    worldclock - nobody made this, so I did.
    46 Posts 14 Posters 33.9k Views 14 Watching
      [[global:former-user]] @richardh151
      @richardh151
      You can try this config.
      clocks: [
                 title: "LA, USA",
      	   timezone: "America/Los_Angeles"
      	   title: "Shanghai, China",
                 timezone: "Asia/Shanghai",
                 timegap: true,
      	    title: "Mumbai, India",
                  timezone: "Asia/Kolkata",
      	    timegap: true,
      Whole available list of timezone name is here;
      https://en.wikipedia.org/wiki/List_of_tz_database_time_zones
      Mykle1M R 2 Replies Last reply Reply Quote 1
        Mykle1 Project Sponsor Module Developer @Guest
        @Sean said in worldclock - nobody made this, so I did.:
        Maybe add the link to the timezones into your readme in case people don’t see it here.
        Well done Sean!
          [[global:former-user]] @Mykle1
          @Mykle1 good suggestion. I’d missed it. Later i’ll add.
            richardh151 @Guest
            @Sean thank you works perfectly and looks great.
            • N Offline
              nobita @Guest
              Thanks your help
                [[global:former-user]] @nobita
                @nobita good suggestion. I like that circled flags. Where do you get that?
                N Mykle1M 2 Replies Last reply Reply Quote 0
                • N Offline
                  nobita @Guest
                  @Sean I can’t remember because a longtime ago
                    https://www.shutterstock.com/image-vector/simple-circle-flags-vector-countries-flat-298861670
                    https://image.shutterstock.com/z/avopix-199602161.jpg
                      @nobita How about this?
                      I cannot find any pretty flag images on the network, so I use flag-icon-css.
                      @Mykle1 gave me good resources, but I feel some question.
                      Should we store all the flags in modules? Each person needs only a few flags at once. Therefore I try to find some resources approachable on the internet directly, which might be already hosted via CDN or something like. The only one thing I’ve found was flag-icon-css.
                      But… The flag is not so pretty as I’ve thought.
                      Anyway, I added flags feature, you can upgrade your module now.
                      [card:eouia/worldclock]
                      Mykle1M N iMAGiCI 3 Replies Last reply Reply Quote 3
                        @Sean
                        Those look fantastic! Nice work Sean!
                        • N Offline
                          nobita @Guest
                          @Sean Very Nice and Good Module for all
                          • iMAGiCI Offline
                            iMAGiC @Guest
                            @Sean thanks for the module, could you advise how to hide time gap, default is showing, but I can’t hide it when set “false”.
                            Choice * Judgment * Values
                              [[global:former-user]] @iMAGiC
                              @iMAGiC in your custom css, add this.
                              .worldclock .gap {
                              display:none;
                              iMAGiCI 1 Reply Last reply Reply Quote 0
                              • iMAGiCI Offline
                                iMAGiC @Guest
                                @Sean thanks, but I can’t get it work, found alternative. Thank you.
                                  @iMAGiC
                                  Sorry for my improper instruction. At that time I was not in front of machine, so I just simply guessed,
                                   .worldclock .world .caption .gap {
                                   display:none;
                                  will do.
                                  • N Offline
                                    nobita @Guest
                                    @Sean , How to Change your digital Clock to Analog Clock
                                    like as the default module clock (MM2)
                                    Configuration options
                                    displayType : Possible values: digital, analog, or both
                                    analogFace : Possible values: simple for a simple border, none for no face or border,
                                    or face-### (where ### is currently a value between 001 and 012, inclusive)
                                    Thank so much for your all helps
                                      @nobita
                                      Unfortunately, worldclock doesn’t support Analog face. Sorry.
                                        Arjen_lima
                                        Hi There,
                                        just starting out with MM and i like the module a lot.
                                        one question i have is how to organize the clock’s in row instead of one below the other.
                                        thanks
                                        Arjen
                                          [[global:former-user]] @Arjen_lima
                                          @Arjen_lima
                                          Sorry for my English, I cannot catch your question.
                                          The order of clocks is defined in config.js by the section clocks, that is the array of clock, then the order of display is same with the order of array element.
                                          Or… If you mean another problem, give me more detailed information. Of course, an image could be the great help for understanding.
                                            Arjen_lima @Guest
                                            @Arjen_lima
                                            Hey Sean,
                                            Its probably my english ;-),
                                            now the clocks in the array are all vertically aligned one clock below the next clock.
                                            in some of the screen shots they are in a 3x3 grid i was wondering how to get it like that
                                            my current lay out
                                            the lay out im looking for
                                            ? 1 Reply Last reply Reply Quote 1
