MMM-Lunartic
I removed the comma from the config and ran
npm run config:check. The result would be enough to determine the cause.daddle@daddle-Presario-CQ57-Notebook-PC:~/MagicMirror$ npm run config:check > magicmirror@2.1.3 config:check /home/daddle/MagicMirror > node tests/configs/check_config.js Checking file... /home/daddle/MagicMirror/config/config.js Line 30 col 9 Expected '}' to match '{' from line 28 and instead saw 'distance'. Line 30 col 17 Expected '}' to match '{' from line 25 and instead saw ':'. Line 30 col 19 Expected ']' to match '[' from line 24 and instead saw 'miles'. Line 35 col 6 Missing semicolon. Line 35 col 5 Unrecoverable syntax error. (55% scanned). daddle@daddle-Presario-CQ57-Notebook-PC:~/MagicMirror$ -
I’m astonished by the fact that “npm run config:check” seems to be so unknown in the community. It is a VERY important tool in my opinion.
Whenever there is something odd, always run this one first to check if the config is ok.
However, it took me about twenty lookups into the github readme to finally remember it correctly. -
The terrible thing is that this command was exactly what I spent most of the afternoon yesterday looking for, and it’s apparently nowhere in the popular search results for debugging MM. (Git readme? Pffffft. Clearly my brain was not in a “RTactualFM” mood…lesson learned.) I’ll totally be preaching it now. Thanks for the info and demonstration!
@lavolp3 said in MMM-Lunartic:
Well, it is a relatively new function, introduced in the last update to MM (I think). I had to look for the command because I don’t use it usually. However, I agree that it is a valuable tool
@thetalentedfool said in MMM-Lunartic:
I’ll write up a simple tutorial and post it so that it is easier to find using the forum search function.
Great idea Mykle1! Thanks in advance for the effort :-)
The function is not that new.
I’m using it for a few months now, I’d guess. -
Ok, but it’s not available in MM version 2.1.1 or 2.1.2 (I think) so that would only make it available in the most recent version (2.1.3). I did say relatively new. :-)
I promised a tutorial. :-)
Minor update
- Fixed wording for phases of the moon.
- Also, a not so hidden config option for image choice.
cd MagicMirror/modules/MMM-Lunartic
git pullOr install as usual
It appears the API that I am using for this module has reached its limit for the month of November. I apologize for that. It’s actually my API being hosted by a free service herokuapp.com. The drawback is that it has such a low limitation. I’m not willing to pay for higher usage. So, as I see it, I have 2 options if I want to keep this module alive.
I have the PHP file that does the computations for the API. I’d be willing to host the API if someone would be willing to help me set it up locally and administer it. That doesn’t seem very likely but the offer stands.
I can look for another public API to use for the module. This is probably the more logical option but it’s not as cool as the first.
So, to those millions of MMM-Lunartic users, I will start looking for another API this very moment. In the meantime, the module will be functional again on December 1 when the current API resumes.
API update
I’ve acquired nearly double the amount of free API usage for my Lunartic module. So, no more loss of API in the 3rd week of every month. :-)
So here we are on the 24th of January and my API for this module is still up and running. Miracle of miracles! With only 7 more days left in the month I still have 47% of my free dyno hours. Looks like this problem has been solved. :-)
Hello, very interesting this module.
I like Astronomy a lot, and I already have it installed. I have translated it into Spanish: es.json{ "Distance from Earth's core = ": "Distancia desde la Tierra: ", "Distance from sun = ": "Distancia desde el Sol: ", "The next full moon is ": "Próxima Luna llena ", "The next new moon is ": "Próxima Luna nueva: ", "The current moon is ": "La fase actual lleva ", "The moon is ": "Esta Luna está ", "% illuminated": "% iluminada", " days old": " dias transcurridos", "New Moon Phase": "Luna Nueva", "Waxing Crescent Moon": "Luna Creciente", "First Quarter Half Moon": "Primer cuarto de media luna", "Waxing Gibbous Moon": "Luna creciente Gibosa", "Full Moon": "Luna Llena", "Waning Gibbous Moon": "Luna Gibosa menguante", "Third Quarter Half Moon": "Tercer cuarto de Media Luna", "Waning Crescent Moon": "Luna creciente menguante", "When the Moon hits your eye . . .": "Cuando la Luna ilumina tus ojos . . ." } -
@pepebc said in MMM-Lunartic:
Hello, and thank you. I applaud the fact that you made the effort and did the translations. :-)
I’ve added your translation file to the module. A
git pullin the MMM-Lunartic directory will get you the updated files.Once again, thanks!
Peace.
Thanks to user @el97 the module now has Swedish translation.
Download:
[card:mykle1/MMM-Lunartic]
Version Update 1.0.3
Added an option for rotating data. So now the module takes up far less mirror real estate yet you still get the same information. Of course, you can still use the static mode, in which case, the module is visually unchanged.
Click on the animated gif below for a more pleasing view:
Do a
git pullin your MMM-Lunartic directory or install as per the readme. -
Version update 1.0.4
Fixed the check for “Last full moon was” and "Next full moon is. That was bothering me.
Added config option for sound of howling wolf when there is a full moon.
git pullin the MMM-Lunartic directory or install as per the readme
https://github.com/mykle1/MMM-Lunartic -
Ok, stupid me thought I fixed the issue . . . but didn’t.
Now it’s fixed!
@mykle1 Cant get the Swedish translation to show up despite language: “sv”, in config.js
Translation sv.json is present in MagicMirror/modules/MMM-Lunartic/translations
