    2 problems with MMM-MyCommute module
    13 Posts 6 Posters 9.8k Views 6 Watching
      Bob
      This is what I get using the code above.
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @Bob
        @Bob two times you have destination: 'Work 2 Postal Code, instead of destination: 'Work 2 Postal Code',
        • yawnsY Offline
          yawns Moderator
          	module: 'MMM-MyCommute',
          	header: "Work Commute",
          	position: 'bottom_right',
          		api_key: 'xxxxxxxxxxxxxxxxxxxxxxxxxxx',
          		origin: 'Home Postal Code',
          		showSummary: true,
          		startTime: '00:00',
          		endTime: '23:59',
          		colorCodeTravelTime: true,
          		moderateTimeThreshold: 1.01,
          		poorTimeThreshold: 1.05,
          		destinations: [
          			destination: 'Work  1 Postal Code', // Farther office, by car, alternatives on
          			label: 'Office 1',
          			color: '#1E90FF', //Blue
          			alternatives: true,
          			destination: 'Work  2 Postal Code', // Closer office, walking, alternatives off
          			label: 'Office 2 - Walking',
          			mode: 'walking',
          			color: '#98FB98', // Green
          			alternatives: false,
          			label: 'Office 2 - Train',
          			mode: 'transit',
          			transitMode: 'train',
          			showNextVehicleDeparture: true,
          			color: '#ffff00', //Yellow
          			label: 'Office 2 - Tram',
          			mode: 'transit',
          			transitMode: 'tram',
          			label: 'Office 2 - Bus',
          			mode: 'transit',
          			transitMode: 'bus',
            Bob
            @strawberry-3-141 I saw that, and fixed it (just not in my post)
            @yawns I cut and pasted your code (adjusted the API key and the postal codes), and still get the same error (as per previous screenshot)
              Bob
              I’m guessing no-one has any other ideas ? I wondered if there was a conflict with any other modules, so I’ve done a full rebuild of the RPi, stripped the config to just this module, and it still doesn’t work properly.
              Ho hum
                j.e.f.f Project Sponsor Module Developer @Bob
                @Bob I’m the author of this module. Can you send me a private message? I’ll see if I can figure out what’s going on.
                • K Offline
                  knubbl
                  I got the same problem. So im really interested what is the problem and how to fix.
                    @Bob @knubbl The issue is that the config has api_key: "...". It should be apikey: "..." (no underscore)
                      Bob @j.e.f.f
                      @j.e.f.f Thanks Jeff, problem solved, and everything now works. Typical that Google allows you to use the API without a valid key, and doesn’t error out to say it’s not a valid entry :(
                      Oh for the good old days of 2 word *nix error messages that required a manual the size of war and peace to troubleshoot…but at least you knew there was an error ! :)
                        shakir
                        this helped immensely. i got my MM exactly where i want it now and can cancel CTATracker. sorry for being a nub
