    Electron CPU usage
    247 Posts 46 Posters 647.0k Views 42 Watching
    • T Offline
      TiemenMoesker
      In details: My mm time is running fine until an animation happens, the time freezes and the choppy animation accurs. When the animation is done the time starts again and it speeds up to the point it should be. Also I noticed that every time the animation happens the CPU jumps to 90+% usage. The pi itself also goes extremely hot.
      I bought my raspberry from coolblue.nl 4 days ago.
        bhepler Module Developer
        Have you guys tried allocating more memory to the GPU? I think the default is like 64MB or something. I bumped mine to 128MB a while ago.
        One other dumb suggestion: Did you remove the nonessential stuff from your Raspian installs? The Minecraft, Wolfram Alpha, etc. as per the complete setup tutorial?
        • T Offline
          TiemenMoesker
          Actually the only thing I did was. Run the auto install command of magic mirror 2 and pm2. That’s it.
          • W Offline
            wtidwell @bhepler
            @bhepler
            I’ve done that, both ways giving the gpu more ram and less ram and that doesn’t seem to solve it for me.
            I did remove all the excess on other installs I did but there’s no other processes running anyway to take away cpu time.
              bhepler Module Developer @TiemenMoesker
              @TiemenMoesker Okay, not a problem. This may not free up resources, but it will remove some of the unused programs from the default Raspian image. This is more important with smaller SD cards where space is at a premium.
              sudo apt-get remove --purge idle3 java-common libreoffice* minecraft-pi scratch nuscratch penguinspuzzle python-minecraftpi python3-minecraftpi smartsim sonic-pi wolfram-engine
              The second option is to increase the amount of memory that is dedicated to the graphics chip on the pi. If you enter sudo raspi-config from the command line, you’ll get a basic configuration window. If you’re actually on the pi, you can go to the main menu ->sudo Preferences and one of the tabs in the pi configuration is the GPU memory allocation. The default is 64MB IIRC. You can bump that up to 128 or 256 and see if it helps with your animation issue.
              Note: It seems like these suggestions don’t help anyway. Nuts.
              • T Offline
                TiemenMoesker @bhepler
                @bhepler
                Your “Note” says it all…😔
                • T Offline
                  TiemenMoesker
                  Fresh manual installation of Raspbarian. Running the magic mirror auto install now.
                  Everything seems fine, but I do get this:
                  //npm WARN grunt-stylelint@0.9.0 requires a peer of stylelint@^8.0.0 but none was installed.
                  npm WARN stylelint-config-standard@17.0.0 requires a peer of stylelint@^8.0.0 but none was installed.
                  npm WARN stylelint-config-recommended@1.0.0 requires a peer of stylelint@^8.0.0 but none was installed.
                  Is this a (or THE) problem?
                    djsunrise19
                    Same here. I have / had this problem since months. Today I’ve updated my mirror (because it says, there is an update). After this my mirror isn’t usable anymore. The problem is way heavier : I tried very much, but no effects. With MMv1 everything was smooth. I have 2x Raspi 3 - same behaviour.
                    • Tried Raspi 2 and 3
                    • deactivated all modules
                    • fresh installations a few times
                    • different (sandisk) sd cards
                    • increase gpu amount to 128/256MB
                    In MMv2 something changes with the CSS transitions. But I don’t know if that is the problem.
                    • T Offline
                      TiemenMoesker
                      For now I wish to know if it’s a problem with the PI or the installation / SD. Because if it’s a problem with the PI, at this moment, I can get it replaced for free or get my money back. My main reason buying the PI was for this project and to kill some time (vacation).
                        djsunrise19
                        Yeah, totally understand. I feel the same. It has to do anything with the transitions. Another screen with the newsfeed module only. You can see cleary, when the transition starts and ends. So frustrating.
                        • T Offline
                          TiemenMoesker @djsunrise19
                          @djsunrise19
                          This is what I get too, but with both News and Compliments on.
                          • T Offline
                            TiemenMoesker
                            @MichMich be our hero. :p
                            • W Offline
                              wtidwell @TiemenMoesker
                              @TiemenMoesker it feels good to get some validation that I may not actually be crazy and there is a problem. Hahaha
                              • T Offline
                                TiemenMoesker @wtidwell
                                @wtidwell True :)
                                • T Offline
                                  TiemenMoesker
                                  @djsunrise19 I noticed that you have had this problem for wel over a year now. Damn. I don’t understand how it doesnt work properly… Used Noobs to install Rasbain, used auto install from MagicMirror homepage, nothing else, yet it doesn’t work.
                                    djsunrise19 @TiemenMoesker
                                    @TiemenMoesker said in Electron CPU usage:
                                    Yes, but today, after
                                    git pull && npm install
                                    it becomes totally unusable. My “seconds” refreshed every 15 seconds, 320% CPU usage… I don’t know.
                                    • T Offline
                                      @djsunrise19
                                      :( …has anyone here tried another PI. I am considering to buy another one.
                                      D W 2 Replies Last reply Reply Quote 0
                                        @djsunrise19
                                        I have two of them. The second Raspi 3 (I bought them at the same time) works better. But, as everybody can see, while an animation is working, there are 45-55% peaks (one animation in newsfeed). I don’t think, that this should be.
                                        • W Offline
                                          @TiemenMoesker I tried two pies with exactly the same result. My spikes are way higher than 55%, on the order of max processing.
                                            A Former User
                                            I have a very stupid question.
                                            In my new ATB, transition animation caused CPU usage around max 70%.(by nmon. htop shows less than that… around 30~50%). Without transition, near 10~20%.
                                            But… I had not felt the performance issue before this thread. Will it be a real problem? I’m not an expert, but I think, temporally CPU usage could be high than we’ve thought. Should I really worry about this?
                                            • 12
                                            • 13
                                            • 4 / 13
