    MMM-Lunartic
    Scheduled Pinned Locked Moved Education
    266 Posts 30 Posters 543.4k Views 29 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @thetalentedfool
      @thetalentedfool you can put your config here so we can have a look
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @thetalentedfool
        @thetalentedfool said in MMM-Lunartic:
        I don’t think this is the source of my problems, but it seems maybe unintentional.)
        It’s not, but thank you for bringing that to my attention.
        The problem is/was completely my fault. In a recent update to the repo, specifically the README file, I failed to place a comma at the end of the image: "animation" line of the config entry. I’ve updated the repo and apologize for the error. Your config entry should now look like this:
                module: 'MMM-Lunartic',
                position: 'top_left',                   // Best in left, center, or right regions
        		image: "animation",                     // animation, current or static
        		distance: "miles",                      // miles or km
        		useHeader: false,                       // true if you want a header
        		header: "The Lunartic is in my head",   // Any text you want
        		maxWidth: "300px",
        		animationSpeed: 3000,                   // updated info fades in and out
        If you have any further problems or questions, don’t hesitate to post for assistance. Thanks!
        Peace
        • T
          thetalentedfool @Mykle1
          @Mykle1 D’oh! Can’t believe I missed that too - my kingdom for an actual helpful nodejs debug message with pointers to the offending line. Works great now. Thanks for the response!
          Mykle1M 3 Replies Last reply Reply Quote 0
          • Mykle1M
            @thetalentedfool
            No, thank you. Just a stupid mistake on my part.
            MM has a command that will check your config and point out the errors but that command escapes me. I’ll take a look for it. Otherwise, jshint.com and jslint.com are pretty useful when I remember to actually USE them. :-)
            Cheers
            • Mykle1M
              @thetalentedfool
              Found it! Here is the command that will check your config if you get that error at launch. I assume you need to run it in the MagicMirror directory
              npm run config:check
              • Mykle1M
                @thetalentedfool
                I removed the comma from the config and ran npm run config:check. The result would be enough to determine the cause.
                daddle@daddle-Presario-CQ57-Notebook-PC:~/MagicMirror$ npm run config:check
                > magicmirror@2.1.3 config:check /home/daddle/MagicMirror
                > node tests/configs/check_config.js
                Checking file...  /home/daddle/MagicMirror/config/config.js
                Line 30 col 9 Expected '}' to match '{' from line 28 and instead saw 'distance'.
                Line 30 col 17 Expected '}' to match '{' from line 25 and instead saw ':'.
                Line 30 col 19 Expected ']' to match '[' from line 24 and instead saw 'miles'.
                Line 35 col 6 Missing semicolon.
                Line 35 col 5 Unrecoverable syntax error. (55% scanned).
                • lavolp3L
                  lavolp3 Module Developer
                  I’m astonished by the fact that “npm run config:check” seems to be so unknown in the community. It is a VERY important tool in my opinion.
                  Whenever there is something odd, always run this one first to check if the config is ok.
                  However, it took me about twenty lookups into the github readme to finally remember it correctly.
                  How to troubleshoot modules
                  MMM-soccer v2, MMM-AVStock
                  • T
                    thetalentedfool
                    The terrible thing is that this command was exactly what I spent most of the afternoon yesterday looking for, and it’s apparently nowhere in the popular search results for debugging MM. (Git readme? Pffffft. Clearly my brain was not in a “RTactualFM” mood…lesson learned.) I’ll totally be preaching it now. Thanks for the info and demonstration!
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @lavolp3
                      @lavolp3 said in MMM-Lunartic:
                      Well, it is a relatively new function, introduced in the last update to MM (I think). I had to look for the command because I don’t use it usually. However, I agree that it is a valuable tool
                      • Mykle1M
                        I’ll write up a simple tutorial and post it so that it is easier to find using the forum search function.
                        • lavolp3L
                          Great idea Mykle1! Thanks in advance for the effort :-)
                          The function is not that new.
                          I’m using it for a few months now, I’d guess.
                          • Mykle1M
                            Ok, but it’s not available in MM version 2.1.1 or 2.1.2 (I think) so that would only make it available in the most recent version (2.1.3). I did say relatively new. :-)
                            • Mykle1M
                              I promised a tutorial. :-)
                              https://forum.magicmirror.builders/topic/5399/how-to-check-your-config-for-errors-for-absolute-beginners
                              • Mykle1M
                                Minor update
                                • Fixed wording for phases of the moon.
                                • Also, a not so hidden config option for image choice.
                                cd MagicMirror/modules/MMM-Lunartic
                                git pull
                                Or install as usual
                                • Mykle1M
                                  German translation added
                                  Thanks to our friend @tbbear, MMM-Lunartic now has German translation. And, when you choose German as your language, the date will be properly formatted for you. Again, thanks to @tbbear. Well done, Robert!
                                  git pull
                                  Or install as usual
                                  • Mykle1M
                                    It appears the API that I am using for this module has reached its limit for the month of November. I apologize for that. It’s actually my API being hosted by a free service herokuapp.com. The drawback is that it has such a low limitation. I’m not willing to pay for higher usage. So, as I see it, I have 2 options if I want to keep this module alive.
                                    1. I have the PHP file that does the computations for the API. I’d be willing to host the API if someone would be willing to help me set it up locally and administer it. That doesn’t seem very likely but the offer stands.
                                    2. I can look for another public API to use for the module. This is probably the more logical option but it’s not as cool as the first.
                                    So, to those millions of MMM-Lunartic users, I will start looking for another API this very moment. In the meantime, the module will be functional again on December 1 when the current API resumes.
                                    • Mykle1M
                                      @tbbear
                                      API update
                                      I’ve acquired nearly double the amount of free API usage for my Lunartic module. So, no more loss of API in the 3rd week of every month. :-)
                                      • Mykle1M
                                        So here we are on the 24th of January and my API for this module is still up and running. Miracle of miracles! With only 7 more days left in the month I still have 47% of my free dyno hours. Looks like this problem has been solved. :-)
                                          pepebc
                                          Hello, very interesting this module.
                                          I like Astronomy a lot, and I already have it installed. I have translated it into Spanish: es.json
                                          "Distance from Earth's core = ": "Distancia desde la Tierra: ",
                                          "Distance from sun = ": "Distancia desde el Sol: ",
                                          "The next full moon is ": "Próxima Luna llena ",
                                          "The next new moon is ": "Próxima Luna nueva: ",
                                          "The current moon is ": "La fase actual lleva ",
                                          "The moon is ": "Esta Luna está  ",
                                          "% illuminated": "% iluminada",
                                          " days old": " dias transcurridos",
                                          "New Moon Phase": "Luna Nueva",
                                          "Waxing Crescent Moon": "Luna Creciente",
                                          "First Quarter Half Moon": "Primer cuarto de media luna",
                                          "Waxing Gibbous Moon": "Luna creciente Gibosa",
                                          "Full Moon": "Luna Llena",
                                          "Waning Gibbous Moon": "Luna Gibosa menguante",
                                          "Third Quarter Half Moon": "Tercer cuarto de Media Luna",
                                          "Waning Crescent Moon": "Luna creciente menguante",
                                          "When the Moon hits your eye . . .": "Cuando la Luna ilumina tus ojos . . ."
                                          • Mykle1M
                                            Mykle1 Project Sponsor Module Developer @pepebc
                                            @pepebc said in MMM-Lunartic:
                                            Hello, and thank you. I applaud the fact that you made the effort and did the translations. :-)
                                            I’ve added your translation file to the module. A git pull in the MMM-Lunartic directory will get you the updated files.
                                            Once again, thanks!
                                            Peace.
                                            • 13
                                            • 14
                                            • 2 / 14
