    worldclock - nobody made this, so I did.
    46 Posts 14 Posters 35.3k Views 14 Watching
      richardh151
      I’m a complete novice but successfully managed to get the three additional clocks on my MM and I am able to edit their name. However I am unable to set the correct time for each country, for example I want to set the time for Mumbai India and also Shanghai China, but struggling. Please can you give me some simple instructions as I’ve looked in the various folders and failed so far.
      ? 1 Reply Last reply
        A Former User @richardh151
        @richardh151
        You can try this config.
        clocks: [
                   title: "LA, USA",
        	   timezone: "America/Los_Angeles"
        	   title: "Shanghai, China",
                   timezone: "Asia/Shanghai",
                   timegap: true,
        	    title: "Mumbai, India",
                    timezone: "Asia/Kolkata",
        	    timegap: true,
        Whole available list of timezone name is here;
        https://en.wikipedia.org/wiki/List_of_tz_database_time_zones
        Mykle1M R 2 Replies Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @Guest
          @Sean said in worldclock - nobody made this, so I did.:
          Maybe add the link to the timezones into your readme in case people don’t see it here.
          Well done Sean!
            A Former User @Mykle1
            @Mykle1 good suggestion. I’d missed it. Later i’ll add.
              richardh151 @Guest
              @Sean thank you works perfectly and looks great.
              • N
                nobita @Guest
                Thanks your help
                ? 2 Replies Last reply
                  A Former User @nobita
                  @nobita good suggestion. I like that circled flags. Where do you get that?
                  N Mykle1M 2 Replies Last reply
                  • N
                    nobita @Guest
                    @Sean I can’t remember because a longtime ago
                    • Mykle1M
                      https://www.shutterstock.com/image-vector/simple-circle-flags-vector-countries-flat-298861670
                      https://image.shutterstock.com/z/avopix-199602161.jpg
                        @nobita How about this?
                        I cannot find any pretty flag images on the network, so I use flag-icon-css.
                        @Mykle1 gave me good resources, but I feel some question.
                        Should we store all the flags in modules? Each person needs only a few flags at once. Therefore I try to find some resources approachable on the internet directly, which might be already hosted via CDN or something like. The only one thing I’ve found was flag-icon-css.
                        But… The flag is not so pretty as I’ve thought.
                        Anyway, I added flags feature, you can upgrade your module now.
                        [card:eouia/worldclock]
                        Mykle1M N iMAGiCI 3 Replies Last reply
                        Reply Quote 3
                        • Mykle1M
                          @Sean
                          Those look fantastic! Nice work Sean!
                          • N
                            nobita @Guest
                            @Sean Very Nice and Good Module for all
                            • iMAGiCI
                              iMAGiC @Guest
                              @Sean thanks for the module, could you advise how to hide time gap, default is showing, but I can’t hide it when set “false”.
                              Choice * Judgment * Values
                                A Former User @iMAGiC
                                @iMAGiC in your custom css, add this.
                                .worldclock .gap {
                                display:none;
                                iMAGiCI 1 Reply Last reply
                                • iMAGiCI
                                  iMAGiC @Guest
                                  @Sean thanks, but I can’t get it work, found alternative. Thank you.
                                    @iMAGiC
                                    Sorry for my improper instruction. At that time I was not in front of machine, so I just simply guessed,
                                     .worldclock .world .caption .gap {
                                     display:none;
                                    will do.
                                    N 1 Reply Last reply
                                    • N
                                      nobita @Guest
                                      @Sean , How to Change your digital Clock to Analog Clock
                                      like as the default module clock (MM2)
                                      Configuration options
                                      displayType : Possible values: digital, analog, or both
                                      analogFace : Possible values: simple for a simple border, none for no face or border,
                                      or face-### (where ### is currently a value between 001 and 012, inclusive)
                                      Thank so much for your all helps
                                        @nobita
                                        Unfortunately, worldclock doesn’t support Analog face. Sorry.
                                        • A
                                          Arjen_lima
                                          Hi There,
                                          just starting out with MM and i like the module a lot.
                                          one question i have is how to organize the clock’s in row instead of one below the other.
                                          thanks
                                          Arjen
                                            A Former User @Arjen_lima
                                            @Arjen_lima
                                            Sorry for my English, I cannot catch your question.
                                            The order of clocks is defined in config.js by the section clocks, that is the array of clock, then the order of display is same with the order of array element.
                                            Or… If you mean another problem, give me more detailed information. Of course, an image could be the great help for understanding.
                                            A 1 Reply Last reply
