    2 problems with MMM-MyCommute module
    13 Posts 6 Posters 10.1k Views 6 Watching
      Bob
      Brief bit of background.
      I have 2 offices that I go to. One is about a mile from where I live and I have 4 ways to get to there (walking, tram, train or bus). The other is about 30 miles away with a couple of alternative driving routes. Depending on which office I’m going to (and whether I want to walk or take public transport), I want the module to show me what is likely to be the best option to get to each of the specific offices.
      This is where I have 2 problems I’m trying to resolve and could do with some help.
      1. For driving, I never have anything but a “green” commuting time (ie, it never goes yellow or red for delays, even when adjusted to 1% and 5% delay thresholds)
      2. For the closer office I can’t get the alternative transit modes to work (ie, train, tram, bus etc). If I specify anything within the transitMode option, I get Error displayed in the module. If I just use transit (with no transitmode) it works fine, although I can’t then pick which mode of transit to use.
      My code is below (API is edited out, as are home & work postal codes - the rest is cut and paste)
      	module: 'MMM-MyCommute',
      	header: "Work Commute",
      	position: 'bottom_right',
      		api_key: 'xxxxxxxxxxxxxxxxxxxxxxxxxxx',
      		origin: 'Home Postal Code',
      		showSummary: true,
      		startTime: '00:00',
      		endTime: '23:59',
      		colorCodeTravelTime: true,
      		moderateTimeThreshold: 1.01,
      		poorTimeThreshold: 1.05,
      		destinations: [
      			destination: 'Work  1 Postal Code', // Farther office, by car, alternatives on
      			label: 'Office 1',
      			color: '#1E90FF', //Blue
      			alternatives: true,
      			destination: 'Work  2 Postal Code', // Closer office, walking, alternatives off
      			label: 'Office 2 - Walking',
      			mode: 'walking',
      			color: '#98FB98', // Green
      			alternatives: false,
      			label: 'Office 2 - Train',
      			mode: 'transit',
      			transitMode: 'train',
      			showNextVehicleDeparture: true,
      			color: '#ffff00', //Yellow
      			destination: 'Work 2 Postal Code,
      			label: 'Office 2 - Tram',
      			mode: 'transit',
      			transitMode: 'tram',
      			label: 'Office 2 - Bus',
      			mode: 'transit',
      			transitMode: 'bus',
      I’ve tried all sorts of editing, using both single and double quotes, and am using Geany to check the syntax (which I believe is correct)
      Any ideas ?
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @Bob
        @Bob I can spot multiple missing quotes
          Bob
          @strawberry-3-141 Where are there quotes missing ? I could only see a couple (which I’ve corrected in my first post). I edited the code to remove identifying info, so it should be ok now. Normally when there is a code error due to syntax (such as quotes), MM won’t even run.
          In this instance, I simply get a line error for the specific mode of transport.
            Bob
            This is what I get using the code above.
              @Bob two times you have destination: 'Work 2 Postal Code, instead of destination: 'Work 2 Postal Code',
              • yawnsY Offline
                yawns Moderator
                		showSummary: true,
                		startTime: '00:00',
                		endTime: '23:59',
                		destinations: [
                			label: 'Office 1',
                			alternatives: true,
                			mode: 'walking',
                			mode: 'transit',
                			mode: 'transit',
                			mode: 'transit',
                			transitMode: 'bus',
                  Bob
                  @strawberry-3-141 I saw that, and fixed it (just not in my post)
                  @yawns I cut and pasted your code (adjusted the API key and the postal codes), and still get the same error (as per previous screenshot)
                    Bob
                    I’m guessing no-one has any other ideas ? I wondered if there was a conflict with any other modules, so I’ve done a full rebuild of the RPi, stripped the config to just this module, and it still doesn’t work properly.
                    Ho hum
                      j.e.f.f Project Sponsor Module Developer @Bob
                      @Bob I’m the author of this module. Can you send me a private message? I’ll see if I can figure out what’s going on.
                      • K Offline
                        knubbl
                        I got the same problem. So im really interested what is the problem and how to fix.
                          @Bob @knubbl The issue is that the config has api_key: "...". It should be apikey: "..." (no underscore)
                            Bob @j.e.f.f
                            @j.e.f.f Thanks Jeff, problem solved, and everything now works. Typical that Google allows you to use the API without a valid key, and doesn’t error out to say it’s not a valid entry :(
                            Oh for the good old days of 2 word *nix error messages that required a manual the size of war and peace to troubleshoot…but at least you knew there was an error ! :)
                              shakir
                              this helped immensely. i got my MM exactly where i want it now and can cancel CTATracker. sorry for being a nub
