S Mykle1M 2 Replies Last reply Reply Quote 1
              • strawberry 3.141S Offline
                strawberry 3.141 Project Sponsor Module Developer @thetalentedfool
                @thetalentedfool you can put your config here so we can have a look
                  Mykle1 Project Sponsor Module Developer @thetalentedfool
                  @thetalentedfool said in MMM-Lunartic:
                  It’s not, but thank you for bringing that to my attention.
                  The problem is/was completely my fault. In a recent update to the repo, specifically the README file, I failed to place a comma at the end of the image: "animation" line of the config entry. I’ve updated the repo and apologize for the error. Your config entry should now look like this:
                          module: 'MMM-Lunartic',
                          position: 'top_left',                   // Best in left, center, or right regions
                  		image: "animation",                     // animation, current or static
                  		distance: "miles",                      // miles or km
                  		useHeader: false,                       // true if you want a header
                  		header: "The Lunartic is in my head",   // Any text you want
                  		maxWidth: "300px",
                  		animationSpeed: 3000,                   // updated info fades in and out
                  If you have any further problems or questions, don’t hesitate to post for assistance. Thanks!
                  Peace
                  • T Offline
                    thetalentedfool @Mykle1
                    @Mykle1 D’oh! Can’t believe I missed that too - my kingdom for an actual helpful nodejs debug message with pointers to the offending line. Works great now. Thanks for the response!
                    Mykle1M 3 Replies Last reply Reply Quote 0
                      @thetalentedfool
                      No, thank you. Just a stupid mistake on my part.
                      MM has a command that will check your config and point out the errors but that command escapes me. I’ll take a look for it. Otherwise, jshint.com and jslint.com are pretty useful when I remember to actually USE them. :-)
                      Cheers
                        @thetalentedfool
                        Found it! Here is the command that will check your config if you get that error at launch. I assume you need to run it in the MagicMirror directory
                        npm run config:check
                          @thetalentedfool
                          I removed the comma from the config and ran npm run config:check. The result would be enough to determine the cause.
                          daddle@daddle-Presario-CQ57-Notebook-PC:~/MagicMirror$ npm run config:check
                          > magicmirror@2.1.3 config:check /home/daddle/MagicMirror
                          > node tests/configs/check_config.js
                          Checking file...  /home/daddle/MagicMirror/config/config.js
                          Line 30 col 9 Expected '}' to match '{' from line 28 and instead saw 'distance'.
                          Line 30 col 17 Expected '}' to match '{' from line 25 and instead saw ':'.
                          Line 30 col 19 Expected ']' to match '[' from line 24 and instead saw 'miles'.
                          Line 35 col 6 Missing semicolon.
                          Line 35 col 5 Unrecoverable syntax error. (55% scanned).
                          • lavolp3L Offline
                            lavolp3 Module Developer
                            I’m astonished by the fact that “npm run config:check” seems to be so unknown in the community. It is a VERY important tool in my opinion.
                            Whenever there is something odd, always run this one first to check if the config is ok.
                            However, it took me about twenty lookups into the github readme to finally remember it correctly.
                            How to troubleshoot modules
                            MMM-soccer v2, MMM-AVStock
                            • T Offline
                              thetalentedfool
                              The terrible thing is that this command was exactly what I spent most of the afternoon yesterday looking for, and it’s apparently nowhere in the popular search results for debugging MM. (Git readme? Pffffft. Clearly my brain was not in a “RTactualFM” mood…lesson learned.) I’ll totally be preaching it now. Thanks for the info and demonstration!
                                Mykle1 Project Sponsor Module Developer @lavolp3
                                @lavolp3 said in MMM-Lunartic:
                                Well, it is a relatively new function, introduced in the last update to MM (I think). I had to look for the command because I don’t use it usually. However, I agree that it is a valuable tool
                                  I’ll write up a simple tutorial and post it so that it is easier to find using the forum search function.
                                  • lavolp3L Offline
                                    Great idea Mykle1! Thanks in advance for the effort :-)
                                    The function is not that new.
                                    I’m using it for a few months now, I’d guess.
                                      Ok, but it’s not available in MM version 2.1.1 or 2.1.2 (I think) so that would only make it available in the most recent version (2.1.3). I did say relatively new. :-)
                                        I promised a tutorial. :-)
                                        https://forum.magicmirror.builders/topic/5399/how-to-check-your-config-for-errors-for-absolute-beginners
                                          Minor update
                                          • Fixed wording for phases of the moon.
                                          • Also, a not so hidden config option for image choice.
                                          cd MagicMirror/modules/MMM-Lunartic
                                          git pull
                                          Or install as usual
                                            German translation added
                                            Thanks to our friend @tbbear, MMM-Lunartic now has German translation. And, when you choose German as your language, the date will be properly formatted for you. Again, thanks to @tbbear. Well done, Robert!
                                            git pull
                                            Or install as usual
                                            • 13
                                            • 14
                                            • 2 / 14
