    worldclock - nobody made this, so I did.
    46 Posts 14 Posters 34.9k Views 14 Watching
      A Former User @Mykle1
      @Mykle1 good suggestion. I’d missed it. Later i’ll add.
        richardh151 @Guest
        @Sean thank you works perfectly and looks great.
        • N
          nobita @Guest
          Thanks your help
            A Former User @nobita
            @nobita good suggestion. I like that circled flags. Where do you get that?
            N Mykle1M 2 Replies Last reply Reply Quote 0
            • N
              nobita @Guest
              @Sean I can’t remember because a longtime ago
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @Guest
                @Sean said in worldclock - nobody made this, so I did.:
                https://www.shutterstock.com/image-vector/simple-circle-flags-vector-countries-flat-298861670
                https://image.shutterstock.com/z/avopix-199602161.jpg
                  @nobita How about this?
                  I cannot find any pretty flag images on the network, so I use flag-icon-css.
                  @Mykle1 gave me good resources, but I feel some question.
                  Should we store all the flags in modules? Each person needs only a few flags at once. Therefore I try to find some resources approachable on the internet directly, which might be already hosted via CDN or something like. The only one thing I’ve found was flag-icon-css.
                  But… The flag is not so pretty as I’ve thought.
                  Anyway, I added flags feature, you can upgrade your module now.
                  [card:eouia/worldclock]
                  Mykle1M N iMAGiCI 3 Replies Last reply Reply Quote 3
                  • Mykle1M
                    @Sean
                    Those look fantastic! Nice work Sean!
                    • N
                      nobita @Guest
                      @Sean Very Nice and Good Module for all
                      • iMAGiCI
                        iMAGiC @Guest
                        @Sean thanks for the module, could you advise how to hide time gap, default is showing, but I can’t hide it when set “false”.
                        Choice * Judgment * Values
                          A Former User @iMAGiC
                          @iMAGiC in your custom css, add this.
                          .worldclock .gap {
                          display:none;
                          iMAGiCI 1 Reply Last reply Reply Quote 0
                          • iMAGiCI
                            iMAGiC @Guest
                            @Sean thanks, but I can’t get it work, found alternative. Thank you.
                              @iMAGiC
                              Sorry for my improper instruction. At that time I was not in front of machine, so I just simply guessed,
                               .worldclock .world .caption .gap {
                               display:none;
                              will do.
                              • N
                                nobita @Guest
                                @Sean , How to Change your digital Clock to Analog Clock
                                like as the default module clock (MM2)
                                Configuration options
                                displayType : Possible values: digital, analog, or both
                                analogFace : Possible values: simple for a simple border, none for no face or border,
                                or face-### (where ### is currently a value between 001 and 012, inclusive)
                                Thank so much for your all helps
                                  @nobita
                                  Unfortunately, worldclock doesn’t support Analog face. Sorry.
                                  • A
                                    Arjen_lima
                                    Hi There,
                                    just starting out with MM and i like the module a lot.
                                    one question i have is how to organize the clock’s in row instead of one below the other.
                                    thanks
                                    Arjen
                                      A Former User @Arjen_lima
                                      @Arjen_lima
                                      Sorry for my English, I cannot catch your question.
                                      The order of clocks is defined in config.js by the section clocks, that is the array of clock, then the order of display is same with the order of array element.
                                      Or… If you mean another problem, give me more detailed information. Of course, an image could be the great help for understanding.
                                      • A
                                        Arjen_lima @Guest
                                        @Arjen_lima
                                        Hey Sean,
                                        Its probably my english ;-),
                                        now the clocks in the array are all vertically aligned one clock below the next clock.
                                        in some of the screen shots they are in a 3x3 grid i was wondering how to get it like that
                                        my current lay out
                                        the lay out im looking for
                                        ? 1 Reply Last reply Reply Quote 1
                                          @Arjen_lima
                                          Sorry for the confusion. that image was just sample of the different layout configuration. That was not real, it was photoshopped.
                                            Peter
                                            Can somebody help me to change the font size of this module?
                                            I would like to have the time a little smaller; about the same as the size of the citynames.
                                            Thanks.
                                            Peter
                                            • 2 / 3
