    Electron CPU usage
    247 Posts 46 Posters 639.3k Views 42 Watching
      Mykle1 Project Sponsor Module Developer @wtidwell
      @wtidwell said in Electron CPU usage:
      I think I’ve tried everything at this point.
      Damn! :-(
      • W Offline
        wtidwell @Mykle1
        @Mykle1
        Is there anything to do after using the install script? Am I missing some next step?
          You could try this, but I don’t think it’s anything you’re doing or not doing. MM is running, it’s just not running well. I left you another suggestion in the other topic you posted in.
          Updating your MagicMirror²
          If you want to update your MagicMirror² to the latest version, use your terminal to go to your Magic Mirror folder and type the following command:
          git pull && npm install
          If you changed nothing more than the config or the modules, this should work without any problems. Type git status to see your changes, if there are any, you can reset them with git reset --hard. After that, git pull should be possible.
          • T Offline
            TiemenMoesker
            I am having the exact same problem. It is so frustrating.
            • W Offline
              wtidwell @TiemenMoesker
              @TiemenMoesker
              I’m really sorry =/ I don’t have any better information for you, maybe you can fix yours. Mine is still busted…
              • T Offline
                TiemenMoesker
                In details: My mm time is running fine until an animation happens, the time freezes and the choppy animation accurs. When the animation is done the time starts again and it speeds up to the point it should be. Also I noticed that every time the animation happens the CPU jumps to 90+% usage. The pi itself also goes extremely hot.
                I bought my raspberry from coolblue.nl 4 days ago.
                  bhepler Module Developer
                  Have you guys tried allocating more memory to the GPU? I think the default is like 64MB or something. I bumped mine to 128MB a while ago.
                  One other dumb suggestion: Did you remove the nonessential stuff from your Raspian installs? The Minecraft, Wolfram Alpha, etc. as per the complete setup tutorial?
                  • T Offline
                    TiemenMoesker
                    Actually the only thing I did was. Run the auto install command of magic mirror 2 and pm2. That’s it.
                    • W Offline
                      wtidwell @bhepler
                      @bhepler
                      I’ve done that, both ways giving the gpu more ram and less ram and that doesn’t seem to solve it for me.
                      I did remove all the excess on other installs I did but there’s no other processes running anyway to take away cpu time.
                        bhepler Module Developer @TiemenMoesker
                        @TiemenMoesker Okay, not a problem. This may not free up resources, but it will remove some of the unused programs from the default Raspian image. This is more important with smaller SD cards where space is at a premium.
                        sudo apt-get remove --purge idle3 java-common libreoffice* minecraft-pi scratch nuscratch penguinspuzzle python-minecraftpi python3-minecraftpi smartsim sonic-pi wolfram-engine
                        The second option is to increase the amount of memory that is dedicated to the graphics chip on the pi. If you enter sudo raspi-config from the command line, you’ll get a basic configuration window. If you’re actually on the pi, you can go to the main menu ->sudo Preferences and one of the tabs in the pi configuration is the GPU memory allocation. The default is 64MB IIRC. You can bump that up to 128 or 256 and see if it helps with your animation issue.
                        Note: It seems like these suggestions don’t help anyway. Nuts.
                        • T Offline
                          TiemenMoesker @bhepler
                          @bhepler
                          Your “Note” says it all…😔
                          • T Offline
                            TiemenMoesker
                            Fresh manual installation of Raspbarian. Running the magic mirror auto install now.
                            Everything seems fine, but I do get this:
                            //npm WARN grunt-stylelint@0.9.0 requires a peer of stylelint@^8.0.0 but none was installed.
                            npm WARN stylelint-config-standard@17.0.0 requires a peer of stylelint@^8.0.0 but none was installed.
                            npm WARN stylelint-config-recommended@1.0.0 requires a peer of stylelint@^8.0.0 but none was installed.
                            Is this a (or THE) problem?
                              djsunrise19
                              Same here. I have / had this problem since months. Today I’ve updated my mirror (because it says, there is an update). After this my mirror isn’t usable anymore. The problem is way heavier : I tried very much, but no effects. With MMv1 everything was smooth. I have 2x Raspi 3 - same behaviour.
                              • Tried Raspi 2 and 3
                              • deactivated all modules
                              • fresh installations a few times
                              • different (sandisk) sd cards
                              • increase gpu amount to 128/256MB
                              In MMv2 something changes with the CSS transitions. But I don’t know if that is the problem.
                              • T Offline
                                TiemenMoesker
                                For now I wish to know if it’s a problem with the PI or the installation / SD. Because if it’s a problem with the PI, at this moment, I can get it replaced for free or get my money back. My main reason buying the PI was for this project and to kill some time (vacation).
                                  djsunrise19
                                  Yeah, totally understand. I feel the same. It has to do anything with the transitions. Another screen with the newsfeed module only. You can see cleary, when the transition starts and ends. So frustrating.
                                  • T Offline
                                    TiemenMoesker @djsunrise19
                                    @djsunrise19
                                    This is what I get too, but with both News and Compliments on.
                                    • T Offline
                                      TiemenMoesker
                                      @MichMich be our hero. :p
                                      • W Offline
                                        @TiemenMoesker it feels good to get some validation that I may not actually be crazy and there is a problem. Hahaha
                                        • T Offline
                                          TiemenMoesker @wtidwell
                                          @wtidwell True :)
                                          • T Offline
                                            TiemenMoesker
                                            @djsunrise19 I noticed that you have had this problem for wel over a year now. Damn. I don’t understand how it doesnt work properly… Used Noobs to install Rasbain, used auto install from MagicMirror homepage, nothing else, yet it doesn’t work.
                                            • 12
                                            • 13
                                            • 3 / 13
